409DMQ135
409DMQ135
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
409DMQ135 数据手册
SANGDEST MICROELECTRONICS 409DMQ SERIES Green Products Technical Data Data Sheet N1502, Rev. - 409DMQ135/150 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 175 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN Marking for 409CMQ135/150, 1st row SS YYWWL, 2nd row 409CMQ135/150 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 409DMQ SERIES Green Products Technical Data Data Sheet N1502, Rev. - Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM Condition - IF(AV) 50% duty cycle @TC =105°C, rectangular wave form IFSM 8.3 ms, half Sine pulse 135 150 200 400 Max. 409CMQ135 409CMQ150 per leg per device Units V A 2760 A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Isolation Voltage IR1 IR2 CT LS VISO Max. Voltage Rate of Change * dv/dt Condition @ 200A, Pulse, TJ = 25 °C @ 400A, Pulse, TJ = 25 °C @ 200A, Pulse, TJ = 125 °C @ 400A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Tracer to 1500V, measuring whether conducting base plate and the center column - Max. 1.03 1.21 0.72 0.83 6 85 Units V V mA mA 6000 pF 5.0 nH 1500 V 10,000 V/µs Specification -55 to +150 -55 to +150 Units °C °C Pulse Width < 300µs, Duty Cycle
409DMQ135
物料型号:409DMQ135/150
器件简介:409DMQ系列肖特基整流器,适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
引脚分配:阳极(ANODE COMMON)和阴极(CATHODE)。
参数特性: - 峰值反向电压(VRWM):135V(409CMQ135)/ 150V(409CMQ150) - 最大平均正向电流(IF(AV)):每腿200A,设备总400A,50%占空比@Tc=105°C - 最大正向电压降(VF1):单腿200A时为1.03V,设备总400A时为0.72V,单腿在T=25°C时为1.21V - 最大反向电流(IR1):每腿在额定VR@T=25°C时为6mA - 最大结电容(CT):每腿在VR=5V,T=25°C时为6000pF - 典型串联电感(Ls):从封装体5mm处测量,每腿为5.0nH - 隔离电压(VIso):1500V
功能详解:该器件能在175℃的结温下工作,具有中心抽头模块、高纯度高温环氧封装以增强机械强度和防潮性、低正向电压降、高频率操作能力、防护环以增强鲁棒性和长期可靠性。
应用信息:适用于需要高电流和高可靠性的场合,例如开关电源、电镀电源、UPS系统等。
封装信息:PRM4(Isolated),标记为409CMQ135/150,采用环氧树脂UL:94V-0封装,符合无铅标准,所有SMC零件都可以追溯到晶圆批次。
409DMQ135 价格&库存
很抱歉,暂时无法提供与“409DMQ135”相匹配的价格&库存,您可以联系我们找货
