GBL08
GBL08
    GENESICSEMICONDUCTOR
    SIP4
    DIODE BRIDGE 800V 4A GBL
GBL08 数据手册
GBL06 thru GBL10 Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 600 V -1000 V IO = 4 A Features • Plastic package has Underwriters Laboratory Flammability Classification 94V-0 • This series is UL listed under the Recognized • Glass passivated chip junction • High case dielectric strength • Typical IR less than 0,1 A GBL Package • High surge current capability • Ideal for printed circuit boards • Not ESD Sensitive Mechanical Data Case: Molded plastic body over passivated junctions Terminals: Plated leads, solderable per MIL-STD-750 Method 2026. Weight: 0.071 oz, 2.0 g Maximum ratings at Tc = 25 °C, unless otherwise specified Parameter Symbol Conditions GBL06 GBL08 GBL10 Unit 600 800 1000 V V Repetitive peak reverse voltage VRRM RMS reverse voltage VRMS 420 560 700 DC blocking voltage Operating temperature Storage temperature VDC Tj Tstg 600 -55 to 150 -55 to 150 800 -55 to 150 -55 to 150 1000 -55 to 150 -55 to 150 V °C °C Conditions GBL06 GBL08 GBL10 Unit Tc = 50 °C (Note 1) 4.0 4.0 4.0 Tc = 40 °C (Note 2) 3.0 3.0 3.0 IFSM tp = 8.3 ms, half sine 135 135 135 A Maximum instantaneous forward voltage drop per leg VF IF = 4 A 1.1 1.1 1.1 V Maximum DC reverse current at rated DC blocking voltage per leg IR Ta = 25 °C 5 5 5 Ta = 125 °C 500 75 500 75 500 75 A2sec 40 40 40 pF 22 3.5 22 3.5 3.5 Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load. For capacitive load derate current by 20%. Parameter Maximum average forward rectified current Peak forward surge current Rating for fusing Typical junction capacitance per leg (Note 3) Typical thermal resistance per leg Symbol IO I2 t t < 8.3 ms Cj RΘJA RΘJL (Note 1) (Note 2) 1 - Unit mounted on 3.0" x 3.0" x 0.11" (75 mm x 75 mm x 3 mm) Al plate 2 - Unit mounted on P.C.B. At 0.375" (9.5 mm) lead length and 0.5" x 0.5" (12 mm x 12 mm) - Measured at 1.0 MHz and applied reverse bias of 4.0 V 3 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbl08.pdf 22 A μA °C/W 1 GBL06 thru GBL10 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbl08.pdf 2 GBL06 thru GBL10 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Dimensions in inches and (millimeters) Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbl08.pdf 3
GBL08 价格&库存
很抱歉,暂时无法提供与“GBL08”相匹配的价格&库存,您可以联系我们找货
GBL08
  • 1+14.247831+1.84375
