MDD312-12N1
MDD312-12N1
    IXYSCORPORATION
    Y1-CU
    Diode Array 1 Pair Series Connection Standard 1200V (1.2kV) 310A Chassis Mount Y1-CU
MDD312-12N1 数据手册
Contents Page General Contents Certified Management Systems Alphanumeric Index Symbols and Terms Nomenclature I II III XVII XIX IXYS New Packages 1 ISOPLUS™ family ISOPLUS-SMPD™ ISOPLUS-DIL™ ISOPLUS i4-PAC™ 4 5 10 11 IGBT Discretes 600V / 650V & 900V & 1200V XPT NPT IGBTs / G-Series PT IGBT‘s High Voltage Types 1700V up to 4500 V BiMOSFETs 1600V up to 3600 V 14 16 21 23 25 IGBT Modules CBI Modules Six-Packs Multi Level, CBI and 6-Pack in MiniPack2B Housing Half Bridge and Boost Modules in SimBUS F Housing Full Bridge and Solar Inverter Modules Half Bridge and Buck / Boost in 34 mm and 62 mm wide Modules 27 27 29 31 32 33 34 Power MOSFETs Trench MOSFETs / HiPerFETs (Fast Body Diode) TrenchT2™ MOSFETs / HiPerFETs (FBD) Polar™ MOSFETs / HiPerFETs (FBD) PolarP2™ MOSFETs / HiPerFETs (FBD) PolarP3™ HiPerFETs (FBD) X-Class Power MOSFETs and SiC MOSFETs Q3-Class HiPerFET (Fast Body Diode) Very High Voltage (up to 4500 V) / Legacy MOSFETs LinearL2™ Power MOSFETs Depletion-Mode MOSFETs PolarP™ and TrenchP™ P-channel MOSFETs CoolMOS™ MOSFET Modules Power Factor Correction Modules 35 37 39 41 47 47 49 50 51 52 53 54 56 57 58 Diodes 59 Schottky Gen2 Diodes 60 Schottky Diodes 62 Silicon Carbide Schottky Diodes 63 HiPerDyn™ FREDs & Dual Ultrafast Diodes 63 HiPerFRED2™ & HiPerFRED™ Diodes 64 Sonic-FRDs™ Diodes 66 FRED Diodes 67 FRED & HiPerFRED™ Modules & Semifast Diodes 68 Rectifier & Avalanche Types 69 Studs: Rectifier & Avalanche Diodes & Thyristors 71 Rectifier Diode Modules 75, 138 Page Thyristors Discretes Phase Control Thyristors Thyristor / Diode Modules Thyristor Modules Accessories & Design Information 72 78, 137 81, 136 85 Rectifier Bridges Rectifier Bridges with Fast Diodes 1~ Rectifier Bridges 1~ Rectifier Bridges, half controlled 3~ Rectifier Bridges 3~ Rectifier Bridges with Brake Unit 3~ Rectifier Bridges, half controlled AC Controller / Triac 1~ / 3~ High Voltage Rectifiers Braking Rectifier Assemblies 86 87 88 89 92 93 94 95 95 Protection Devices Break-over Diodes (BOD) Fast Break-over Diodes (BOD) 96 98 IXYS ICD Gate Drivers & Power Relays 99 IXYS UK Application Notes & Technical Information 107 Rectifier Diodes Fast Recovery Diodes Soft Recovery Diodes Extra Fast Recovery Diodes High Power Sonic FRD‘s Phase Control Thyristors Medium Voltage Thyristors Fast Turn-Off Thyristors Distributed Gate Thyristors Asymmetric and Pulse Thyristors GTOs Insulated Gate Bi-polar Transistors - Press-Pack IGBTs Press-Pack IGBT Gate Drive Units Dual Thyristor /Single Thyristor Modules Thyristor / Diode Modules Dual & Single Diode Modules Water Cooled Diode & Thyristor Modules Power Semiconductor Assemblies Westack - Modular Solutions WestackLITE - Modular Solutions Power Semiconductor Accessories Bar Clamps / Box Clamps Coolers / Heatsinks Snubber Capacitors / DC Link Capacitors 108 112 113 116 117 118 123 125 127 132 133 134 135 136 137 138 140 141 144 146 148 149 155 157 Power Semiconductor Chips @ DCB Ceramic Substrates 159 Application Notes Highlights Outline Drawings IXYS UK IXYS Sales Representatives and Distributors: See „Sales Offices“ at 160 O-01 O-31 www.ixys.com I Certified Management Systems Certificates '19 %86,1(66 $6685$1&( 0$1$*(0(1760.5 27 max. min. 0.8 6.1 3 4.1 A A Ø2 M6 ¼“-28 UNF SW 17 13 10 max. 1.6 ¼“-28 UNF X251 UGE-single Weight = 125 g 15.7 X252 UG Weight = 155 g X253a UG b: w/o middle terminal Weight = 310 g c f c h g k i e f g d e Ø 55 Ø 16 M8 23 5.5 8 2 d 5.5 A b a 34 b a red/rot ~ ~ ~ + ~ ~ 5 24 + 5 24 K M8 Type a b c d e UGB 3132 AD 80 70 57 58.5 260 f 6 UGB 6124 AG 135 125 112 58.5 260 11 UGD 6123 AG 135 125 112 58.5 260 8 UGD 8124 AG 135 125 112 58.5 260 8 g h i 15 15 15 k 32.5 25 32.5 30 18 18 30 30 18 18 30 Dimensions in mm O-51 Outline drawings Dimensions in mm and inches (1 mm = 0.0394“) X254 VG-A Weight = 61 g 34 X255 VG-B Weight = 87 g X256 VG-C Weight = 50 g M 2.5x6 4 19 4.5 6 5 3.5 7.5 25 O-52 ~ + + 4 49 57 _ 33 ~ + ~ 18 0.8x43 D5 DE475 7 ~ 2 15 46 38 1 7 4 ~ 22 ~ 38 3 5 4 220 25.5 7 17 24.5 M 4x4
MDD312-12N1 价格&库存
很抱歉,暂时无法提供与“MDD312-12N1”相匹配的价格&库存,您可以联系我们找货
