VUC36-14GO2
VUC36-14GO2
    IXYSCORPORATION
    KAMM
    DIODE BRIDGE FAST 1400V KAMM-MOD
VUC36-14GO2 数据手册
VUC 36 IdAVM = 39 A 31 A ITAVM = VRRM = 1200/1600 V Three Phase Rectifier Bridge with Fast Diodes and "Softstart" Thyristor VRSM VRRM V V 1300 1700 1200 1600 Type VUC 36-12go2 VUC 36-16go2 Conditions IdAV IdAVM ITAVM TK = 85°C, module module TK = 85°C, DC IFSM, ITSM TVJ = 45°C VR = 0 (di/dt)cr (dv/dt)cr 4 1 6 7 3 5 8 Maximum Ratings Diode Thyristor 34 39 - 31 A A A t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine 300 330 400 440 A A TVJ = TVJM VR = 0 t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine 270 300 360 400 A A TVJ = 45°C VR = 0 t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine 450 460 800 810 A2 s A2 s TVJ = TVJM VR = 0 t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine 365 380 650 670 A2 s A2 s 150 A/µs 500 A/µs 200 V/µs 10 V 10 1 0.5 W W W -40...+125 125 -40...+125 °C °C °C 3000 3600 V~ V~ 2-2.5 18-22 Nm lb.in. 28 g TVJ = TVJM repetitive, IT = 50 A f = 400 Hz, tP = 200 µs VD = 2/3 VDRM IG = 0.3 A non repetitive, IT = ITAVM diG /dt = 0.3 A/µs TVJ = TVJM; VDR = 2/3 VDRM RGK = ∞; method 1 (linear voltage rise) VRGM PGM 1 TVJ = TVJM IT = ITAVM tp = 30 µs tp = 10 ms < < PGAVM TVJ TVJM Tstg VISOL 50/60 Hz, RMS IISOL < 1 mA t = 1 min t=1s Md Mounting torque (M5) (10-32 UNF) Weight typ. 4 3 2 5 Symbol I2t 2 6 7 8 Features • Package with DCB ceramic base plate • Isolation voltage 3600 V~ • Planar passivated chips • Fast recovery diodes to reduce EMI • Separate thyristor for softstart • Solderable terminals • UL registered E 72873 Applications • Input rectifier for switching power supplies (SMPS) • Softstart capacitor charging • Electric drives and auxiliaries Advantages • Easy to mount with two screws • Space and weight savings • Improved temperature & power cycling • Up to 10 dB lower EMI/RFI compared to standard rectifier Dimensions in mm (1 mm = 0.0394") Data according to IEC 60747 and refer to a single thyristor/diode unless otherwise stated IXYS reserves the right to change limits, test conditions and dimensions. © 2010 IXYS All rights reserved 20100709b 1-2 VUC VUC36 36 Symbol Conditions IR, ID VR = VRRM; VD = VDRM TVJ = TVJM TVJ = 25°C < 5 < 0.3 < < 5 0.3 mA mA VF, VT IF = 55 A; IT = 45 A TVJ = 25°C
VUC36-14GO2 价格&库存
很抱歉,暂时无法提供与“VUC36-14GO2”相匹配的价格&库存,您可以联系我们找货
