VUO68-14NO7
VUO68-14NO7
    IXYSCORPORATION
    ECO-PAC1
    RECT BRIDGE 3PH 1400V ECO-PAC1
VUO68-14NO7 数据手册
VUO68-08NO7 3~ Rectifier Standard Rectifier Module VRRM = 800 V I DAV = 70 A I FSM = 300 A 3~ Rectifier Bridge Part number VUO68-08NO7 K N H A D Features / Advantages: Applications: Package: ECO-PAC1 ● Package with DCB ceramic ● Improved temperature and power cycling ● Planar passivated chips ● Very low forward voltage drop ● Very low leakage current ● Diode for main rectification ● For three phase bridge configurations ● Supplies for DC power equipment ● Input rectifiers for PWM inverter ● Battery DC power supplies ● Field supply for DC motors ● Isolation Voltage: 3000 V~ ● Industry standard outline ● RoHS compliant ● Soldering pins for PCB mounting ● Height: 9 mm ● Base plate: DCB ceramic ● Reduced weight ● Advanced power cycling Disclaimer Notice Information furnished is believed to be accurate and reliable. However, users should independently evaluate the suitability of and test each product selected for their own applications. Littelfuse products are not designed for, and may not be used in, all applications. Read complete Disclaimer Notice at www.littelfuse.com/disclaimer-electronics. IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved Data according to IEC 60747and per semiconductor unless otherwise specified 20191220c VUO68-08NO7 Ratings Rectifier Conditions Symbol VRSM Definition max. non-repetitive reverse blocking voltage TVJ = 25°C VRRM max. repetitive reverse blocking voltage TVJ = 25°C IR reverse current VF forward voltage drop I DAV bridge output current VF0 threshold voltage rF slope resistance R thJC thermal resistance junction to case total power dissipation I FSM max. forward surge current I²t CJ value for fusing junction capacitance IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved 800 V TVJ = 25°C 40 µA TVJ = 150°C 1.5 mA TVJ = 25°C 1.15 V 1.50 V 1.12 V IF = 20 A IF = 60 A IF = 20 A IF = 60 A TVJ = 125 °C 1.39 V T VJ = 150 °C 70 A TVJ = 150 °C 0.82 V 12.2 mΩ d=⅓ for power loss calculation only thermal resistance case to heatsink max. Unit 900 V VR = 800 V rectangular R thCH typ. VR = 800 V TC = 105 °C Ptot min. 1.1 K/W 0.4 K/W TC = 25°C 110 W t = 10 ms; (50 Hz), sine TVJ = 45°C 300 A t = 8,3 ms; (60 Hz), sine VR = 0 V 325 A t = 10 ms; (50 Hz), sine TVJ = 150 °C 255 A t = 8,3 ms; (60 Hz), sine VR = 0 V 275 A t = 10 ms; (50 Hz), sine TVJ = 45°C 450 A²s t = 8,3 ms; (60 Hz), sine VR = 0 V 440 A²s t = 10 ms; (50 Hz), sine TVJ = 150 °C 325 A²s 315 A²s t = 8,3 ms; (60 Hz), sine VR = 0 V VR = 400 V; f = 1 MHz TVJ = 25°C 10 Data according to IEC 60747and per semiconductor unless otherwise specified pF 20191220c VUO68-08NO7 Package Ratings ECO-PAC1 Symbol I RMS Definition Conditions RMS current per terminal min. TVJ virtual junction temperature T op operation temperature Tstg storage temperature -40 max. 100 Unit A -40 150 °C -40 125 °C 125 °C 19 Weight MD 1.4 mounting torque d Spp/App creepage distance on surface | striking distance through air d Spb/Apb VISOL typ. t = 1 minute 2 Nm terminal to terminal 6.0 mm terminal to backside 10.0 mm 3000 V 2500 V t = 1 second isolation voltage g 50/60 Hz, RMS; IISOL ≤ 1 mA Date Code/Location Logo yywwZ 123456 XXX XX-XXXXX Part Number Ordering Standard Circuit Diagram Lot# Ordering Number VUO68-08NO7 Equivalent Circuits for Simulation I V0 R0 * on die level Delivery Mode Box Quantity 25 Code No. 483303 T VJ = 150°C Rectifier V 0 max threshold voltage 0.82 R0 max slope resistance * 11 IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved Marking on Product VUO68-08NO7 V mΩ Data according to IEC 60747and per semiconductor unless otherwise specified 20191220c VUO68-08NO7 Outlines ECO-PAC1 K IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved N H A D Data according to IEC 60747and per semiconductor unless otherwise specified 20191220c VUO68-08NO7 Rectifier 80 300 60 250 IF 50 Hz 0.8 x V RRM IFSM I2t TVJ = 45°C [A] TVJ = 125°C 150°C 0 0.4 TVJ = 25°C 0.8 1.2 1.6 TVJ = 150°C TVJ = 150°C 100 10-3 2.0 TVJ = 45°C 2 [A s] 150 20 10-2 10-1 100 100 1 10 VF [V] t [s] t [ms] Fig. 1 Forward current versus voltage drop per diode Fig. 2 Surge overload current Fig. 3 I t versus time per diode 40 30 25 2 100 RthJA: DC = 1 0.5 0.4 0.33 0.17 0.08 35 DC = 0.6 KW 0.8 KW 20 [W] VR = 0 V 200 40 [A] Ptot 1000 1 KW 2 KW 4 KW 8 KW 0.5 0.4 IF(AV)M60 0.33 0.17 [A] 15 1 80 0.08 40 10 20 5 0 0 0 5 10 15 20 25 30 0 25 50 75 100 125 0 150 25 50 TA [°C] IdAVM [A] 75 100 125 150 TC [°C] Fig. 4 Power dissipation vs. direct output current & ambient temperature Fig. 5 Max. forward current vs. case temperature 1.2 1.0 Constants for ZthJC calculation: 0.8 ZthJC 0.6 [K/W] 0.4 0.2 i Rth (K/W) ti (s) 1 0.05070 0.004 2 0.163 0.0025 3 0.2805 0.0035 4 0.363 0.02 5 0.2228 0.15 0.0 1 10 100 1000 10000 t [ms] Fig. 6 Transient thermal impedance junction to case IXYS reserves the right to change limits, conditions and dimensions. © 2019 IXYS all rights reserved Data according to IEC 60747and per semiconductor unless otherwise specified 20191220c
VUO68-14NO7 价格&库存
很抱歉,暂时无法提供与“VUO68-14NO7”相匹配的价格&库存,您可以联系我们找货
