DB103G
DB103G
    GENESICSEMICONDUCTOR
    DIP4
    DB103G
DB103G 数据手册
DB101G thru DB104G Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 50 V - 400 V IO = 1 A Features • Ideal for printed circuit board • Reliable low cost construction utilizing molded plastic technique • High surge current capability • Small size, simple installation • Types from 50 V up to 400 V VRRM DB Package • Not ESD Sensitive Mechanical Data Case: Molded plastic Terminals: Plated terminals, solderable per MIL-STD202, Method 208 Polarity: Polarrity symbols marked on the body Mounting position: Any Maximum ratings at Tc = 25 °C, unless otherwise specified DB101G DB102G DB103G DB104G Unit VRRM 50 100 200 400 V VRMS 35 70 140 280 V VDC Tj Tstg 50 -55 to 150 -55 to 150 100 -55 to 150 -55 to 150 200 -55 to 150 -55 to 150 400 -55 to 150 -55 to 150 V °C °C Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Operating temperature Storage temperature Conditions Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load For capacitive load derate current by 20% Parameter Symbol Conditions DB101G DB102G DB103G DB104G Unit Maximum average forward rectified current IO Ta = 40 °C 1.0 1.0 1.0 1.0 A Peak forward surge current IFSM tp = 8.3 ms, half sine 30 30 30 30 A Maximum instantaneous forward voltage drop VF IF = 1.0 A 1.1 1.1 1.1 1.1 V Maximum DC reverse current at rated DC blocking voltage IR Ta = 25 °C 5 5 5 5 Ta = 125 °C Typical junction capacitance Cj 500 25 500 25 500 25 500 25 RΘJC 20 20 20 20 Typical thermal resistance Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db103g.pdf μA pF °C/W 1 DB101G thru DB104G Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db103g.pdf 2 DB101G thru DB104G Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Dimensions in inches and (millimeters) Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db103g.pdf 3
DB103G 价格&库存
很抱歉,暂时无法提供与“DB103G”相匹配的价格&库存,您可以联系我们找货
DB103G
  • 1+7.428401+0.94610
  • 10+4.6180010+0.58820
  • 25+3.6617025+0.46640
  • 100+2.98540100+0.38020
  • 250+2.97370250+0.37870
  • 500+2.32070500+0.29560
  • 1000+2.099101000+0.26730
  • 2500+1.947502500+0.24800
库存:5853
