GBPC1506T/W thru GBPC1510T/W
Single Phase Glass Passivated
Silicon Bridge Rectifier
VRRM = 600 V - 1000 V
IO = 15 A
Features
• Integrally molded heat sink provides low thermal resistance
for maximum heat dissipation
• High surge current capability
• Void-free junction soldering by using vacuum soldering
• Universal 3-way terminals: snap on, wire-around, or P.C
board mounting
• High temperature soldering guaranteed: 260⁰C/ 10
seconds at 5 lbs (2.3 kg) tension
• Not ESD Sensitive
GBPC-T/W Package
Mechanical Data
Case: Molded plastic with heat sink integrally mounted in the bridge
encapsulation
Terminals: Either nickel plated 0.25". Faston lugs or copper leads
0.040" diameter.
Polarity: Polarrity symbols marked on the body
Mounting position: Bolt down on heat-sink with silicone thermal
compound between bridge and mounting surface
Weight: 15 grams or 0.53 ounces
Mounting torque: 20 inch-lbs max
Maximum ratings at Tc = 25 °C, unless otherwise specified (GBPCXXXXT uses GBPC-T package while GBPCXXXXW
uses GBPC-W package)
Parameter
Symbol
Conditions
GBPC1506T/W
GBPC1508T/W
GBPC1510T/W
Unit
1000
V
Repetitive peak reverse voltage
VRRM
600
800
RMS reverse voltage
VRMS
420
560
700
V
DC blocking voltage
Operating temperature
Storage temperature
VDC
Tj
Tstg
600
-55 to 150
-55 to 150
800
-55 to 150
-55 to 150
1000
-55 to 150
-55 to 150
V
°C
°C
Electrical characteristics at Tc = 25 °C, unless otherwise specified
Single phase, half sine wave, 60 Hz, resistive or inductive load
For capacitive load derate current by 20%
Parameter
Maximum average forward rectified
current
Peak forward surge current
Maximum instantaneous forward
voltage drop per leg
Maximum DC reverse current at
rated DC blocking voltage per leg
Rating for fusing
RMS isolation voltage from case to
leads
Typical junction capacitance
Typical thermal resistance
Oct. 2018
Conditions
GBPC1506T/W
GBPC1508T/W
GBPC1510T/W
Unit
IO
Tc = 55 °C
15.0
15.0
15.0
A
IFSM
single sine-wave
300
300
300
A
VF
IF = 7.5 A
1.1
1.1
1.1
V
Ta = 25 °C
5
5
5
500
375
500
375
500
375
A sec
VISO
2500
2500
2500
V
Cj
300
300
300
pF
RΘJC
1.9
1.9
1.9
°C/W
Symbol
IR
2
It
Ta = 125 °C
1 ms < tm < 8.3 ms
http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbpc1510tw.pdf
μA
2
1
Oct. 2018
2
Oct. 2018
3
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
Dimensions in inches and (millimeters)
Oct. 2018
4
很抱歉,暂时无法提供与“GBPC1510T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+19.54609500+2.43286
