VUO68-08NO7
3~
Rectifier
Standard Rectifier Module
VRRM =
800 V
I DAV =
70 A
I FSM =
300 A
3~ Rectifier Bridge
Part number
VUO68-08NO7
K
N
H
A
D
Features / Advantages:
Applications:
Package: ECO-PAC1
● Package with DCB ceramic
● Improved temperature and power cycling
● Planar passivated chips
● Very low forward voltage drop
● Very low leakage current
● Diode for main rectification
● For three phase bridge configurations
● Supplies for DC power equipment
● Input rectifiers for PWM inverter
● Battery DC power supplies
● Field supply for DC motors
● Isolation Voltage: 3000 V~
● Industry standard outline
● RoHS compliant
● Soldering pins for PCB mounting
● Height: 9 mm
● Base plate: DCB ceramic
● Reduced weight
● Advanced power cycling
Disclaimer Notice
Information furnished is believed to be accurate and reliable. However, users should independently
evaluate the suitability of and test each product selected for their own applications. Littelfuse products are not designed for,
and may not be used in, all applications. Read complete Disclaimer Notice at www.littelfuse.com/disclaimer-electronics.
IXYS reserves the right to change limits, conditions and dimensions.
© 2019 IXYS all rights reserved
Data according to IEC 60747and per semiconductor unless otherwise specified
20191220c
VUO68-08NO7
Ratings
Rectifier
Conditions
Symbol
VRSM
Definition
max. non-repetitive reverse blocking voltage
TVJ = 25°C
VRRM
max. repetitive reverse blocking voltage
TVJ = 25°C
IR
reverse current
VF
I DAV
bridge output current
VF0
threshold voltage
rF
slope resistance
R thJC
thermal resistance junction to case
total power dissipation
I FSM
max. forward surge current
I²t
CJ
value for fusing
junction capacitance
800
V
TVJ = 25°C
40
µA
TVJ = 150°C
1.5
mA
TVJ = 25°C
1.15
V
1.50
V
1.12
V
IF =
20 A
IF =
60 A
IF =
20 A
IF =
60 A
TVJ = 125 °C
1.39
V
T VJ = 150 °C
70
A
TVJ = 150 °C
0.82
V
12.2
mΩ
d=⅓
for power loss calculation only
thermal resistance case to heatsink
max. Unit
900
V
VR = 800 V
rectangular
R thCH
typ.
VR = 800 V
TC = 105 °C
Ptot
min.
1.1 K/W
0.4
K/W
TC = 25°C
110
W
t = 10 ms; (50 Hz), sine
TVJ = 45°C
300
A
t = 8,3 ms; (60 Hz), sine
VR = 0 V
325
A
TVJ = 150 °C
255
A
VR = 0 V
275
A
TVJ = 45°C
450
A²s
VR = 0 V
440
A²s
TVJ = 150 °C
325
A²s
315
A²s
VR = 0 V
VR = 400 V; f = 1 MHz
TVJ = 25°C
10
pF
20191220c
VUO68-08NO7
Package
Ratings
ECO-PAC1
Symbol
I RMS
Definition
Conditions
RMS current
per terminal
min.
TVJ
virtual junction temperature
T op
operation temperature
Tstg
storage temperature
-40
max.
100
Unit
A
-40
150
°C
-40
125
°C
125
°C
19
Weight
MD
1.4
mounting torque
d Spp/App
creepage distance on surface | striking distance through air
d Spb/Apb
VISOL
typ.
t = 1 minute
2
Nm
terminal to terminal
6.0
mm
terminal to backside
10.0
mm
3000
V
2500
V
t = 1 second
isolation voltage
g
50/60 Hz, RMS; IISOL ≤ 1 mA
Date Code/Location
Logo
yywwZ
123456
XXX XX-XXXXX
Part Number
Ordering
Standard
Circuit Diagram
Lot#
Ordering Number
VUO68-08NO7
Equivalent Circuits for Simulation
I
V0
R0
* on die level
Delivery Mode
Box
Quantity
25
Code No.
483303
T VJ = 150°C
Rectifier
V 0 max
threshold voltage
0.82
R0 max
slope resistance *
11
Marking on Product
VUO68-08NO7
V
mΩ
20191220c
VUO68-08NO7
Outlines ECO-PAC1
K
N
H
A
D
20191220c
VUO68-08NO7
Rectifier
80
300
60
250
IF
50 Hz
0.8 x V RRM
IFSM
I2t
TVJ = 45°C
[A]
TVJ =
125°C
150°C
TVJ = 25°C
0.8
1.2
1.6
TVJ = 150°C
TVJ = 150°C
100
10-3
2.0
TVJ = 45°C
2
[A s]
150
10-1
100
100
1
10
VF [V]
t [s]
t [ms]
Fig. 1 Forward current versus
voltage drop per diode
Fig. 2 Surge overload current
Fig. 3 I t versus time per diode
40
30
25
2
100
RthJA:
DC =
1
0.5
0.4
0.33
0.17
0.08
35
DC =
0.6 KW
0.8 KW
[W]
VR = 0 V
200
40
[A]
Ptot
1000
1
KW
2
KW
4
KW
8
KW
0.5
0.4
IF(AV)M60
0.33
0.17
[A]
15
1
80
0.08
40
10
10
15
30
50
75
100
125
25
50
TA [°C]
IdAVM [A]
75
100 125 150
TC [°C]
Fig. 4 Power dissipation vs. direct output current & ambient temperature
Fig. 5 Max. forward current vs.
case temperature
1.2
1.0
Constants for ZthJC calculation:
0.8
ZthJC
0.6
[K/W]
0.4
0.2
i
Rth (K/W)
ti (s)
1
0.05070
0.004
2
0.163
0.0025
3
0.2805
0.0035
4
0.363
0.02
5
0.2228
0.15
0.0
1
10
100
1000
10000
t [ms]
Fig. 6 Transient thermal impedance junction to case
20191220c
很抱歉,暂时无法提供与“VUO68-08NO7”相匹配的价格&库存,您可以联系我们找货
