1N5263
1N5263
    SMCDIODESOLUTIONS(桑德斯)
    DO-35(DO-204AH)
    DIODEZENER56V500MWDO35
1N5263 数据手册
1N5225 Thru 1N5267 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0187, Rev. A Green Products 1N5225 THRU 1N5267 ZENER DIODES Features: z z z z z z z Silicon Planar Power Zener Diodes Standard Zener voltage tolerance is ± 5% with a “B” suffix. Other tolerances are available upon request. These diodes are also available in Mini-MELF case with the type designation ZMM5225 ... ZMM5267, SOT-23 case with the type designation MMBZ5265 ... MMBZ5267 and SOD-23 case with the types designation MMSZ5225 ... MMSZ5267. This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical data: z z z z z z Case: DO-35 Glass Case Terminals: Plated axial leads, solderable per LIL-STD 750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: approx. 0.14 grams Marking: Part Name, SSG and Date Code Mechanical Dimensions (In mm) and Marking: DO-35 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • 1N5225 Thru 1N5267 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0187, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL 1N5225 SSG YY WW L = Part Name = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device 1N5225-1N5267 Package DO-35 (Pb-Free) Shipping 5000pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings Ratings at 25°C ambient temperature unless otherwise specified. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS Technical Data Data Sheet N0187, Rev. A 1N5225 Thru 1N5267 Green Products NOTES: (1) The Zener impedance is derived from the 1 kHz AC voltage which results when an AC current having an RMS value equal to 10% of the Zener current (IZT or IZK) is superimposed on IZT or IZK. Zener impedance is measured at two points to insure a sharp knee on the breakdown curve and to eliminate unstable units (2) Valid provided that leads at a distance of 10 mm from case are kept at ambient temperature (3) Measured with device junction in thermal equilibrium • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS Technical Data Data Sheet N0187, Rev. A 1N5225 Thru 1N5267 Green Products • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS Technical Data Data Sheet N0187, Rev. A 1N5225 Thru 1N5267 Green Products DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.. • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
1N5263
物料型号:1N5225至1N5267
器件简介:这些是硅平面功率齐纳二极管,具有标准齐纳电压公差±5%(带有“B”后缀)。其他公差可以根据要求提供。这些二极管还提供Mini-MELF封装,类型为ZMM5225至ZMM5267,SOT-23封装,类型为MMBZ5265至MMBZ5267,以及SOD-23封装,类型为MMSZ5225至MMSZ5267。
引脚分配:DO-35玻璃封装,端子为镀层轴向引线,可按照LIL-STD 750,方法2026进行焊接。极性由色环表示,阴极端。
参数特性: - 齐纳电流:具体值见“特性”表。 - 在环境温度为75°C时的总功耗:500mW。 - 最大结温:200℃。 - 存储温度范围:-65至+200℃。 - 热阻(结到环境空气):最大300℃/W。 - 正向电压在IF=200mA时:最大1.1V。
功能详解:这些二极管具有稳定的齐纳电压,适用于电路中的电压稳定和过压保护。
应用信息:适用于需要电压稳定和过压保护的电路。
封装信息:提供DO-35、Mini-MELF、SOT-23和SOD-23封装。
订购信息:1N5225至1N5267的发货方式为每卷5000个。
1N5263 价格&库存
很抱歉,暂时无法提供与“1N5263”相匹配的价格&库存,您可以联系我们找货
