BUK6C3R3-75C,118
BUK6C3R3-75C,118
    NEXPERIA(安世)
    TO-263-7(D2PAK)
    MOSFET N-CH 75V 181A D2PAK
BUK6C3R3-75C,118 数据手册
BUK6C3R3-75C N-channel TrenchMOS intermediate level FET Rev. 3 — 18 January 2012 Product data sheet 1. Product profile 1.1 General description Intermediate level gate drive N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in high-performance automotive applications. 1.2 Features and benefits  AEC Q101 compliant  High current handling capability, up to 320 A  Low conduction losses due to very low on-state resistance  Suitable for standard and logic level gate drive sources  Suitable for thermally demanding environments due to 175 °C rating 1.3 Applications  12 V and 24 V automotive systems  Start-Stop micro-hybrid applications  Electric and electro-hydraulic power steering  Transmission control  Motors, lamps and solenoids  Ultra high performance power switching 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 75 V ID drain current VGS = 10 V; Tmb = 25 °C; see Figure 1 - - 181 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 300 W VGS = 10 V; ID = 90 A; Tj = 25 °C; see Figure 11 - 2.85 3.4 mΩ Static characteristics RDSon drain-source on-state resistance BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET Table 1. Quick reference data …continued Symbol Parameter Conditions Min Typ Max Unit ID = 25 A; VDS = 60 V; VGS = 10 V; see Figure 13; see Figure 14 - 76 - nC - - 560 mJ Dynamic characteristics QGD gate-drain charge Avalanche ruggedness EDS(AL)S non-repetitive ID = 120 A; Vsup < 75 V; drain-source avalanche RGS = 50 Ω; VGS = 10 V; energy Tj(init) = 25 °C; unclamped 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 S source 3 S source 4 D drain[1] 5 S source 6 S source 123 567 7 S source SOT427 (D2PAK) mb D mounting base; connected to drain [1] Simplified outline Graphic symbol mb D G mbb076 S 4 It is not possible to connect to pin 4 of the SOT427 package. 3. Ordering information Table 3. Ordering information Type number BUK6C3R3-75C BUK6C3R3-75C Product data sheet Package Name Description D2PAK plastic single-ended surface-mounted package (D2PAK); 7 leads SOT427 (one lead cropped) All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 Version © Nexperia B.V. 2017. All rights reserved 2 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C gate-source voltage VGS drain current ID Min Max Unit - 75 V Pulsed [1] -20 20 V DC [2] -16 16 V Tmb = 25 °C; VGS = 10 V; see Figure 1 - 181 A Tmb = 100 °C; VGS = 10 V; see Figure 1 - 128 A IDM peak drain current Tmb = 25 °C; pulsed; tp ≤ 10 µs; see Figure 3 - 723 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 300 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 181 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 723 A ID = 120 A; Vsup < 75 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped - 560 mJ Avalanche ruggedness non-repetitive drain-source avalanche energy EDS(AL)S [1] Accumulated pulse duration not to exceed 5mins. [2] -16V accumulated duration not to exceed 168 hrs. 003aaf928 200 ID (A) 03na19 120 Pder (%) 160 80 120 80 40 40 0 0 0 Fig 1. 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature BUK6C3R3-75C Product data sheet 0 50 100 150 200 Tmb (°C) Fig 2. Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 3 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 003a a f929 104 ID (A) 103 Limit RDSon = VDS / ID tp =10 μ s 102 100 μ s 10 DC 1 ms 1 10 ms 100 ms -1 10 10-1 Fig 3. 1 102 10 103 V DS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - - 0.5 K/W 003aaf930 1 Zth(j-mb) (K/W) δ = 0.5 0.2 10-1 0.1 0.05 0.02 δ= P 10-2 tp T single shot t tp T 10-3 10-6 Fig 4. 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration BUK6C3R3-75C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 4 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit - V Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 75 - ID = 250 µA; VGS = 0 V; Tj = -55 °C 68 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 9; see Figure 10 1.8 2.3 2.8 V VGSth gate-source threshold voltage ID = 2.5 mA; VDS = VGS; Tj = 175 °C; see Figure 10 0.8 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 10 - - 3.3 V - 0.04 1 µA IDSS drain leakage current VDS = 75 V; VGS = 0 V; Tj = 25 °C VDS = 75 V; VGS = 0 V; Tj = 175 °C - - 500 µA IGSS gate leakage current VGS = 20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 90 A; Tj = 25 °C; see Figure 11 - 2.85 3.4 mΩ VGS = 5 V; ID = 90 A; Tj = 25 °C; see Figure 11 - 3.35 4.3 mΩ VGS = 4.5 V; ID = 90 A; Tj = 25 °C; see Figure 11 - 3.7 5.1 