VBO40-08NO6
3~
1~
Rectifier
Standard Rectifier
VRRM =
800 V
I DAV =
40 A
I FSM =
320 A
1~ Rectifier Bridge
Part number
VBO40-08NO6
Backside: isolated
3
2
1
4
Features / Advantages:
Applications:
Package: SOT-227B (minibloc)
● Planar passivated chips
● Very low leakage current
● Very low forward voltage drop
● Improved thermal behaviour
● Diode for main rectification
● For one phase bridge configurations
● Supplies for DC power equipment
● Input rectifiers for PWM inverter
● Battery DC power supplies
● Field supply for DC motors
● Isolation Voltage: 3000 V~
● Industry standard outline
● RoHS compliant
● Epoxy meets UL 94V-0
● Base plate: Copper
internally DCB isolated
● Advanced power cycling
Disclaimer Notice
Information furnished is believed to be accurate and reliable. However, users should independently
evaluate the suitability of and test each product selected for their own applications. Littelfuse products are not designed for,
and may not be used in, all applications. Read complete Disclaimer Notice at www.littelfuse.com/disclaimer-electronics.
IXYS reserves the right to change limits, conditions and dimensions.
© 2019 IXYS all rights reserved
Data according to IEC 60747and per semiconductor unless otherwise specified
20191211c
VBO40-08NO6
Ratings
Rectifier
Conditions
Symbol
VRSM
Definition
max. non-repetitive reverse blocking voltage
TVJ = 25°C
VRRM
max. repetitive reverse blocking voltage
TVJ = 25°C
IR
reverse current
VF
I DAV
bridge output current
VF0
threshold voltage
rF
slope resistance
R thJC
thermal resistance junction to case
total power dissipation
I FSM
max. forward surge current
I²t
CJ
value for fusing
junction capacitance
800
V
TVJ = 25°C
40
µA
TVJ = 150°C
1.5
mA
TVJ = 25°C
1.15
V
1.33
V
1.07
V
IF =
20 A
IF =
40 A
IF =
20 A
IF =
40 A
TVJ = 125 °C
1.31
V
T VJ = 150 °C
40
A
TVJ = 150 °C
0.81
V
12.1
mΩ
d = 0.5
for power loss calculation only
thermal resistance case to heatsink
max. Unit
900
V
VR = 800 V
rectangular
R thCH
typ.
VR = 800 V
TC = 115 °C
Ptot
min.
1.3 K/W
K/W
0.1
TC = 25°C
95
W
t = 10 ms; (50 Hz), sine
TVJ = 45°C
320
A
t = 8,3 ms; (60 Hz), sine
VR = 0 V
345
A
TVJ = 150 °C
270
A
VR = 0 V
295
A
TVJ = 45°C
510
A²s
VR = 0 V
495
A²s
TVJ = 150 °C
365
A²s
360
A²s
VR = 0 V
VR = 400 V; f = 1 MHz
TVJ = 25°C
11
pF
20191211c
VBO40-08NO6
Package
Ratings
SOT-227B (minibloc)
Symbol
I RMS
Definition
Conditions
RMS current
per terminal
min.
TVJ
virtual junction temperature
T op
operation temperature
Tstg
storage temperature
-40
typ.
max.
150
Unit
A
-40
150
°C
-40
125
°C
150
°C
30
Weight
g
MD
mounting torque
1.1
1.5
Nm
MT
terminal torque
1.1
1.5
Nm
d Spp/App
creepage distance on surface | striking distance through air
d Spb/Apb
VISOL
terminal to terminal
10.5
terminal to backside
8.6
t = 1 second
isolation voltage
t = 1 minute
50/60 Hz, RMS; IISOL ≤ 1 mA
3.2
mm
6.8
mm
3000
V
2500
V
Product Marking
Logo
XXXXX ®
yywwZ
1234
Date
Code
Location
Ordering
Standard
Part
Number
UL
Lot#
Ordering Number
VBO40-08NO6
Similar Part
VBO40-12NO6
VBO40-16NO6
Equivalent Circuits for Simulation
I
V0
R0
Marking on Product
VBO40-08NO6
Package
SOT-227B (minibloc)
SOT-227B (minibloc)
* on die level
Delivery Mode
Tube
Code No.
475866
Voltage class
1200
1600
T VJ = 150°C
Rectifier
V 0 max
threshold voltage
0.81
V
R0 max
slope resistance *
10.2
mΩ
Quantity
10
20191211c
VBO40-08NO6
Outlines SOT-227B (minibloc)
3
2
1
4
20191211c
VBO40-08NO6
Rectifier
80
300
60
250
700
50 Hz
0.8 x V RRM
VR = 0 V
600
500
IF
IFSM
2
TVJ = 45°C
It
200
40
[A]
400
[A]
TVJ = 45°C
[A2s]
TVJ = 150°C
TVJ = 150°C
300
TVJ =
125°C
150°C
200
TVJ = 25°C
0.8
1.0
1.2
1.4
1.6
100
10-3
1.8
10-2
10-1
t [s]
Fig. 1 Forward current vs.
voltage drop per diode
Fig. 2 Surge overload current
vs. time per diode
Ptot 16
10
Fig. 3 I2t vs. time per diode
80
RthJA:
DC =
1
0.5
0.4
0.33
0.17
0.08
24
1
t [ms]
VF [V]
28
100
100
DC =
0.6 KW
1
0.8 KW
1
KW
2
KW
4
KW
8
KW
60
0.5
0.4
0.33
IF(AV)M
0.17
40
[W] 12
0.08
[A]
8
10
15
50
75
100
125
150
175
50
TA [°C]
IdAVM [A]
75
100 125 150
TC [°C]
Fig. 4 Power dissipation vs. forward current
and ambient temperature per diode
Fig. 5 Max. forward current vs.
case temperature per diode
1.6
1.2
Constants for ZthJC calculation:
ZthJC
0.8
[K/W]
0.4
0.0
1
10
100
1000
i
Rth (K/W)
ti (s)
1
0.061
0.0002
2
0.145
0.0036
3
0.398
0.0200
4
0.405
0.1000
5
0.291
0.7000
10000
t [ms]
Fig. 6 Transient thermal impedance junction to case vs. time per diode
20191211c
很抱歉,暂时无法提供与“VBO40-16NO6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+227.92936
- 10+221.48520
