VUB160-16NOX
3~
Rectifier
Standard Rectifier Module
Brake
Chopper
VRRM = 1600 V VCES = 1200 V
I DAV =
180 A I C25
= 250 A
I FSM = 1100 A VCE(sat) =
1.7 V
3~ Rectifier Bridge + Brake Unit
Part number
VUB160-16NOX
Backside: isolated
M1/O1
S1
U1/
W1
~A6
~E6
~K6
M10/O10
W U S/T
10 10 10
Features / Advantages:
Applications:
Package: V2-Pack
● Package with DCB ceramic base plate
● Improved temperature and power cycling
● Planar passivated chips
● Very low forward voltage drop
● Very low leakage current
● X2PT - 2nd generation Xtreme light Punch Through
● Rugged X2PT design results in:
- short circuit rated for 10 µsec.
- very low gate charge
- low EMI
- square RBSOA @ 2x Ic
● Thin wafer technology combined with X2PT design
results in a competitive low VCE(sat) and low
thermal resistance
● 3~ Rectifier with brake unit
for drive inverters
● Isolation Voltage: 3600 V~
● Industry standard outline
● RoHS compliant
● Soldering pins for PCB mounting
● Height: 17 mm
● Base plate: DCB ceramic
● Reduced weight
● Advanced power cycling
Disclaimer Notice
Information furnished is believed to be accurate and reliable. However, users should independently
evaluate the suitability of and test each product selected for their own applications. Littelfuse products are not designed for,
and may not be used in, all applications. Read complete Disclaimer Notice at www.littelfuse.com/disclaimer-electronics.
IXYS reserves the right to change limits, conditions and dimensions.
© 2019 IXYS all rights reserved
Data according to IEC 60747and per semiconductor unless otherwise specified
20191220f
VUB160-16NOX
Ratings
Rectifier
Conditions
Symbol
VRSM
Definition
max. non-repetitive reverse blocking voltage
TVJ = 25°C
VRRM
max. repetitive reverse blocking voltage
TVJ = 25°C
1600
IR
reverse current
VF
min.
typ.
VR = 1600 V
TVJ = 25°C
100
µA
TVJ = 125°C
2
mA
IF =
TVJ = 25°C
1.16
V
1.55
V
1.09
V
IF =
60 A
TVJ = 125 °C
60 A
I F = 180 A
bridge output current
VF0
threshold voltage
rF
slope resistance
R thJC
thermal resistance junction to case
TC = 90 °C
rectangular
R thCH
thermal resistance case to heatsink
total power dissipation
I FSM
max. forward surge current
I²t
CJ
value for fusing
junction capacitance
1.59
V
T VJ = 150 °C
180
A
TVJ = 150 °C
0.81
V
4.4
mΩ
d=⅓
for power loss calculation only
Ptot
V
VR = 1600 V
I F = 180 A
I DAV
max. Unit
1700
V
0.6 K/W
0.2
K/W
TC = 25°C
205
W
t = 10 ms; (50 Hz), sine
TVJ = 45°C
1.10
kA
t = 8,3 ms; (60 Hz), sine
VR = 0 V
1.19
kA
TVJ = 150 °C
935
A
VR = 0 V
1.01
kA
TVJ = 45°C
6.05 kA²s
VR = 0 V
5.89 kA²s
TVJ = 150 °C
4.37 kA²s
VR = 0 V
VR = 400 V; f = 1 MHz
TVJ = 25°C
4.25 kA²s
37
pF
20191220f
VUB160-16NOX
Ratings
Brake IGBT + Diode
Symbol
VCES
Definition
Conditions
min.
VGES
max. DC gate voltage
±20
V
VGEM
max. transient gate emitter voltage
±30
V
I C25
collector current
TC = 25°C
250
A
TC = 80 °C
175
A
695
W
2.1
V
TVJ =
collector emitter voltage
I C80
Ptot
VCE(sat)
collector emitter saturation voltage
VGE(th)
gate emitter threshold voltage
I C = 6 mA; VGE = V CE
TVJ = 25°C
I CES
collector emitter leakage current
VCE = VCES ; V GE = 0 V
TVJ = 25°C
I GES
gate emitter leakage current
VGE = ±20 V
Q G(on)
total gate charge
VCE = 600 V; VGE = 15 V; I C =150 A
t d(on)
turn-on delay time
TC = 25°C
I C = 150 A; V GE = 15 V
TVJ = 25°C
1.7
TVJ = 125°C
1.9
TVJ = 125°C
tr
current rise time
t d(off)
turn-off delay time
tf
current fall time
Eon
turn-on energy per pulse
Eoff
turn-off energy per pulse
RBSOA
reverse bias safe operating area
typ.
