BR66
BR66
    GENESICSEMICONDUCTOR
    BR-6
    DIODEBRIDGE600V6ABR-6
BR66 数据手册
BR66 thru BR610 Single Phase Silicon Bridge Rectifier VRRM = 600 V - 1000 V IO = 6 A Features • Ideal for printed circuit board • Low forward voltage drop • Low leakage current • Types from 600 V up to 1000 V VRRM BR-6 Package • Not ESD Sensitive Mechanical Data Case: Molded plastic body Mounting: Hole thru for #6 screw Mounting position: Any Lead: As marked Maximum ratings at Tc = 25 °C, unless otherwise specified Parameter Symbol Conditions BR66 BR68 BR610 Unit 1000 V Repetitive peak reverse voltage VRRM 600 800 RMS reverse voltage VRMS 420 560 700 V DC blocking voltage Operating temperature Storage temperature VDC Tj Tstg 600 -65 to 125 -65 to 150 800 -65 to 125 -65 to 150 1000 -65 to 125 -65 to 150 V °C °C Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load For capacitive load derate current by 20% Parameter Symbol Conditions BR66 BR68 BR610 Unit Maximum average forward rectified current IO Tc = 75 °C 6.0 6.0 6.0 A Peak forward surge current IFSM tp = 8.3 ms, half sine 200 200 200 A Maximum instantaneous forward voltage drop per bridge element VF IF = 3.0 A 1.0 1.0 1.0 V Maximum DC reverse current at rated DC blocking voltage IR Ta = 25 °C 10 10 10 Ta = 100 °C 200 200 200 www.genesicsemi.com/silicon-products/bridge-rectifiers/ 1 μA BR66 thru BR610 www.genesicsemi.com/silicon-products/bridge-rectifiers/ 2 BR66 thru BR610 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Di Dimensions i iin iinches h and d ((millimeters) illi t ) www.genesicsemi.com/silicon-products/bridge-rectifiers/ 3
很抱歉,暂时无法提供与“BR66”相匹配的价格&库存,您可以联系我们找货
