GBU15J thru GBU15M
Single Phase Glass Passivated Silicon
Bridge Rectifier
VRRM = 600 V - 1000 V
IO = 15 A
Features
• Epoxy Resin material compliant with 94V-0 standards of
UL UL Material Flammability Provisions
• Compliant with UL Provisions, UL Code: E303851
• Ideal for printed circuit boards
• High surge overload rating
• High temperature soldering guaranteed: 260⁰C/ 10 seconds,
9.5 mm lead length
GBU Package
• Not ESD Sensitive
Mechanical Data
• Case: Epoxy resin body over passivated junctions
• Weight: 4.60 g
• Mounting position: Any
Maximum ratings at TA = 25 °C, unless otherwise specified
Parameter
Symbol
Conditions
GBU15J
GBU15K
GBU15M
Unit
Repetitive peak reverse voltage
VRRM
600
800
1000
V
RMS reverse voltage
DC blocking voltage
Operating temperature
Storage temperature
VRMS
VDC
Tj
Tstg
420
600
-40 to 150
-40 to 150
560
800
-40 to 150
-40 to 150
700
1000
-40 to 150
-40 to 150
V
V
°C
°C
Conditions
GBU15J
GBU15K
GBU15M
Unit
TC = 100 °C
15 (1)
15 (1)
15 (1)
(2)
(2)
Electrical characteristics at TA = 25 °C, unless otherwise specified
Single phase, half sine wave, 50 Hz, resistive load
For capacitive load derate current by 20%
Parameter
Symbol
IO
Maximum forward rectified current
IFSM
VF
Peak forward surge current
Maximum forward voltage drop
Maximum reverse current at rated DC
blocking voltage
IR
Insulation strength (lead wire to case)
Vdis
Rating for fusing at Tj = 25 C
I2 t
RΘJA
Typical thermal resistance
tp = 10 ms, Tj = 25 °C
IF = 7.5 A
3.8
250
1.05
3.8 (2)
250
1.05
TA = 25 °C
5
5
5
TA = 125 °C
500
500
500
2.5
2.5
2.5
kV
80
80
80
A2s
22 (2)
5.0 (1)
22 (2)
5.0 (1)
22 (2)
5.0 (1)
°C/W
AC voltage: 1 min
leakage current
很抱歉,暂时无法提供与“GBU15J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+5.564625000+0.71692
