GBU10G
GBU10G
    GENESICSEMICONDUCTOR
    SIP4
    DIODE BRIDGE 400V 10A GBU
GBU10G 数据手册
GBU10A thru GBU10G Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 50 V - 400 V IO = 10 A Features • Epoxy Resin material compliant with 94V-0 standards of UL UL Material Flammability Provisions • Compliant with UL Provisions, UL Code: E303851 • Ideal for printed circuit boards • High surge overload rating • High temperature soldering guaranteed: 260⁰C/ 10 seconds, 9.5 mm lead length GBU Package • Not ESD Sensitive Mechanical Data • Case: Epoxy resin body over passivated junctions • Weight: 4.60 g • Mounting position: Any Maximum ratings at TA = 25 °C, unless otherwise specified Parameter Symbol Conditions GBU10A GBU10B GBU10D GBU10G Unit Repetitive peak reverse voltage VRRM 50 100 200 400 V RMS reverse voltage DC blocking voltage Operating temperature Storage temperature VRMS VDC Tj Tstg 35 50 -40 to 150 -40 to 150 70 100 -40 to 150 -40 to 150 140 200 -40 to 150 -40 to 150 280 400 -40 to 150 -40 to 150 V V °C °C Unit Electrical characteristics at TA = 25 °C, unless otherwise specified Single phase, half sine wave, 50 Hz, resistive load For capacitive load derate current by 20% Parameter Symbol IO Maximum forward rectified current IFSM VF Peak forward surge current Maximum forward voltage drop Maximum reverse current at rated DC blocking voltage IR Insulation strength (lead wire to case) Vdis Rating for fusing at Tj = 25 C I2 t RΘJA Typical thermal resistance Conditions GBU10A GBU10B GBU10D GBU10G TC = 100 °C 10 (1) 10 (1) 10 (1) 10 (1) (2) (2) (2) tp = 10 ms, Tj = 25 °C 3.5 225 3.5 225 3.5 225 3.5 (2) 225 IF = 5 A 1.05 1.05 1.05 1.05 TA = 25 °C A V TA = 25 °C 5 5 5 5 TA = 125 °C 500 500 500 500 2.5 2.5 2.5 2.5 kV 80 80 80 80 A2s AC voltage: 1 min leakage current
GBU10G
物料型号:GBU10A至GBU10G
器件简介: - 这些器件是单相玻璃钝化硅桥式整流器,适合用于印刷电路板,具有高浪涌过载等级,符合UL标准和94V-0的UL材料可燃性规定。
引脚分配: - 引脚分配细节在PDF中提供的图表中,但具体的引脚分配信息未在摘要中提供。
参数特性: - 包括重复峰值反向电压(VRRM)从50V至400V不等,RMS反向电压(VRMS)从35V至280V,直流阻断电压(VDo)与VRRM相同,工作温度范围为-40至150摄氏度。
功能详解: - 提供了电气特性,例如最大正向整流电流(IF),最大正向电压降(VF),最大反向电流(IR),绝缘强度(Vdis)和典型热阻(RoJA)等。
应用信息: - 包括电流降额曲线,典型反向特性曲线,最大浪涌电流曲线和额定正向特性曲线的图表。
封装信息: - 提供了GBU封装的尺寸和端子配置,以及产品标记有零件号和端子配置。
GBU10G 价格&库存
很抱歉,暂时无法提供与“GBU10G”相匹配的价格&库存,您可以联系我们找货
