1N4728A-1N4764A
Green Products
Technical Data
Data Sheet N0183, Rev. A
1N4728A THRU 1N4764A Zener Diode
Zener Voltage:3.3-100V Peak Pulse Power:1000mW
Features:
Low zener impedance
Low reverse leakage
Power dissipation of 1000mW
High stability and high reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical data:
Case: DO-41 Glass Case
Polarity: Color band denotes cathode end
Mounting Position: Any
Mechanical Dimensions: In mm/Inches
DO-41
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
1N4728A-1N4764A
Green Products
Technical Data
Marking Diagram:
1N4728A
= Part Name
Cautions:Molding resin
Epoxy resin UL: 94V-0
Ordering Information:
Device
Package
DO-41
(Pb-Free)
1N4728A-1N4764A
Shipping
5000pcs / tape
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings @TA=25°C unless otherwise specified
Parameter
Power Dissipation (Note 1)
Forward Voltage
@ IF = 200mA
Typical Thermal resistance junction to
Ambient Air (Note 1)
Operating Junction and Storage
Temperature Range
Symbol
Value
Unit
PD
1000
mW
VF
1.2
V
RθJA
170
°C/W
TJ,TSTG
-65 to 200
°C
Notes: 1. Valid provided that leads are kept at ambient temperature at a distance of 8mm from case
1N4728A-1N4764A
Technical Data
Green Products
1N4728A-1N4764A
Technical Data
Green Products
1N4728A-1N4764A
Technical Data
Green Products
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“1N4738ATA”相匹配的价格&库存,您可以联系我们找货
