GBU10K
GBU10K
    GENESICSEMICONDUCTOR
    SIP4
    DIODE BRIDGE 800V 10A GBU
GBU10K 数据手册
GBU10J thru GBU10M Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 600 V - 1000 V IO = 10 A Features • Epoxy Resin material compliant with 94V-0 standards of UL UL Material Flammability Provisions • Compliant with UL Provisions, UL Code: E303851 • Ideal for printed circuit boards • High surge overload rating • High temperature soldering guaranteed: 260⁰C/ 10 seconds, 9.5 mm lead length GBU Package • Not ESD Sensitive Mechanical Data • Case: Epoxy resin body over passivated junctions • Weight: 4.60 g • Mounting position: Any Maximum ratings at TA = 25 °C, unless otherwise specified Parameter Symbol Conditions GBU10J GBU10K GBU10M Unit Repetitive peak reverse voltage VRRM 600 800 1000 V RMS reverse voltage DC blocking voltage Operating temperature Storage temperature VRMS VDC Tj Tstg 420 600 -40 to 150 -40 to 150 560 800 -40 to 150 -40 to 150 700 1000 -40 to 150 -40 to 150 V V °C °C Conditions GBU10J GBU10K GBU10M Unit TC = 100 °C 10 (1) 10 (1) 10 (1) (2) (2) Electrical characteristics at TA = 25 °C, unless otherwise specified Single phase, half sine wave, 50 Hz, resistive load For capacitive load derate current by 20% Parameter Symbol IO Maximum forward rectified current IFSM VF Peak forward surge current Maximum forward voltage drop Maximum reverse current at rated DC blocking voltage IR Insulation strength (lead wire to case) Vdis Rating for fusing at Tj = 25 C I2 t RΘJA Typical thermal resistance tp = 10 ms, Tj = 25 °C IF = 5 A 3.5 225 1.05 3.5 (2) 225 1.05 TA = 25 °C 5 5 5 TA = 125 °C 500 500 500 2.5 2.5 2.5 kV 80 80 80 A2s 23 (2) 5.0 (1) 23 (2) 5.0 (1) 23 (2) 5.0 (1) °C/W AC voltage: 1 min leakage current
GBU10K 价格&库存
很抱歉,暂时无法提供与“GBU10K”相匹配的价格&库存,您可以联系我们找货
GBU10K
  • 1+18.526081+2.39858
