409CMQ135/150
409CMQ135R/150R
Technical Data
Data Sheet N0991, Rev. E
Green Products
409CMQ135/150 409CMQ135R/150R
SCHOTTKY RECTIFIER
Applications:
● High current switching power supply ● Plating power supply ● Free-Wheeling diodes
● Reverse battery protection ● Converters ● UPS System ● Welding
Features:
175 ℃ TJ operation
Center tap module
High purity, high temperature epoxy encapsulation for enhanced
mechanical strength and moisture resistance
Low forward voltage drop
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In mm/Inches
409CMQ135
409CMQ150
409CMQ135R
409CMQ150R
Please Note: Suffix “R” Denotes For Reversed Polarity
PRM4 (Isolated)
MARKING,MOLDING RESIN
st
nd
Marking for 409CMQ135/R 409CMQ150/R, 1 row SS YYWWL, 2 row 409CMQ135/409CMQ135R 409CMQ150/409CMQ150R
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL:94V-0
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
409CMQ135/150
409CMQ135R/150R
Technical Data
Green Products
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Symbol
VRRM
VRWM
VR
Condition
Average Forward Current
IF(AV)
50% duty cycle @TC =105°C,
rectangular wave form
Peak One Cycle Non-Repetitive
Surge Current(per leg)
IFSM
8.3 ms, half Sine pulse
Max.
135
409CMQ135/R
150
409CMQ150/R
200
400
Units
V
per leg
per device
A
2760
A
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Symbol
VF1
VF2
Reverse Current (per leg) *
Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Isolation Voltage
IR1
IR2
CT
LS
VISO
Voltage Rate of Change
dv/dt
Condition
@ 200A, Pulse, TJ = 25 °C
@ 400A, Pulse, TJ = 25 °C
@ 200A, Pulse, TJ = 125 °C
@ 400A, Pulse, TJ = 125 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Tracer to 1500V, measuring
whether conducting base
plate and the center column
Max.
1.03
1.21
0.72
0.83
6
85
Units
V
V
mA
mA
6000
pF
5.0
nH
1500
V
10,000
V/μs
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“409CMQ135”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 198+633.50406198+81.96066
