BR805 thru BR84
Single Phase Silicon
Bridge Rectifier
VRRM = 50 V - 400 V
IO = 8 A
Features
• Low forward voltage drop
• Low leakage current
• Types from 50 V up to 400 V VRRM
• Not ESD Sensitive
BR-8 Package
Mechanical Data
Mounting: Hole thru for #6 screw
Mounting position: Any
Maximum ratings at Tc = 25 °C, unless otherwise specified
BR805
BR81
BR82
BR84
Unit
VRRM
50
100
200
400
V
RMS reverse voltage
VRMS
35
70
140
280
V
DC blocking voltage
Operating temperature
Storage temperature
VDC
Tj
Tstg
50
-65 to 125
-65 to 150
100
-65 to 125
-65 to 150
200
-65 to 125
-65 to 150
400
-65 to 125
-65 to 150
V
°C
°C
Parameter
Symbol
Repetitive peak reverse voltage
Conditions
Electrical characteristics at Tc = 25 °C, unless otherwise specified
Single phase, half sine wave, 60 Hz, resistive or inductive load
For capacitive load derate current by 20%
Parameter
Symbol
Conditions
BR805
BR81
BR82
BR84
Unit
Maximum average forward
rectified current
IO
Tc = 50 °C
8.0
8.0
8.0
8.0
A
Peak forward surge current
IFSM
tp = 8.3 ms, half sine
250
250
250
250
A
Maximum instantaneous
forward voltage drop per bridge
element
VF
IF = 4.0 A
1.1
1.1
1.1
1.1
V
Maximum DC reverse current at
rated DC blocking voltage
IR
Ta = 25 °C
10
10
10
10
Ta = 100 °C
200
200
200
200
Oct. 2018
http://www.diodemodule.com/silicon_products/bridge_rectifiers/br81.pdf
μA
1
BR805 thru BR84
Oct. 2018
2
BR805 thru BR84
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
Dimensions in inches and (millimeters)
Oct. 2018
3
很抱歉,暂时无法提供与“BR81”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+24.576531+3.17935
- 10+15.8331010+2.04826
- 200+9.81950200+1.27031
- 600+8.51806600+1.10194
- 1000+8.024381000+1.03808
- 2000+7.447862000+0.96350
- 5000+6.824325000+0.88283
- 10000+6.5640310000+0.84916
