BR82
BR82
    GENESICSEMICONDUCTOR
    BR-8
    DIODEBRIDGE200V8ABR-8
BR82 数据手册
BR805 thru BR84 Single Phase Silicon Bridge Rectifier VRRM = 50 V - 400 V IO = 8 A Features • Low forward voltage drop • Low leakage current • Types from 50 V up to 400 V VRRM • Not ESD Sensitive BR-8 Package Mechanical Data Mounting: Hole thru for #6 screw Mounting position: Any Maximum ratings at Tc = 25 °C, unless otherwise specified BR805 BR81 BR82 BR84 Unit VRRM 50 100 200 400 V RMS reverse voltage VRMS 35 70 140 280 V DC blocking voltage Operating temperature Storage temperature VDC Tj Tstg 50 -65 to 125 -65 to 150 100 -65 to 125 -65 to 150 200 -65 to 125 -65 to 150 400 -65 to 125 -65 to 150 V °C °C Parameter Symbol Repetitive peak reverse voltage Conditions Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load For capacitive load derate current by 20% Parameter Symbol Conditions BR805 BR81 BR82 BR84 Unit Maximum average forward rectified current IO Tc = 50 °C 8.0 8.0 8.0 8.0 A Peak forward surge current IFSM tp = 8.3 ms, half sine 250 250 250 250 A Maximum instantaneous forward voltage drop per bridge element VF IF = 4.0 A 1.1 1.1 1.1 1.1 V Maximum DC reverse current at rated DC blocking voltage IR Ta = 25 °C 10 10 10 10 Ta = 100 °C 200 200 200 200 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br82.pdf μA 1 BR805 thru BR84 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br82.pdf 2 BR805 thru BR84 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Dimensions in inches and (millimeters) Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br82.pdf 3
很抱歉,暂时无法提供与“BR82”相匹配的价格&库存,您可以联系我们找货
BR82
  • 2000+6.886622000+0.88363
