BUK7905-40AIE
N-channel TrenchPLUS standard level FET
Rev. 05 — 10 February 2009
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. The devices include TrenchPLUS current sensing
and diodes for ElectroStatic Discharge (ESD) protection. This product has been designed
and qualified to the appropriate AEC standard for use in automotive critical applications.
1.2 Features and benefits
Electrostatically robust due to
integrated protection diodes
Reduced component count due to
integrated current sensor
Low conduction losses due to low
on-state resistance
Suitable for standard level gate drive
sources
Q101 compliant
1.3 Applications
Electrical Power Assisted Steering
(EPAS)
Variable Valve Timing for engines
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C
ID
drain current
VGS = 10 V; Tmb = 25 °C;
see Figure 2; see Figure 3;
[1]
Min
Typ
Max
Unit
40
V
155
A
mΩ
Static characteristics
RDSon
drain-source
on-state resistance
VGS = 10 V; ID = 50 A;
Tj = 25 °C; see Figure 7; see
Figure 8
4.5
5
ID/Isense
ratio of drain current
to sense current
Tj > -55 °C; Tj < 175 °C;
VGS > 10 V
450
500
550
[1]
Current is limited by power dissipation chip rating.
BUK7905-40AIE
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
Simplified outline
1
G
gate
2
ISENSE
Sense current
3
D
drain
4
KS
Kelvin source
5
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
d
mb
g
Isense
MBL368
s
Kelvin source
12 3 4 5
SOT263B
(TO-220)
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
BUK7905-40AIE
TO-220
plastic single-ended package; heatsink mounted; 1 mounting hole; 5-lead SOT263B
TO-220
BUK7905-40AIE_5
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 15
BUK7905-40AIE
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
40
V
RGS = 20 kΩ
VDGR
drain-gate voltage
VGS
gate-source voltage
ID
drain current
Tmb = 25 °C; VGS = 10 V; see Figure 2; see Figure 3
Tmb = 100 °C; VGS = 10 V; see Figure 2
40
V
-20
V
[1]
155
A
[2]
75
A
[2]
75
A
IDM
peak drain current
Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3
620
A
Ptot
total power dissipation
Tmb = 25 °C; see Figure 1
272
W
IGS(CL)
gate-source clamping
current
continuous
10
mA
50
mA
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
[1]
155
A
[2]
75
A
620
A
1.46
J
6
kV
pulsed; tp = 5 ms; δ = 0.01
Source-drain diode
IS
ISM
source current
Tmb = 25 °C
peak source current
tp ≤ 10 µs; pulsed; Tmb = 25 °C
Avalance ruggedness
EDS(AL)S
non-repetitive
ID = 75 A; Vsup ≤ 40 V; RGS = 50 Ω; VGS = 10 V;
drain-source avalanche Tj(init) = 25 °C; unclamped
energy
Electrostatic discharge
Vesd
electrostatic discharge
voltage
HBM; C = 100 pF; R = 1.5 kΩ
[1]
[2]
Continuous current is limited by package.
BUK7905-40AIE_5
Product data sheet
3 of 15
BUK7905-40AIE
Nexperia
03na19
120
03ng16
160
ID
(A)
Pder
120
80
80
capped at 75A
due to package
40
40
100
150
200
100
150
Tmb (°C)
Fig 2.
Fig 1.
200
Tmb (°C)
Normalized total power dissipation as a
function of mounting base temperature
Continuous drain current as a function of
103
03ng17
ID
(A)
Limit RDSon = VDS/ID
tp = 10 µs
100 µs
102
Capped at 75 A due to package
1 ms
DC
10 ms
10
100 ms
1
1
Fig 3.
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
BUK7905-40AIE_5
Product data sheet
4 of 15
BUK7905-40AIE
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-a)
Rth(j-mb)
Conditions
Min
Typ
Max
Unit
thermal resistance from vertical in still air
junction to ambient
60
K/W
thermal resistance from see Figure 4
junction to mounting
base
0.55
K/W
03ni64
1
Z th(j-mb)
(K/W)
10-1
δ = 0.5
0.2
0.1
0.05
0.02
10-2
δ=
P
tp
T
single shot
t
tp
T
10-3
10-6
Fig 4.
