2W005M thru 2W04M
Single Phase Silicon
Bridge Rectifier
VRRM = 50 V - 400 V
IO = 2 A
Features
• Ideal for printed circuit board
• Low forward voltage drop
WOM Package
• Low leakage current
• High temperature soldering guaranteed: 250⁰C/ 10
seconds, 0.375" lead length, .5 lbs (2.3kg) tension
• Types from 50 V up to 400 V VRRM
• Not ESD Sensitive
Mechanical Data
Case: Molded plastic body
Terminals: Plated leads, solderable per MIL-STD-202
Method 208 guaranteed
Polarity: Color band on body denotes cathode end
Mounting position: Any
Weight: 1.1 grams
Maximum ratings at Tc = 25 °C, unless otherwise specified
2W005M
2W01M
2W02M
2W04M
U it
Unit
VRRM
50
100
200
400
V
RMS reverse voltage
VRMS
35
70
140
280
V
DC blocking voltage
Operating temperature
Storage temperature
VDC
Tj
Tstg
50
-65 to 125
-65 to 150
100
-65 to 125
-65 to 150
200
-65 to 125
-65 to 150
400
-65 to 125
-65 to 150
V
°C
°C
P
Parameter
t
S b l
Symbol
Repetitive peak reverse voltage
Conditions
Electrical characteristics at Tc = 25 °C, unless otherwise specified
Single phase, half sine wave, 60 Hz, resistive or inductive load
For capacitive load derate current by 20%
Parameter
Symbol
Conditions
2W005M
2W01M
2W02M
2W04M
Unit
Maximum average forward
rectified current
IO
Ta = 50 °C
2
2
2
2
A
Peak forward surge current
IFSM
tp = 8.3 ms, half sine
60
60
60
60
A
Maximum instantaneous
forward voltage drop per bridge
element
VF
IF = 2 A
1.1
1.1
1.1
1.1
V
Maximum DC reverse current at
rated DC blocking voltage
IR
www.genesicsemi.com/silicon-products/bridge-rectifiers/
Ta = 25 °C
10
10
10
10
Ta= 100 °C
500
500
500
500
1
μA
2W005M thru 2W04M
2
2W005M thru 2W04M
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
Di
Dimensions
i
iin iinches
h and
d ((millimeters)
illi t )
3
很抱歉,暂时无法提供与“2W005M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+2.822822000+0.36567
