DB107G
DB107G
    GENESICSEMICONDUCTOR
    DIP4
    DB107G
DB107G 数据手册
DB105G thru DB107G Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 600 V - 1000 V IO = 1 A Features • Ideal for printed circuit board • Reliable low cost construction utilizing molded plastic technique • High surge current capability • Small size, simple installation • Types from 600 V up to 1000 V VRRM DB Package • Not ESD Sensitive Mechanical Data Case: Molded plastic Terminals: Plated terminals, solderable per MIL-STD202, Method 208 Polarity: Polarrity symbols marked on the body Mounting position: Any Maximum ratings at Tc = 25 °C, unless otherwise specified Parameter Symbol Conditions DB105G DB106G DB107G Unit Repetitive peak reverse voltage VRRM 600 800 1000 V RMS reverse voltage VRMS 420 560 700 V DC blocking voltage Operating temperature Storage temperature VDC Tj Tstg 800 -55 to 150 -55 to 150 1000 -55 to 150 -55 to 150 V °C °C 600 -55 to 150 -55 to 150 Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load For capacitive load derate current by 20% Parameter Symbol Conditions DB105G DB106G DB107G Unit Maximum average forward rectified current IO Ta = 40 °C 1.0 1.0 1.0 A Peak forward surge current IFSM tp = 8.3 ms, half sine 30 30 30 A Maximum instantaneous forward voltage drop VF IF = 1.0 A 1.1 1.1 1.1 V Maximum DC reverse current at rated DC blocking voltage IR Typical junction capacitance Typical thermal resistance Oct. 2018 Cj RΘJC Ta = 25 °C 5 5 5 Ta = 125 °C 500 25 20 500 25 20 500 25 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db107g.pdf 20 μA pF °C/W 1 DB105G thru DB107G Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db107g.pdf 2 DB105G thru DB107G Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Dimensions in inches and (millimeters) Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db107g.pdf 3
DB107G 价格&库存
很抱歉,暂时无法提供与“DB107G”相匹配的价格&库存,您可以联系我们找货