25°C
inductive load
6.8
TVJ = 125°C
VGE = ±15 V; R G = 1.2 Ω
SCSOA
short circuit safe operating area
t SC
short circuit duration
VCEK = 1200 V
VCE = 900 V; VGE = ±15
I SC
short circuit current
RG = 1.2 Ω; non-repetitive
R thJC
R thCH
7.5
V
0.1
mA
0.1
mA
nA
510
nC
220
ns
100
ns
400
ns
220
ns
21.5
mJ
17
mJ
TVJ = 125°C
VCEK = 1200 V
I CM
V
500
VCE = 600 V; IC = 150 A
6
max. Unit
1200
V
TVJ = 125°C
450
A
10
µs
A
650
0.16 K/W
K/W
0.10
Brake Diode
VRRM
max. repetitive reverse voltage
TVJ = 25°C
1200
V
I F25
forward current
TC = 25°C
48
A
TC = 80 °C
32
A
TVJ = 25°C
2.75
V
TVJ = 25°C
0.25
mA
TVJ = 125°C
1
mA
I F80
VF
forward voltage
I F = 30 A
IR
reverse current
VR = VRRM
Q rr
reverse recovery charge
VR =
I RM
max. reverse recovery current
-di F /dt =
trr
reverse recovery time
IF =
E rec
reverse recovery energy
R thJC
RthCH
TVJ = 125°C
1.60
6
µC
50
A
600 V
900 A/µs
30 A; VGE = 0 V
TVJ = 125°C
V
350
ns
2
mJ
0.9 K/W
0.3
K/W
20191220f
VUB160-16NOX
Package
Ratings
V2-Pack
Symbol
I RMS
Definition
Conditions
RMS current
per terminal
min.
TVJ
virtual junction temperature
T op
operation temperature
Tstg
storage temperature
-40
max.
100
Unit
A
-40
150
°C
-40
125
°C
125
°C
76
Weight
MD
2
mounting torque
d Spp/App
creepage distance on surface | striking distance through air
d Spb/Apb
VISOL
typ.
t = 1 minute
2.5
Nm
terminal to terminal
6.0
mm
terminal to backside
12.0
mm
3600
V
3000
V
t = 1 second
isolation voltage
g
50/60 Hz, RMS; IISOL ≤ 1 mA
Data Matrix: Typ (1-19), DC+Prod.Index (20-25), FKT# (26-31)
leer (33), lfd.# (33-36)
yywwAA
Part Number
Lot.No: xxxxxx
UL Date code
Prod. Index
Ordering
Standard
Ordering Number
VUB160-16NOX
Similar Part
VUB160-16NOXT
Equivalent Circuits for Simulation
I
V0
R0
Rectifier
Marking on Product
VUB160-16NOX
Package
V2-Pack
* on die level
Brake
IGBT +
Brake
Diode
V 0 max
threshold voltage
0.81
1.1
1.31
R0 max
slope resistance *
3.2
13.8
8
Delivery Mode
Box
Quantity
6
Code No.
521713
Voltage class
1600
T VJ = 150°C
V
mΩ
20191220f
VUB160-16NOX
Outlines V2-Pack
Marking
Remarks:
EJOT PT® self-tapping screws of the dimension K25 are
recommended for the mechanical connection between module
and PCB. Choose the right length according to your board
thickness at a maximum depth of 6 mm of the module holes.
The recommended mounting torque is 1.5 Nm.
