BR36 thru BR310
Single Phase Glass Passivated Silicon
Bridge Rectifier
VRRM = 600 V - 1000 V
IO = 3 A
Features
• Low forward voltage
• High surge overload rating
• Ideal for printed circuit boards
• High temperature soldering: 260⁰C/ 10 s
• Types from 600 V up to 1000 V VRRM
BR-3 Package
• Not ESD Sensitive
Applications
• Switching power supply
• Home appliances, office devices
• Industrial auto-equipments
Maximum ratings at TA = 25 °C, unless otherwise specified
Parameter
Symbol
Conditions
BR36
BR38
BR310
Unit
Repetitive peak reverse voltage
VRRM
600
800
1000
V
RMS reverse voltage
DC blocking voltage
Operating temperature
Storage temperature
VRMS
VDC
Tj
Tstg
420
600
-40 to 125
-40 to 150
560
800
-40 to 125
-40 to 150
700
1000
-40 to 125
-40 to 150
V
V
°C
°C
Conditions
BR36
BR38
BR310
Unit
IO
TC = 40 °C
3
3
3
A
IFSM
VF
tp = 8.3 ms
IF = 1.5 A
60
1.05
60
1.05
60
1.05
A
V
TA = 25 °C
10
10
10
TA = 125 °C
500
500
500
15
15
15
A2s
18
18
°C/W
2.0 (1.0 N.m is recommended)
N.m
Electrical characteristics at TA = 25 °C, unless otherwise specified
Single phase, half sine wave, 50 Hz, resistive load
For capacitive load derate current by 20%
Parameter
Maximum forward rectified current
Peak forward surge current
Maximum forward voltage drop
Symbol
Maximum reverse current at rated DC
blocking voltage
IR
Rating for fusing
I2 t
Thermal resistance
Mounting Torque
Oct. 2018
RΘJA
M
1 ms < tp < 10 ms,
= 25 °C
Tj
18
http://www.diodemodule.com/silicon_products/bridge_rectifiers/br36.pdf
μA
1
BR36 thru BR310
Oct. 2018
2
BR36 thru BR310
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
BR-3
Dimensions in inches and (millimeters)
Oct. 2018
3
很抱歉,暂时无法提供与“BR36”相匹配的价格&库存,您可以联系我们找货
