DSSK18-0025B
DSSK18-0025B
    IXYSCORPORATION
    TO220
    DIODE ARRAY SCHOTTKY 25V TO220AB
DSSK18-0025B 数据手册
DSSK18-0025BS preliminary Schottky Diode VRRM = 25 V I FAV = 2x 10 A VF = 0.37 V High Performance Schottky Diode Low Loss and Soft Recovery Common Cathode Part number DSSK18-0025BS Marking on Product: DSSK18-0025BS Backside: cathode 1 2 3 Features / Advantages: Applications: Package: TO-263 (D2Pak) ● Very low Vf ● Extremely low switching losses ● Low Irm values ● Improved thermal behaviour ● High reliability circuit operation ● Low voltage peaks for reduced protection circuits ● Low noise switching ● Rectifiers in switch mode power supplies (SMPS) ● Free wheeling diode in low voltage converters ● Industry standard outline ● RoHS compliant ● Epoxy meets UL 94V-0 Disclaimer Notice Information furnished is believed to be accurate and reliable. However, users should independently evaluate the suitability of and test each product selected for their own applications. Littelfuse products are not designed for, and may not be used in, all applications. Read complete Disclaimer Notice at www.littelfuse.com/disclaimer-electronics. IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved Data according to IEC 60747and per semiconductor unless otherwise specified 20190222a DSSK18-0025BS preliminary Ratings Schottky Conditions Symbol VRSM Definition max. non-repetitive reverse blocking voltage TVJ = 25°C VRRM max. repetitive reverse blocking voltage TVJ = 25°C 25 V IR reverse current, drain current VF forward voltage drop I FAV average forward current VF0 threshold voltage rF slope resistance R thJC thermal resistance junction to case min. VR = 25 V TVJ = 25°C 10 mA 25 V TVJ = 100°C 40 mA TVJ = 25°C 0.45 V 0.56 V 0.37 V IF = 10 A IF = 20 A IF = 10 A IF = 20 A TVJ = 125 °C TC = 140 °C 0.51 V T VJ = 150 °C 10 A TVJ = 150 °C 0.20 V 14.6 mΩ d = 0.5 for power loss calculation only 1.7 K/W R thCH thermal resistance case to heatsink Ptot total power dissipation I FSM max. forward surge current t = 10 ms; (50 Hz), sine; VR = 0 V TVJ = 45°C CJ junction capacitance VR = TVJ = 25°C © 2019 IXYS all rights reserved max. Unit 25 V VR = rectangular IXYS reserves the right to change limits, conditions and dimensions. typ. K/W 0.25 TC = 25°C 5 V f = 1 MHz 75 140 639 Data according to IEC 60747and per semiconductor unless otherwise specified W A pF 20190222a DSSK18-0025BS preliminary Package Ratings TO-263 (D2Pak) Symbol I RMS Definition Conditions RMS current per terminal min. TVJ virtual junction temperature T op operation temperature Tstg storage temperature -55 typ. max. 35 Unit A -55 150 °C -55 125 °C 150 °C 1.5 Weight FC 20 mounting force with clip g 60 N Product Marking XXXXXXXXX Part Number IXYS yywwZ Logo Date Code Location 123456 Lot# Ordering Standard Alternative Ordering Number DSSK18-0025BS-TRL DSSK18-0025BS-TUB Similar Part DSB30C30PB Equivalent Circuits for Simulation I V0 R0 Marking on Product DSSK18-0025BS DSSK18-0025BS Package TO-220AB (3) * on die level Delivery Mode Tape & Reel Tube Code No. 499099 523741 Voltage class 30 T VJ = 150°C Schottky V 0 max threshold voltage 0.2 V R0 max slope resistance * 11.4 mΩ IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved Quantity 800 50 Data according to IEC 60747and per semiconductor unless otherwise specified 20190222a DSSK18-0025BS preliminary Outlines TO-263 (D2Pak) Dim. W A A1 H D E Supplier Option D1 L1 c2 4 L L2 1 2 3 c 2x e 3x b2 10.92 (0.430) E1 W Inches min max 0.160 0.190 typ. 0.004 0.095 0.020 0.039 0.045 0.055 0.016 0.029 0.045 0.055 0.330 0.370 0.315 0.350 0.098 0.380 0.410 0.245 0.335 0,100 BSC 0.169 0.575 0.625 0.070 0.110 0.040 0.066 typ. 0.002 0.0008 All dimensions conform with and/or within JEDEC standard. 1.78 (0.07) 3.05 (0.120) 3.81 (0.150) 9.02 (0.355) mm (Inches) 2x b A A1 A2 b b2 c c2 D D1 D2 E E1 e e1 H L L1 Millimeter min max 4.06 4.83 typ. 0.10 2.41 0.51 0.99 1.14 1.40 0.40 0.74 1.14 1.40 8.38 9.40 8.00 8.89 2.5 9.65 10.41 6.22 8.50 2,54 BSC 4.28 14.61 15.88 1.78 2.79 1.02 1.68 typ. 0.040 0.02 2.54 (0.100) Recommended min. foot print 1 IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved 2 3 Data according to IEC 60747and per semiconductor unless otherwise specified 20190222a
DSSK18-0025B 价格&库存
很抱歉,暂时无法提供与“DSSK18-0025B”相匹配的价格&库存,您可以联系我们找货
