KBL406G thru KBL410G
Single Phase Glass Passivated
Silicon Bridge Rectifier
VRRM = 600 V - 1000 V
IO = 4 A
Features
• Ideal for printed circuit board
• Reliable low cost construction utilizing molded plastic
technique
• High surge current capability
• Silver plated copper leads
• Types from 50 V to 400 V VRRM
KBL Package
• Not ESD Sensitive
Mechanical Data
Case: Molded plastic
Terminals: Plated terminals, solderable per MIL-STD202F, Method 208
Polarity: Marked on body
Weight: 0.167 ounce, 5 grams
Mounting position: Any
Maximum ratings at Ta = 25 °C (ambient temperature), unless otherwise specified
KBL406G
KBL408G
KBL410G
Unit
VRRM
600
800
1000
V
RMS reverse voltage
VRMS
420
560
700
V
DC blocking voltage
Operating temperature
Storage temperature
VDC
Tj
Tstg
600
-50 to 150
-50 to 150
800
-50 to 150
-50 to 150
1000
-50 to 150
-50 to 150
V
°C
°C
Parameter
Symbol
Repetitive peak reverse voltage
Conditions
Electrical characteristics at Ta = 25 °C, unless otherwise specified
Single phase, half sine wave, 60 Hz, resistive or inductive load
For capacitive load derate current by 20%
Parameter
Symbol
Conditions
KBL406G
KBL408G
KBL410G
Unit
Maximum average forward
rectified current
IO
Ta = 50 °C
4
4
4
A
Peak forward surge current
IFSM
single sine-wave
120
120
120
A
Maximum instantaneous
forward voltage per leg
VF
IF = 4 A
1.1
1.1
1.1
V
Maximum reverse current at
rated DC blocking voltage per
leg
Ta = 25 °C
5
5
5
IR
Ta = 125 °C
100
100
100
Oct. 2018
http://www.diodemodule.com/silicon_products/bridge_rectifiers/kbl406g.pdf
μA
1
Oct. 2018
2
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
Dimensions in inches and (millimeters)
Oct. 2018
3
很抱歉,暂时无法提供与“KBL410G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.16880
- 200+1.62000
- 500+1.55520
- 1000+1.53360
