GBL01
GBL01
    GENESICSEMICONDUCTOR
    SIP4
    GBL01
GBL01 数据手册
GBL005 thru GBL04 Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 50 V - 400 V IO = 4 A Features • Plastic package has Underwriters Laboratory Flammability Classification 94V-0 • This series is UL listed under the Recognized • Glass passivated chip junction • High case dielectric strength • Typical IR less than 0,1 A • High surge current capability • Ideal for printed circuit boards GBL Package • Not ESD Sensitive Mechanical Data Case: Molded plastic body over passivated junctions Terminals: Plated leads, solderable per MIL-STD-750 Method 2026. Weight: 0.071 oz, 2.0 g Maximum ratings at Tc = 25 °C, unless otherwise specified Parameter Symbol Conditions GBL005 GBL01 GBL02 GBL04 Unit 50 100 200 400 V 280 V Repetitive peak reverse voltage VRRM RMS reverse voltage VRMS 35 70 140 DC blocking voltage Operating temperature Storage temperature VDC Tj Tstg 50 -55 to 150 -55 to 150 100 -55 to 150 -55 to 150 200 -55 to 150 -55 to 150 400 -55 to 150 -55 to 150 V °C °C Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load For capacitive load derate current by 20% Conditions GBL005 GBL01 GBL02 GBL04 Unit IO Tc = 50 °C (Note 1) Tc = 40 °C (Note 2) 4.0 3.0 4.0 3.0 4.0 3.0 4.0 3.0 A Peak forward surge current IFSM tp = 8.3 ms, half sine 135 135 135 135 A Maximum instantaneous forward voltage drop per leg VF IF = 4 A 1.1 1.1 1.1 1.1 V Maximum DC reverse current at rated DC blocking voltage per leg IR Ta = 25 °C 5 5 5 5 500 75 500 75 500 75 500 75 A sec 95 95 95 95 pF Parameter Maximum average forward rectified current Symbol 2 Rating for fusing It Typical junction capacitance per leg (Note 3) Cj Typical thermal resistance per leg 1 Ta = 125 °C t < 8.3 ms RΘJA (Note 1) 22 22 22 22 RΘJL (Note 2) 3.5 3.5 3.5 3.5 μA 2 °C/W - Unit mounted on 3.0" x 3.0" x 0.11" (75 mm x 75 mm x 3 mm) Al plate 2 - Unit mounted on P.C.B. At 0.375" (9.5 mm) lead length and 0.5" x 0.5" (12 mm x 3 12- Measured mm) copper at pads 1.0 MHz and applied reverse bias of 4.0 V Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbl01.pdf 1 GBL005 thru GBL04 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbl01.pdf 2 GBL005 thru GBL04 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. GBL Dimensions in millimeters Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbl01.pdf 3
GBL01 价格&库存
很抱歉,暂时无法提供与“GBL01”相匹配的价格&库存,您可以联系我们找货
GBL01
  • 8000+26.595988000+3.44527
