DB151G
DB151G
    GENESICSEMICONDUCTOR
    DIP4
    Bridge Rectifier Single Phase 50V 1.5A Through Hole DB
DB151G 数据手册
DB151G thru DB154G Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 50 V - 400 V IO = 1.5 A Features • Ideal for printed circuit board • Reliable low cost construction utilizing molded plastic technique • High surge current capability • Small size, simple installation • Types from 50 V up to 400 V VRRM DB Package • Not ESD Sensitive Mechanical Data Case: Molded plastic Terminals: Plated terminals, solderable per MIL-STD202, Method 208 Polarity: Polarrity symbols marked on the body Mounting position: Any Maximum ratings at Tc = 25 °C, unless otherwise specified DB151G DB152G DB153G DB154G Unit VRRM 50 100 200 400 V VRMS 35 70 140 280 V VDC Tj Tstg 50 -55 to 150 -55 to 150 100 -55 to 150 -55 to 150 200 -55 to 150 -55 to 150 400 -55 to 150 -55 to 150 V °C °C Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Operating temperature Storage temperature Conditions Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load For capacitive load derate current by 20% Parameter Symbol Conditions DB151G DB152G DB153G DB154G Unit Maximum average forward rectified current IO Ta = 40 °C 1.5 1.5 1.5 1.5 A Peak forward surge current IFSM tp = 8.3 ms, half sine 50 50 50 50 A Maximum instantaneous forward voltage drop VF IF = 1.5 A 1.1 1.1 1.1 1.1 V Maximum DC reverse current at rated DC blocking voltage IR Ta = 25 °C 5 5 5 5 Ta = 125 °C Rating for fusing I2 t 500 10 500 10 Cj 14 14 500 10 14 A2sec Typical junction capacitance 500 10 14 36 °C/W Typical thermal resistance Oct. 2018 RΘJA t < 8.3 ms 36 36 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db151g.pdf 36 μA pF 1 DB151G thru DB154G Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db151g.pdf 2 DB151G thru DB154G Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Dimensions in inches and (millimeters) Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/db151g.pdf 3
DB151G 价格&库存
很抱歉,暂时无法提供与“DB151G”相匹配的价格&库存,您可以联系我们找货
DB151G
    • 1+3.66120
    • 200+1.46880
    • 500+1.41480
    • 1000+1.39320
