DB151G thru DB154G
Single Phase Glass Passivated
Silicon Bridge Rectifier
VRRM = 50 V - 400 V
IO = 1.5 A
Features
• Ideal for printed circuit board
• Reliable low cost construction utilizing molded
plastic technique
• High surge current capability
• Small size, simple installation
• Types from 50 V up to 400 V VRRM
DB Package
• Not ESD Sensitive
Mechanical Data
Case: Molded plastic
Terminals: Plated terminals, solderable per MIL-STD202, Method 208
Polarity: Polarrity symbols marked on the body
Mounting position: Any
Maximum ratings at Tc = 25 °C, unless otherwise specified
DB151G
DB152G
DB153G
DB154G
Unit
VRRM
50
100
200
400
V
VRMS
35
70
140
280
V
VDC
Tj
Tstg
50
-55 to 150
-55 to 150
100
-55 to 150
-55 to 150
200
-55 to 150
-55 to 150
400
-55 to 150
-55 to 150
V
°C
°C
Parameter
Symbol
Repetitive peak reverse voltage
RMS reverse voltage
DC blocking voltage
Operating temperature
Storage temperature
Conditions
Electrical characteristics at Tc = 25 °C, unless otherwise specified
Single phase, half sine wave, 60 Hz, resistive or inductive load
For capacitive load derate current by 20%
Parameter
Symbol
Conditions
DB151G
DB152G
DB153G
DB154G
Unit
Maximum average forward
rectified current
IO
Ta = 40 °C
1.5
1.5
1.5
1.5
A
Peak forward surge current
IFSM
tp = 8.3 ms, half sine
50
50
50
50
A
Maximum instantaneous
forward voltage drop
VF
IF = 1.5 A
1.1
1.1
1.1
1.1
V
Maximum DC reverse current at
rated DC blocking voltage
IR
Ta = 25 °C
5
5
5
5
Ta = 125 °C
Rating for fusing
I2 t
500
10
500
10
Cj
14
14
500
10
14
A2sec
Typical junction capacitance
500
10
14
36
°C/W
Typical thermal resistance
Oct. 2018
RΘJA
t < 8.3 ms
36
36
http://www.diodemodule.com/silicon_products/bridge_rectifiers/db154g.pdf
36
μA
pF
1
DB151G thru DB154G
Oct. 2018
2
DB151G thru DB154G
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
Dimensions in inches and (millimeters)
Oct. 2018
3
很抱歉,暂时无法提供与“DB154G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.231511+1.19913
- 国内价格
- 1+3.66120
- 200+1.46880
- 500+1.41480
- 1000+1.39320
