444CMQ035
444CMQ035
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
444CMQ035 数据手册
SANGDEST MICROELECTRONICS 444CMQ… SERIES Technical Data Data Sheet N1233, Rev. B Green Products 444CMQ035/444CMQ040/444CMQ045 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 125℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN st nd Marking for 444CMQ035/040/045, 1 row SS YYWWL, 2 row 444CMQ035/040/045 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 444CMQ… SERIES Technical Data Data Sheet N1233, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRWM Condition - 35 40 45 220 440 Max. 444CMQ035 444CMQ040 444CMQ045 per leg per device Units V IF(AV) 50% duty cycle @TC =81°C, rectangular wave form A IFSM 8.3 ms, half Sine pulse 4560 A EAS TJ=25℃,IAS=40A,L=0.34mH 270 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 40 A Symbol Condition @ 220A, Pulse, TJ = 25 °C @ 440A, Pulse, TJ = 25 °C @ 220A, Pulse, TJ = 125 °C @ 440A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt Max. 0.53 0.69 0.51 0.68 20 2400 Units V V mA mA 10300 pF 5.0 nH 10,000 V/μs Specification -55 to +125 -55 to +125 Units °C °C Pulse Width < 300µs, Duty Cycle
444CMQ035
物料型号: - 444CMQ035 - 444CMQ040 - 444CMQ045
器件简介: 444CMQ系列是SANGDEST MICROELECTRONICS生产的肖特基整流器,适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
引脚分配: - 阳极1 = 端子1 - 阳极2 = 端子3 - 公共阴极 = 端子2 - 后缀R表示反极性。
参数特性: - 最高工作结温(TJ):125℃ - 中心抽头模块 - 高纯度、耐高温环氧封装,增强机械强度和防潮性能 - 低正向电压降 - 高频运行 - 保护环增强鲁棒性和长期可靠性 - 无铅设备 - 所有SMC部件都可以追溯到晶圆批次
功能详解: - 该系列肖特基整流器具有低正向电压降和高频率运行能力,适用于需要高效率和高可靠性的场合。
应用信息: - 适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
封装信息: - 封装类型:PRM4(隔离) - 封装材料:环氧树脂UL:94V-0
444CMQ035 价格&库存
很抱歉,暂时无法提供与“444CMQ035”相匹配的价格&库存,您可以联系我们找货
