BR86
BR86
    GENESICSEMICONDUCTOR
    BR-8
    DIODE BRIDGE 600V 8A BR-8
BR86 数据手册
BR86 thru BR810 Single Phase Silicon Bridge Rectifier VRRM = 600 V - 1000 V IO = 8 A Features • Low forward voltage drop • Low leakage current • Types from 600 V up to 1000 V VRRM • Not ESD Sensitive BR-8 Package Mechanical Data Mounting: Hole thru for #6 screw Mounting position: Any Maximum ratings at Tc = 25 °C, unless otherwise specified Parameter Symbol Conditions BR86 BR88 BR810 Unit 1000 V Repetitive peak reverse voltage VRRM 600 800 RMS reverse voltage VRMS 420 560 700 V DC blocking voltage Operating temperature Storage temperature VDC Tj Tstg 600 -65 to 125 -65 to 150 800 -65 to 125 -65 to 150 1000 -65 to 125 -65 to 150 V °C °C Electrical characteristics at Tc = 25 °C, unless otherwise specified Single phase, half sine wave, 60 Hz, resistive or inductive load For capacitive load derate current by 20% Parameter Symbol Conditions BR86 BR88 BR810 Unit Maximum average forward rectified current IO Tc = 50 °C 8.0 8.0 8.0 A Peak forward surge current IFSM tp = 8.3 ms, half sine 250 250 250 A Maximum instantaneous forward voltage drop per bridge element VF IF = 4.0 A 1.1 1.1 1.1 V Maximum DC reverse current at rated DC blocking voltage IR Ta = 25 °C 10 10 10 Ta = 100 °C 200 200 200 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br86.pdf μA 1 BR86 thru BR810 Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br86.pdf 2 BR86 thru BR810 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Dimensions in inches and (millimeters) Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/br86.pdf 3
很抱歉,暂时无法提供与“BR86”相匹配的价格&库存,您可以联系我们找货
