DB101G thru DB104G
Single Phase Glass Passivated
Silicon Bridge Rectifier
VRRM = 50 V - 400 V
IO = 1 A
Features
• Ideal for printed circuit board
• Reliable low cost construction utilizing molded
plastic technique
• High surge current capability
• Small size, simple installation
• Types from 50 V up to 400 V VRRM
DB Package
• Not ESD Sensitive
Mechanical Data
Case: Molded plastic
Terminals: Plated terminals, solderable per MIL-STD202, Method 208
Polarity: Polarrity symbols marked on the body
Mounting position: Any
Maximum ratings at Tc = 25 °C, unless otherwise specified
DB101G
DB102G
DB103G
DB104G
Unit
VRRM
50
100
200
400
V
VRMS
35
70
140
280
V
VDC
Tj
Tstg
50
-55 to 150
-55 to 150
100
-55 to 150
-55 to 150
200
-55 to 150
-55 to 150
400
-55 to 150
-55 to 150
V
°C
°C
Parameter
Symbol
Repetitive peak reverse voltage
RMS reverse voltage
DC blocking voltage
Operating temperature
Storage temperature
Conditions
Electrical characteristics at Tc = 25 °C, unless otherwise specified
Single phase, half sine wave, 60 Hz, resistive or inductive load
For capacitive load derate current by 20%
Parameter
Symbol
Conditions
DB101G
DB102G
DB103G
DB104G
Unit
Maximum average forward
rectified current
IO
Ta = 40 °C
1.0
1.0
1.0
1.0
A
Peak forward surge current
IFSM
tp = 8.3 ms, half sine
30
30
30
30
A
Maximum instantaneous
forward voltage drop
VF
IF = 1.0 A
1.1
1.1
1.1
1.1
V
Maximum DC reverse current at
rated DC blocking voltage
IR
Ta = 25 °C
5
5
5
5
Ta = 125 °C
Typical junction capacitance
Cj
500
25
500
25
500
25
500
25
RΘJC
Typical thermal resistance
Oct. 2018
http://www.diodemodule.com/silicon_products/bridge_rectifiers/db104g.pdf
μA
pF
°C/W
1
DB101G thru DB104G
Oct. 2018
2
DB101G thru DB104G
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
Dimensions in inches and (millimeters)
Oct. 2018
3
很抱歉,暂时无法提供与“DB104G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.286651+1.07341
