GBU4J thru GBU4M
Single Phase Glass Passivated Silicon
Bridge Rectifier
VRRM = 600 V -1000 V
IO = 4 A
Features
• Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
• High case dielectric strength of 1500 VRMS
• Glass passivated chip junction
• Ideal for printed circuit boards
• High surge overload rating
GBU Package
• High temperature soldering guaranteed: 260⁰C/ 10
seconds, 0.375 (9.5mm) lead length
• Not ESD Sensitive
Mechanical Data
Case: Molded plastic body over passivated junctions
Terminals: Plated leads, solderable per MIL-STD-750 Method 2026.
Mounting position: Any
Maximum ratings at Tc = 25 °C, unless otherwise specified
Parameter
Symbol
Conditions
GBU4J
GBU4K
GBU4M
Repetitive peak reverse voltage
VRRM
600
800
1000
RMS reverse voltage
VRMS
420
560
700
DC blocking voltage
Operating temperature
Storage temperature
VDC
Tj
Tstg
600
-55 to 150
-55 to 150
800
-55 to 150
-55 to 150
1000
-55 to 150
-55 to 150
Conditions
GBU4J
GBU4K
GBU4M
IO
Tc = 100 °C
4.0
4.0
4.0
IFSM
tp = 8.3 ms, half sine
150
150
150
Maximum instantaneous forward
voltage drop per leg
VF
IF = 4 A
1.1
1.1
1.1
Maximum DC reverse current at
rated DC blocking voltage per leg
IR
Ta = 25 °C
5
5
5
Ta = 125 °C
500
93
500
93
500
93
Cj
45
45
45
RΘJA
RΘJL
22
4.2
22
4.2
4.2
Electrical characteristics at Tc = 25 °C, unless otherwise specified
Single phase, half sine wave, 60 Hz, resistive or inductive load.
For capacitive load derate current by 20%.
Parameter
Symbol
Maximum average forward rectified
current 1,2
Peak forward surge current
I2 t
Rating for fusing
Typical junction capacitance per
leg 3
Typical thermal resistance per leg
1
1,2
t < 8.3 ms
22
- Device mounted on 40 mm x 40 mm x 1.5 mm Al plate heatsink
2
- Recommended mounted position is to bolt down device on a heatsink with silicon thermal
compond for maximum heat transfer using #6 screw.
3
- Measured at 1.0 MHz and applied reverse bias of 4.0 V
Oct. 2018
http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbu4m.pdf
1
GBU4J thru GBU4M
GBU Package
Unit
V
V
V
°C
°C
ified
Unit
A
A
V
μA
A2sec
pF
°C/W
Oct. 2018
2
GBU4J thru GBU4M
Oct. 2018
3
GBU4J thru GBU4M
Oct. 2018
4
GBU4J thru GBU4M
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
Dimensions in inches and (millimeters)
Oct. 2018
5
GBU4J thru GBU4M
Oct. 2018
6
很抱歉,暂时无法提供与“GBU4M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.624801+1.64100
- 10+8.8517010+1.15060
- 25+7.7617025+1.00890
- 100+6.27650100+0.81580
- 250+5.60570250+0.72860
- 500+4.75530500+0.61810
- 1000+4.419901000+0.57450
- 2500+4.312102500+0.56050
