BR305 thru BR34
Single Phase Glass Passivated
Silicon Bridge Rectifier
VRRM = 50 V - 400 V
IO = 3 A
Features
• Low forward voltage
• High surge overload rating
• Ideal for printed circuit boards
• High temperature soldering: 260⁰C/ 10 s
• Types from 50 V up to 400 V VRRM
BR-3 Package
• Not ESD Sensitive
Applications
• Switching power supply
• Home appliances, office devices
• Industrial auto-equipments
Maximum ratings at TA = 25 °C, unless otherwise specified
Parameter
Symbol
Conditions
BR305
BR31
BR32
BR34
Unit
Repetitive peak reverse voltage
VRRM
50
100
200
400
V
RMS reverse voltage
DC blocking voltage
Operating temperature
Storage temperature
VRMS
VDC
Tj
Tstg
35
50
-40 to 125
-40 to 150
70
100
-40 to 125
-40 to 150
140
200
-40 to 125
-40 to 150
280
400
-40 to 125
-40 to 150
V
V
°C
°C
BR32
BR34
Unit
Electrical characteristics at TA = 25 °C, unless otherwise specified
Single phase, half sine wave, 50 Hz, resistive load
For capacitive load derate current by 20%
Parameter
Maximum forward rectified current
Peak forward surge current
Maximum forward voltage drop
Conditions
BR305
BR31
IO
TA = 40 °C
3
3
3
3
A
IFSM
VF
tp = 8.3 ms
IF = 1.5 A
TA = 25 °C
60
1.05
10
60
1.05
10
60
1.05
10
60
1.05
10
A
V
TA = 125 °C
1 ms < tp < 10 ms,
Tj = 25 °C
500
500
500
500
15
15
15
15
A2s
18
18
18
18
°C/W
Symbol
Maximum reverse current at rated DC
blocking voltage
IR
Rating for fusing
I2 t
Thermal resistance
Mounting Torque
Oct. 2018
RΘJA
M
2.0 (1.0 N.m is recommended)
http://www.diodemodule.com/silicon_products/bridge_rectifiers/br34.pdf
μA
N.m
1
BR305 thru BR34
Oct. 2018
2
BR305 thru BR34
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
BR-3
Dimensions in inches and (millimeters)
Oct. 2018
3
很抱歉,暂时无法提供与“BR34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+5.165642000+0.66855