M1/O1
S1
U1/
W1
~A6
~E6
~K6
M10/O10
W U S/T
10 10 10
20191220f
VUB160-16NOX
Rectifier
200
10 4
900
TVJ = 125°C
TVJ = 25°C
800
IF
IFSM
TVJ= 45°C
TVJ = 45°C
150
2
700
It
600
[A s]
TVJ= 150°C
100
[A]
[A]
2
50
TVJ = 150°C
500
50Hz, 80% VRRM
0.5
1.0
1.5
400
0.001
2.0
0.01
VF [V]
0.1
10 3
1
1
2
t [s]
Fig. 1 Forward current vs.
voltage drop per diode
3
4
5 6 7 8 910
t [ms]
2
Fig. 2 Surge overload current
vs. time per diode
Fig. 3 I t vs. time per diode
140
RthA:
0.1 K/W
0.3 K/W
0.6 K/W
1.0 K/W
1.5 K/W
2.5 K/W
DC =
1
0.5
0.4
0.33
0.17
0.08
80
60
Ptot
40
DC =
1
0.5
0.4
0.33
0.17
0.08
120
100
IdAV 80
[A] 60
[W]
40
40
50
60
70
IF(AV)M [A]
60
80 100 120 140 160
50
Tamb [°C]
75
100 125 150
TC [°C]
Fig. 4 Power dissipation vs. forward current
and ambient temperature per diode
Fig. 5 Max. forward current vs.
case temperature per diode
0.6
0.5
Constants for ZthJC calculation:
0.4
ZthJC
0.3
i
Rth (K/W)
ti (s)
[K/W]
1
0.040
0.004
2
0.003
0.010
3
0.140
0.030
4
0.120
0.300
5
0.197
0.080
0.2
0.1
0.0
1
10
100
1000
10000
t [s]
Fig. 6 Transient thermal impedance junction to case vs. time per diode
20191220f
VUB160-16NOX
Brake IGBT + Diode
300
300
25°C
200
IC
300
VGE = 19 V
17 V
15 V
VGE = 15 V
200
[A]
200
11 V
IC
125°C
VCE = 20 V
13 V
IC
TVJ = 125°C
[A]
[A]
100
125°C
100
100
25°C
9V
1.0
1.5
2.0
2.5
3.0
2
VCE [V]
6
4
30
60
200
[mJ]
[ns]
13
50
600
40
Eoff
tr
tr
10 11 12
60
300
td(on)
9
Fig. 3 Typ. transfer charact.
IGBT
800
RG = 1.2
VCE = 600 V
VGE = ±15 V
TVJ = 125°C
400
40
8
VGE [V]
Fig.2 Typ. output characteristics
IGBT
40
RG = 1.2
VCE = 600 V
VGE = ±15 V
TVJ = 125°C
Eon
7
VCE [V]
Fig.1 Output characteristics IGBT
80
3
t
td(off)
[ns]
[mJ]
30
[A]
125°C
tf
10
IF
200
10
25°C
Eoff
Eon
200
IC [A]
Fig. 4 Typ. turn-on energy & switch.
times vs. collector current
8
80
RG = 1.2
VR = 600 V
TVJ = 125°C
100
200
2.5
60
Erec
Irr
4
40
[A]
[mJ]
2
125
TVJ = 125°C
VR = 600 V
IF = 30 A
2.0
6
300
IC [A]
Fig. 5 Typ. turn-off energy & switch.
Erec
Irr
0.5
Erec
10
40
50
2.0
2.5
1
100
Erec
1.5
75
[mJ]
Irr
IGBT
ZthJC
Irr
1.0
50
0.1
[K/W]
[A]
IGBT
Ri
ti
0.020 0.006
0.003 0.007
0.040 0.030
0.097 0.250
25
0.0
IF [A]
Fig. 7 Typ. reverse recovery
characteristics Diode
1.5
VF [V]
Fig. 6 Typ. forward characteristics
Diode
Diode
0.5
8
12
16
RG [ ]
Fig. 8 Typ. reverse recovery
0.01
0.001
0.01
0.1
Diode
Ri
ti
0.092 0.002
0.067 0.030
0.155 0.030
0.086 0.080
1
10
t [s]
Fig. 9 Transient thermal
20191220f
很抱歉,暂时无法提供与“VUB160-16NOX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+782.114381+97.48881
- 10+633.0114610+78.90347