mΩ VGS 10 V; ID = 90 A; Tj = 175 °C; see Figure 11; see Figure 12 - - 9.2 mΩ ID = 25 A; VDS = 60 V; VGS = 10 V; see Figure 13; see Figure 14 - 253 - nC ID = 25 A; VDS = 60 V; VGS = 5 V; see Figure 13; see Figure 14 - 140 - nC ID = 25 A; VDS = 60 V; VGS = 10 V; see Figure 13; see Figure 14 - 45 - nC - 76 - nC VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 15 - 11840 15800 pF - 873 1050 pF - 546 750 pF - 45 - ns - 217 - ns RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 384 - ns tf fall time - 165 - ns VDS = 40 V; RL = 0.4 Ω; VGS = 10 V; RG(ext) = 10 Ω Source-drain diode VSD source-drain voltage IS = 80 A; VGS = 0 V; Tj = 25 °C; see Figure 16 - 0.8 1.2 V trr reverse recovery time - 63 - ns Qr recovered charge IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 40 V - 165 - nC BUK6C3R3-75C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 5 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 003aaf931 300 ID (A) VGS (V) =10.0 5.0 003aaf932 240 4.5 ID (A) 240 180 180 4.0 120 120 3.8 60 3.6 60 Tj = 175 °C Tj = 25 °C 3.4 0 0 0 0.5 1 1.5 VDS (V) 2 0 2 4 VGS (V) 6 Tj = 25 °C; tp = 300 μs Fig 5. Output characteristics: drain current as a function of drain-source voltage; typical values Fig 6. 003aaf933 400 gfs (S) Transfer characteristics: drain current as a function of gate-source voltage; typical values 003aaf936 15 RDSon (mΩ) 300 10 200 5 100 0 0 0 Fig 7. 60 120 180 240 I D (A) 300 Forward transconductance as a function of drain current; typical values BUK6C3R3-75C Product data sheet 0 Fig 8. 5 10 15 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 6 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 003aad806 10-1 ID (A) 003aae542 4 VGS(th) (V) 10-2 min 10-3 typ 3 max @1mA 2 typ @1mA max -4 10 10-6 0 Fig 9. min @2.5mA 1 10-5 1 2 3 VGS (V) 0 -60 4 Sub-threshold drain current as a function of gate-source voltage 3.8 RDSon (mΩ) 4.0 60 120 Tj (°C) 180 Fig 10. Gate-source threshold voltage as a function of junction temperature 003aaf935 10 0 003aag555 3 a VGS (V) = 4.5 8 2.4 6 1.8 5.0 6.0 10.0 4 1.2 0.6 2 0 0 100 200 300 I D (A) 400 Fig 11. Drain-source on-state resistance as a function of drain current; typical values BUK6C3R3-75C Product data sheet 0 -60 0 60 120 Tj (°C) 180 Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 7 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 003aaf937 10 VDS = 60V VGS (V) VDS 8 ID 6 VGS(pl) VGS(th) 4 VGS QGS1 2 QGS2 QGS QGD QG(tot) 0 0 100 200 QG (nC) 003aaa508 300 Tj = 25 °C; ID = 25 A Fig 13. Gate-source voltage as a function of gate charge; typical values 003aaf934 105 Fig 14. Gate charge waveform definitions 003aaf938 250 IS (A) C (pF) 200 104 Ciss 150 100 103 Coss 102 10-1 1 10 VDS (V) 102 VGS = 0 V; f = 1 MHz Product data sheet Tj = 25 °C 0 0 0.3 0.6 0.9 VSD (V) 1.2 VGS = 0 V Fig 15. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values BUK6C3R3-75C Tj = 175 °C 50 Crss Fig 16. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 8 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 7. Package outline Plastic single-ended surface-mounted package (D2PAK); 7 leads (one lead cropped) SOT427 A A1 E D1 mounting base D HD 4 1 Lp 7 b e e e e e c e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A A1 b c D max. D1 E e Lp HD Q 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 1.27 2.90 2.10 15.80 14.80 2.60 2.20 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-03-09 06-03-16 SOT427 Fig 17. Package outline SOT427 (D2PAK) BUK6C3R3-75C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 9 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK6C3R3-75C v.3 20120118 Product data sheet - BUK6C3R3-75C v.2 - BUK6C3R3-75C v.1 Modifications: BUK6C3R3-75C v.2 BUK6C3R3-75C Product data sheet • Status changed from preliminary to product. 20111221 Preliminary data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 10 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET 9. Legal information 9.1 Data sheet status Document status [1] [2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. BUK6C3R3-75C Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 11 of 13 BUK6C3R3-75C Nexperia N-channel TrenchMOS intermediate level FET Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BUK6C3R3-75C Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 18 January 2012 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia BUK6C3R3-75C N-channel TrenchMOS intermediate level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 January 2012
BUK6C3R3-75C,118 价格&库存
很抱歉,暂时无法提供与“BUK6C3R3-75C,118”相匹配的价格&库存,您可以联系我们找货
