GBPC2508T
GBPC2508T
    GENESICSEMICONDUCTOR
    GBPC
    GBPC2508T
GBPC2508T 数据手册
GBPC2506T/W thru GBPC2510T/W Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 600 V - 1000 V IO = 25 A Features • Integrally molded heat sink provides low thermal resistance for maximum heat dissipation • High surge current capability • Universal 3-way terminals: snap on, wire-around, or P.C board mounting • High temperature soldering guaranteed: 260⁰C/ 10 seconds at 5 lbs (2.3 kg) tension • Not ESD Sensitive GBPC-T/W Package Mechanical Data Case: Molded plastic with heat sink integrally mounted in the bridge encapsulation Terminals: Either nickel plated 0.25". Faston lugs or copper leads 0.040" diameter. Polarity: Polarrity symbols marked on the body Mounting position: Bolt down on heat-sink with silicone thermal compound between bridge and mounting surface Weight: 15 grams or 0.53 ounces Mounting torque: 20 inch-lbs max Maximum ratings at Tc = 25 °C, unless otherwise specified (GBPCXXXXT uses GBPC-T package while GBPCXXXXW uses GBPC-W package) Parameter Symbol Conditions GBPC2506T/W GBPC2508T/W GBPC2510T/W Unit 600 800 1000 V V Repetitive peak reverse voltage VRRM RMS reverse voltage VRMS 420 560 700 DC blocking voltage Operating temperature Storage temperature VDC Tj Tstg 600 -55 to 150 -55 to 150 800 -55 to 150 -55 to 150 1000 -55 to 150 -55 to 150 V °C °C Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load For capacitive load derate current by 20% Parameter Maximum average forward rectified current Peak forward surge current Maximum instantaneous forward voltage drop per leg Maximum DC reverse current at rated DC blocking voltage per leg Rating for fusing RMS isolation voltage from case to leads Typical junction capacitance Typical thermal resistance Oct. 2018 Conditions GBPC2506T/W GBPC2508T/W GBPC2510T/W Unit IO Tc = 50 °C 25.0 25.0 25.0 A IFSM single sine-wave 300 300 300 A VF IF = 12.5 A 1.1 1.1 1.1 V Symbol Ta = 25 °C 5 5 5 Ta = 125 °C 500 375 500 375 500 375 A sec VISO 2500 2500 2500 V Cj 300 300 300 pF RΘJC 1.9 1.9 1.9 °C/W IR 2 It 1 ms < tm < 8.3 ms http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbpc2508tw.pdf μA 2 1 GBPC2506T/W thru GBPC2510T/W Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbpc2508tw.pdf 2 GBPC2506T/W thru GBPC2510T/W Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbpc2508tw.pdf 3 GBPC2506T/W thru GBPC2510T/W Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Dimensions in inches and (millimeters) Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbpc2508tw.pdf 4
GBPC2508T 价格&库存
很抱歉,暂时无法提供与“GBPC2508T”相匹配的价格&库存,您可以联系我们找货
GBPC2508T
    • 1+39.39840
    • 200+15.72480
    • 500+15.19560
    • 1000+14.93640
