VUC 36
IdAVM =
39 A
31 A
ITAVM =
VRRM = 1200/1600 V
Three Phase
Rectifier Bridge
with Fast Diodes and "Softstart" Thyristor
VRSM
VRRM
V
V
1300
1700
1200
1600
Type
VUC 36-12go2
VUC 36-16go2
Conditions
IdAV
IdAVM
ITAVM
TK = 85°C, module
module
TK = 85°C, DC
IFSM, ITSM
TVJ = 45°C
VR = 0
(di/dt)cr
(dv/dt)cr
4
1
6
7
3
5
8
Maximum Ratings
Diode Thyristor
34
39
31
A
A
A
t = 10 ms (50 Hz), sine
t = 8.3 ms (60 Hz), sine
300
330
400
440
A
A
TVJ = TVJM
VR = 0
270
300
360
400
A
A
TVJ = 45°C
VR = 0
450
460
800
810
A2 s
A2 s
TVJ = TVJM
VR = 0
365
380
650
670
A2 s
A2 s
150
A/µs
500
A/µs
200
V/µs
10
V
10
1
0.5
W
W
W
-40...+125
125
-40...+125
°C
°C
°C
3000
3600
V~
V~
2-2.5
18-22
Nm
lb.in.
28
g
TVJ = TVJM
repetitive, IT = 50 A
f = 400 Hz, tP = 200 µs
VD = 2/3 VDRM
IG = 0.3 A
non repetitive, IT = ITAVM
diG /dt = 0.3 A/µs
TVJ = TVJM; VDR = 2/3 VDRM
RGK = ∞; method 1 (linear voltage rise)
VRGM
PGM
1
TVJ = TVJM
IT = ITAVM
tp = 30 µs
tp = 10 ms
PGAVM
TVJ
TVJM
Tstg
VISOL
50/60 Hz, RMS
IISOL < 1 mA
t = 1 min
t=1s
Md
Mounting torque
(M5)
(10-32 UNF)
Weight
typ.
4
3
2
5
Symbol
I2t
2
6
7
8
Features
• Package with DCB ceramic base plate
• Isolation voltage 3600 V~
• Planar passivated chips
• Fast recovery diodes to reduce EMI
• Separate thyristor for softstart
• Solderable terminals
• UL registered E 72873
Applications
• Input rectifier for switching power
supplies (SMPS)
• Softstart capacitor charging
• Electric drives and auxiliaries
Advantages
• Easy to mount with two screws
• Space and weight savings
• Improved temperature & power cycling
• Up to 10 dB lower EMI/RFI
compared to standard rectifier
Dimensions in mm (1 mm = 0.0394")
Data according to IEC 60747 and refer to a single thyristor/diode unless otherwise stated
IXYS reserves the right to change limits, test conditions and dimensions.
© 2010 IXYS All rights reserved
20100709b
1-2
VUC
VUC36
36
Symbol
Conditions
IR, ID
VR = VRRM; VD = VDRM
TVJ = TVJM
TVJ = 25°C
5
< 0.3
5
0.3
mA
mA
VF, VT
IF = 55 A; IT = 45 A
TVJ = 25°C
很抱歉,暂时无法提供与“VUC36-16GO2”相匹配的价格&库存,您可以联系我们找货
