MDD220-12N1
MDD220-12N1
    IXYSCORPORATION
    Y2-DCB
    DIODE MODULE 1.2KV 270A Y2-DCB
MDD220-12N1 数据手册
MDD 220 High Power Diode Modules VRSM V 1300 1500 1700 1900 VRRM V 1200 1400 1600 1800 IFRSM = 2x 450 A IFAVM = 2x 270 A VRRM = 1200-1800 V 3 Type 1 2 MDD 220-12N1 MDD 220-14N1 MDD 220-16N1 MDD 220-18N1 E72873 Symbol Conditions IFRMS IFAVM TVJ = TVJM TC = 100°C; 180° sine IFSM TVJ = 45°C; VR = 0 It 2 Maximum Ratings 450 270 A A t = 10 ms (50 Hz) t = 8.3 ms (60 Hz) 8500 9000 A A • Direct copper bonded Al2O3 ceramic base plate • Planar passivated chips • Isolation voltage 3600 V~ • UL registered, E 72873 TVJ = TVJM; VR = 0 t = 10 ms (50 Hz) t = 8.3 ms (60 Hz) 7500 8000 A A Applications TVJ = 45°C; VR = 0 t = 10 ms (50 Hz) t = 8.3 ms (60 Hz) 360000 340000 As A2s TVJ = TVJM; VR = 0 t = 10 ms (50 Hz) t = 8.3 ms (60 Hz) 280000 260000 A2s A2s -40...+150 150 -40...+125 °C °C °C 3000 3600 V~ V~ 2.5 - 5 12 - 15 Nm Nm 320 g TVJ TVJM Tstg 2 VISOL 50/60 Hz, RMS t = 1 min IISOL < 1 mA t=1s Md Mounting torque (M5) Terminal connection torque (M8) Weight Typical including screws Symbol Conditions IRRM VR = VRRM; TVJ = TVJM 40 mA VF IF = 600 A; TVJ = 25°C 1.4 V VT0 rt For power-loss calculations only TVJ = TVJM 0.75 0.9 V mW RthJC per diode; DC current per module per diode; DC current per module 0.129 0.065 0.169 0.0845 K/W K/W K/W K/W RthJK Features • Supplies for DC power equipment • DC supply for PWM inverter • Field supply for DC motors • Battery DC power supplies Advantages • Space and weight savings • Simple mounting • Improved temperature and power cycling • Reduced protection circuits Characteristics Values other values see Fig. 6/7 QS IRM TVJ = 125°C; IF = 400 A; -di/dt = 50 A/µs 760 275 µC A dS dA a Creeping distance on surface Creepage distance in air Maximum allowable acceleration 12.7 9.6 50 mm mm m/s2 Data according to IEC 60747 and refer to a single diode unless otherwise stated. IXYS reserves the right to change limits, test conditions and dimensions. © 2015 IXYS All rights reserved 20150910a 1-4 MDD 220 Dimensions in mm (1 mm = 0.0394“) 42.5 28.5 0.25 32 hex SW13 4.5 M8x16 35 65 x 57 116 6 5.5 38 60 80 4567 max. 12.4 Threaded spacer for higher Anode / Cathode construction: Type ZY 250 (material brass) IXYS reserves the right to change limits, test conditions and dimensions. © 2015 IXYS All rights reserved 20150910a 2-4 MDD 220 12000 106 50 Hz, 80%VRRM 600 VR = 0 V 10000 8000 400 IFAVM I2dt IFSM [s] DC 180° sin. 120° rect. 60° rect. 30° rect. 500 6000 300 TVJ = 45°C [A2s] TVJ = 45°C [A] 4000 200 TVJ = 150°C TVJ = 150°C 2000 0 10-3 100 10-1 10-2 105 101 1 100 4 2 6 0 8 10 t [s] t [s] Fig. 1 Surge overload current IFSM: Crest value, t: duration 0 50 100 150 200 TC [°C] Fig. 2a Maximum forward current Fig. 2 I2dt versus time (1-10 ms) at case temperature 600 RthJA [K/W] 0.3 500 0.4 0.5 400 0.6 PT 0.8 300 1.0 [W] 1.4 DC 180° sin. 120° rect. 60° rect. 30° rect. 200 100 0 0 100 200 1.8 300 0 50 100 150 200 TA [°C] TFAVM [A] Fig. 3 Power dissipation vs. forward current and ambient temperature (per diode) 2000 RthJA [K/W] 0.06 0.08 1500 R 0.10 L PT 0.15 0.20 1000 0.30 [W] 0.40 Circuit B2 2x MDD220 500 0.50 R = resistive load L = inductive load 0 0 200 400 TDAVM [A] 600 0 50 100 150 200 TA [°C] Fig. 4 Single phase rectifier bridge: Power dissipation vs. direct output current and ambient IXYS reserves the right to change limits, test conditions and dimensions. © 2015 IXYS All rights reserved 20150910a 3-4 MDD 220 2500 RthJA [K/W] 0.03 2000 0.05 0.06 0.08 1500 0.12 0.15 1000 0.20 0 0.30 Circuit B6 3x MDD220 500 0 200 400 0 600 50 100 150 200 Fig. 5 Three phase rectifier bridge: Power dissipation versus direct  output current and ambient temperature 0.14 RthJC for various conduction angles d: 30° DC 0.12 DC 180° 120° 60° 30° 0.10 0.08 0.129 0.131 0.132 0.132 0.133 0.06 Constants for ZthJC calculation: 0.04 0.02 0.00 10-3 10-2 10-1 100 101 1 2 3 0.0035 0.0165 01091 0.0099 0.168 0.456 Fig. 6 Transient thermal impedance junction to case (per diode) 0.20 RthJK for various conduction angles d: 30° 0.16 DC 180° 120° 60° 30° DC 0.12 0.169 0.171 0.172 0.172 0.173 0.08 Constants for ZthJK calculation: 0.04 1 2 3 4 0.00 10-3 10-2 10-1 100 101 0.0035 0.0165 0.1091 0.04 0.0099 0.168 0.456 1.36 Fig. 7 Transient thermal impedance junction to heatsink (per diode) IXYS reserves the right to change limits, test conditions and dimensions. © 2015 IXYS All rights reserved 20150910a 4-4
MDD220-12N1 价格&库存
很抱歉,暂时无法提供与“MDD220-12N1”相匹配的价格&库存,您可以联系我们找货
