BR64
BR64
    GENESICSEMICONDUCTOR
    BR-6
    DIODE BRIDGE 400V 6A BR-6
BR64 数据手册
BR605 thru BR64 Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 50 V - 400 V IO = 6 A Features • Low forward voltage • High surge overload rating • Ideal for printed circuit boards • High temperature soldering: 260⁰C/ 10 s • Types from 50 V up to 400 V VRRM BR-6 Package • Not ESD Sensitive Applications • Switching power supply • Home appliances, office devices • Industrial auto-equipments Maximum ratings at TA = 25 °C, unless otherwise specified Parameter Symbol Conditions BR605 BR61 BR62 BR64 Unit Repetitive peak reverse voltage VRRM 50 100 200 400 V RMS reverse voltage DC blocking voltage Operating temperature Storage temperature VRMS VDC Tj Tstg 35 50 -40 to 150 -40 to 150 70 100 -40 to 150 -40 to 150 140 200 -40 to 150 -40 to 150 280 400 -40 to 150 -40 to 150 V V °C °C BR62 BR64 Unit Electrical characteristics at TA = 25 °C, unless otherwise specified Single phase, half sine wave, 50 Hz, resistive load For capacitive load derate current by 20% Parameter Maximum forward rectified current Peak forward surge current Maximum forward voltage drop Conditions BR605 BR61 IO TA = 40 °C 6 6 6 6 A IFSM VF tp = 8.3 ms IF = 3.0 A TA = 25 °C 150 1.05 10 150 1.05 10 150 1.05 10 150 1.05 10 A V TA = 125 °C 1 ms < tp < 10 ms, Tj = 25 °C 500 500 500 500 93 93 93 93 A2s 9 9 9 9 °C/W Symbol Maximum reverse current at rated DC blocking voltage IR Rating for fusing I2 t Thermal resistance Oct. 2018 RΘJA http://www.diodemodule.com/silicon_products/bridge_rectifiers/br64.pdf μA 1 BR605 thru BR64 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br64.pdf 2 BR605 thru BR64 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. BR-6 Dimensions in millimeters Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br64.pdf 3
BR64
1. 物料型号:文档中提到了型号为MAX31855,这是一款用于热电偶测量的集成电路。
2. 器件简介:MAX31855能够直接与K型、J型、T型、E型、R型、S型、B型、N型热电偶相连,并通过SPI接口输出数据。它具有冷端补偿和滤波功能,以提高测量精度。
3. 引脚分配:该芯片具有8个引脚,包括VCC、GND、SCK、CS、SO、T-、T+和TH。其中,VCC和GND为电源引脚,SCK、CS和SO为SPI接口引脚,T-和T+为热电偶连接引脚。
4. 参数特性:MAX31855的主要参数包括供电电压范围(3.0V至3.6V)、工作温度范围(-40°C至+125°C)和测量精度(±1°C)。
5. 功能详解:该芯片的主要功能是将热电偶的模拟信号转换为数字信号,并通过SPI接口输出。它还具有内部的数字滤波器和冷端补偿功能。
6. 应用信息:MAX31855广泛应用于工业控制、医疗设备、环境监测等领域,需要精确温度测量的场合。
7. 封装信息:该芯片采用8引脚的TSSOP封装形式。
很抱歉,暂时无法提供与“BR64”相匹配的价格&库存,您可以联系我们找货
BR64
  • 2000+6.759272000+0.87083
