GBU6A
GBU6A
    GENESICSEMICONDUCTOR
    SIP4
    RECT BRIDGE GPP 6A 50V GBU
GBU6A 数据手册
GBU6A thru GBU6G Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 50 V - 400 V IO = 6 A Features • Epoxy Resin material compliant with 94V-0 standards of UL UL Material Flammability Provisions • Compliant with UL Provisions, UL Code: E303851 • Ideal for printed circuit boards • High surge overload rating • High temperature soldering guaranteed: 260⁰C/ 10 seconds, 9.5 mm lead length GBU Package • Not ESD Sensitive Mechanical Data • Case: Epoxy resin body over passivated junctions • Weight: 4.60 g • Mounting position: Any Maximum ratings at TA = 25 °C, unless otherwise specified Parameter Symbol Conditions GBU6A GBU6B GBU6D GBU6G Unit Repetitive peak reverse voltage VRRM 50 100 200 400 V RMS reverse voltage DC blocking voltage Operating temperature Storage temperature VRMS VDC Tj Tstg 35 50 -40 to 150 -40 to 150 70 100 -40 to 150 -40 to 150 140 200 -40 to 150 -40 to 150 280 400 -40 to 150 -40 to 150 V V °C °C Unit Electrical characteristics at TA = 25 °C, unless otherwise specified Single phase, half sine wave, 50 Hz, resistive load For capacitive load derate current by 20% Parameter Symbol IO Maximum forward rectified current IFSM VF Peak forward surge current Maximum forward voltage drop Maximum reverse current at rated DC blocking voltage IR Insulation strength (lead wire to case) Vdis Rating for fusing at Tj = 25 C I2 t RΘJA Typical thermal resistance Conditions GBU6A GBU6B GBU6D GBU6G TC = 100 °C 6 (1) 6 (1) 6 (1) 6 (1) tp = 10 ms, Tj = 25 °C IF = 3 A TA = 25 °C 2.8 175 1.05 5 2.8 175 1.05 5 2.8 (2) 175 1.05 5 TA = 125 °C 500 500 500 500 2.5 2.5 2.5 2.5 kV 55 55 55 55 A2s 22 (2) 5.5 (1) 22 (2) 5.5 (1) 22 (2) 5.5 (1) 22 (2) 5.5 (1) °C/W AC voltage: 1 min leakage current
GBU6A 价格&库存
很抱歉,暂时无法提供与“GBU6A”相匹配的价格&库存,您可以联系我们找货
