GBU10A thru GBU10G
Single Phase Glass Passivated
Silicon Bridge Rectifier
VRRM = 50 V - 400 V
IO = 10 A
Features
• Epoxy Resin material compliant with 94V-0 standards
of UL UL Material Flammability Provisions
• Compliant with UL Provisions, UL Code: E303851
• Ideal for printed circuit boards
• High surge overload rating
• High temperature soldering guaranteed: 260⁰C/ 10 seconds,
9.5 mm lead length
GBU Package
• Not ESD Sensitive
Mechanical Data
• Case: Epoxy resin body over passivated junctions
• Weight: 4.60 g
• Mounting position: Any
Maximum ratings at TA = 25 °C, unless otherwise specified
Parameter
Symbol
Conditions
GBU10A
GBU10B
GBU10D
GBU10G
Unit
Repetitive peak reverse voltage
VRRM
50
100
200
400
V
RMS reverse voltage
DC blocking voltage
Operating temperature
Storage temperature
VRMS
VDC
Tj
Tstg
35
50
-40 to 150
-40 to 150
70
100
-40 to 150
-40 to 150
140
200
-40 to 150
-40 to 150
280
400
-40 to 150
-40 to 150
V
V
°C
°C
Unit
Electrical characteristics at TA = 25 °C, unless otherwise specified
Single phase, half sine wave, 50 Hz, resistive load
For capacitive load derate current by 20%
Parameter
Symbol
IO
Maximum forward rectified current
IFSM
VF
Peak forward surge current
Maximum forward voltage drop
Maximum reverse current at rated DC
blocking voltage
IR
Insulation strength (lead wire to case)
Vdis
Rating for fusing at Tj = 25 C
I2 t
RΘJA
Typical thermal resistance
Conditions
GBU10A
GBU10B
GBU10D
GBU10G
TC = 100 °C
10 (1)
10 (1)
10 (1)
10 (1)
(2)
(2)
(2)
tp = 10 ms, Tj = 25 °C
3.5
225
3.5
225
3.5
225
3.5 (2)
225
IF = 5 A
1.05
1.05
1.05
1.05
TA = 25 °C
A
V
TA = 25 °C
5
5
5
5
TA = 125 °C
500
500
500
500
2.5
2.5
2.5
2.5
kV
80
80
80
80
A2s
AC voltage: 1 min
leakage current
很抱歉,暂时无法提供与“GBU10D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+18.490481+2.39097
