BR104
BR104
    GENESICSEMICONDUCTOR
    BR10
    DIODE BRIDGE 400V 10A BR-10
BR104 数据手册
BR1005 thru BR104 Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 50 V - 400 V IO = 10 A Features • Low forward voltage • High surge overload rating • Ideal for printed circuit boards • High temperature soldering: 260⁰C/ 10 s • Types from 50 V up to 400 V VRRM BR-10 Package • Not ESD Sensitive Applications • Switching power supply • Home appliances, office devices • Industrial auto-equipments Maximum ratings at TA = 25 °C, unless otherwise specified Parameter Symbol Conditions BR1005 BR101 BR102 BR104 Unit Repetitive peak reverse voltage VRRM 50 100 200 400 V RMS reverse voltage DC blocking voltage Operating temperature Storage temperature VRMS VDC Tj Tstg 35 50 -40 to 150 -40 to 150 70 100 -40 to 150 -40 to 150 140 200 -40 to 150 -40 to 150 280 400 -40 to 150 -40 to 150 V V °C °C BR102 BR104 Unit Electrical characteristics at TA = 25 °C, unless otherwise specified Single phase, half sine wave, 50 Hz, resistive load For capacitive load derate current by 20% Parameter Maximum forward rectified current Peak forward surge current Maximum forward voltage drop Conditions BR1005 BR101 IO TA = 40 °C 10 10 10 10 A IFSM VF tp = 8.3 ms IF = 5.0 A TA = 25 °C 200 1.05 10 200 1.05 10 200 1.05 10 200 1.05 10 A V TA = 125 °C 1 ms < tp < 10 ms, Tj = 25 °C 500 500 500 500 166 166 166 166 A2s 5 5 5 5 °C/W Symbol Maximum reverse current at rated DC blocking voltage IR Rating for fusing I2 t Thermal resistance Oct. 2018 RΘJA http://www.diodemodule.com/silicon_products/bridge_rectifiers/br104.pdf μA 1 BR1005 thru BR104 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br104.pdf 2 BR1005 thru BR104 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. BR-10 Dimensions in millimeters Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br104.pdf 3
BR104 价格&库存
很抱歉,暂时无法提供与“BR104”相匹配的价格&库存,您可以联系我们找货
