440CMQ030
440CMQ030
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
440CMQ030 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N0982, Rev. C 440CMQ030 Green Products 440CMQ030 SCHOTTKY RECTIFIER Applications: ● Switching power supply ● Converters ● Free-Wheeling diodes ● Reverse battery protection Features: • • • • • • • • • 150℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN st nd Marking for 440CMQ030, 1 row SS YYWWL, 2 row 440CMQ030 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 440CMQ030 Technical Data Data Sheet N0982, Rev. C Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward* Max. Peak One Cycle NonRepetitive Surge Current (peg leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRWM IF(AV) Condition 50% duty cycle @TC = 95°C, rectangular wave form IFSM 8.3 ms, half Sine pulse 3600 A EAS TJ=25℃,IAS=44A,L=0.20mH 198 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max.VA=1.5×VR typical 44 A Symbol Condition @ 220A, Pulse, TJ = 25 °C @ 440A, Pulse, TJ = 25 °C @ 220A, Pulse, TJ = 125 °C @ 440A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - 220 440 Max. 30 per leg per device Units V A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF1 VF2 Max. Reverse Current (per leg) * IR1 IR2 Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * CT LS dv/dt Max. 0.50 0.60 0.41 0.52 Units V V 20 mA 1120 mA 14800 pF 5.0 nH 10,000 V/μs Specification -55 to +150 -55 to +150 Units °C °C Pulse Width < 300µs, Duty Cycle
440CMQ030
物料型号:440CMQ030 器件简介:该器件为肖特基整流器,适用于开关电源、转换器、飞轮二极管和反向电池保护等应用。
引脚分配:Anode1(阳极1)连接到引脚1,Anode2(阳极2)连接到引脚3,Common Cathode(公共阴极)连接到引脚2。
参数特性:包括最大反向工作电压150℃、中心抽头模块、低正向电压降、高频率操作、增强的鲁棒性和长期可靠性。
功能详解:器件采用高纯度、耐高温的环氧树脂封装,以增强机械强度和防潮性能。
应用信息:适用于需要高可靠性和高效率的应用场景,如开关电源和转换器。
封装信息:封装类型为PRM4(隔离型),尺寸和安装扭矩等信息在文档中有详细说明。
440CMQ030 价格&库存
很抱歉,暂时无法提供与“440CMQ030”相匹配的价格&库存,您可以联系我们找货