10-5
10-4
10-3
10-2
10-1
1
tp (s)
10
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK7905-40AIE_5
Product data sheet
5 of 15
BUK7905-40AIE
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
VGS(th)
IDSS
V(BR)GSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
40
V
36
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 9
2
3
4
V
ID = 1 mA; VDS = VGS; Tj = 175 °C;
see Figure 9
1
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 9
4.4
V
VDS = 40 V; VGS = 0 V; Tj = 25 °C
0.1
10
µA
VDS = 40 V; VGS = 0 V; Tj = 175 °C
250
µA
V
IG = -1 mA; VDS = 0 V; Tj < 175 °C;
Tj > -55 °C
V
VDS = 0 V; VGS = 10 V; Tj = 25 °C
22
1000
nA
VDS = 0 V; VGS = -10 V; Tj = 25 °C
22
1000
nA
VDS = 0 V; VGS = 10 V; Tj = 175 °C
10
µA
VDS = 0 V; VGS = -10 V; Tj = 175 °C
10
µA
VGS = 10 V; ID = 50 A; Tj = 25 °C;
see Figure 7; see Figure 8
4.5
5
mΩ
VGS = 10 V; ID = 50 A; Tj = 175 °C;
9.5
mΩ
VGS = 10 V; ID = 100 mA; Tj = 25 °C;
see Figure 16
0.98
1.08
1.18
Ω
VGS = 10 V; ID = 100 mA; Tj = 175 °C;
see Figure 16
1.86
2.05
2.24
Ω
VGS > 10 V; Tj > -55 °C; Tj < 175 °C
450
500
550
ID = 25 A; VDS = 32 V; VGS = 10 V;
Tj = 25 °C; see Figure 14
120
127
nC
19
22
nC
50
60
nC
gate-source breakdown IG = 1 mA; VDS = 0 V; Tj < 175 °C;
voltage
Tj > -55 °C
gate leakage current
drain-source on-state
resistance
R(D-ISENSE)on drain-ISENSE on-state
resistance
ID/Isense
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
ratio of drain current to
sense current
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
tf
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C; see Figure 12
VDS = 30 V; RL = 1.2 Ω; VGS = 10 V;
RG(ext) = 10 Ω; Tj = 25 °C
4300
5000
pF
1400
1670
pF
820
1100
pF
35
ns
115
ns
turn-off delay time
155
ns
fall time
110
ns
BUK7905-40AIE_5
Product data sheet
6 of 15
BUK7905-40AIE
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
LD
internal drain
inductance
from upper edge of drain mounting base to
centre of die; Tj = 25 °C
2.5
nH
LS
internal source
inductance
from source lead to source bond pad;
Tj = 25 °C
7.5
nH
Source-drain diode
VSD
source-drain voltage
IS = 40 A; VGS = 0 V; Tj = 25 °C;
see Figure 17
0.85
1.2
V
trr
reverse recovery time
96
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V;
VDS = 30 V; Tj = 25 °C
224
nC
BUK7905-40AIE_5
Product data sheet
7 of 15
BUK7905-40AIE
Nexperia
03ni86
400
ID
(A)
Label is VGS (V)
10
8
RDSon
(mΩ)
7.5
03ni88
12
7
8
6.5
200
6
5.5
100
4
5
4.5
4
Fig 5.
2
4
6
8
10
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
4
Fig 6.
16
VGS (V)
Drain-source on-state resistance as a function
of gate-source voltage; typical values
03ni30
a
VGS = 5.5 V 6 V
RDSon
(mΩ)
12
2.0
03ni87
6.5 V
7V
1.6
15
1.2
10
0.8
8V
10 V
5
0.4
20 V
Fig 7.
100
200
−60
300 I (A) 400
D
of drain current; typical values
Fig 8.
60
120
180
Tj (°C)
Normalized drain-source on-state resistance
factor as a function of junction temperature
BUK7905-40AIE_5
Product data sheet
8 of 15
BUK7905-40AIE
Nexperia
03aa32
5
ID
(A)
VGS(th)
(V)
4
typ
max
10−3
typ
2
min
10−2
max
3
10−4
min
10−5
1
−60
Fig 9.
03aa35
10−1
10−6
120
2
4
6
Tj (°C)
VGS (V)
Gate-source threshold voltage as a function of
Fig 10. Sub-threshold drain current as a function of
gate-source voltage
03ne67
8
03ni89
90
C
(nF)
gfs
(S)
6
60
Ciss
4
30
2
Coss
Crss
50
75
100
10−1
1
102
10
ID (A)
VDS (V)
Fig 11. Forward transconductance as a function of
Fig 12. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
BUK7905-40AIE_5
Product data sheet
9 of 15
BUK7905-40AIE
Nexperia
03ni26
10
03ni90
100
VGS
(V)
ID
(A)
8
75
VDS = 14 V
6
32 V
50
4
175 °C
25
Tj = 25 °C
2
4
VGS (V)
40
80
120
QG (nC)
Fig 13. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
03nn69
600
Fig 14. Gate-source voltage as a function of turn-on
gate charge; typical values
03nk33
4
RD(Is)on
(Ω)
ID/Isense
550
3
500
2
450
1
400
8
12
16 V
GS (V)
Fig 15. Drain-sense current ratio as a function of
4
8
VGS (V)
10
Fig 16. Drain-sense current on-state resistance as a
BUK7905-40AIE_5
Product data sheet
6
10 of 15
BUK7905-40AIE
Nexperia
03ni91
100
ID
(A)
80
60
40
175 °C
Tj = 25 °C
0.4
0.8
1.2
VSD (V)
1.6
Fig 17. Drain current as a function of source-drain diode voltage; typical values
BUK7905-40AIE_5
Product data sheet
11 of 15
BUK7905-40AIE
Nexperia
7. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 5-lead TO-220
SOT263B
E
p1
A
∅p
A1
q
D1
mounting
base
D
L1
Q
L2
m
L
1
5
e
b
c
w M
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
c
D
D1
E
e
L
mm
4.5
4.1
1.39
1.27
0.85
0.70
0.7
0.4
15.8
15.2
6.4
5.9
10.3
9.7
1.7
15.0
13.5
L1
(1)
2.4
1.6
(2)
L2
0.5
m
∅p
p1
q
Q
w
0.8
0.6
3.8
3.6
4.3
4.1
3.0
2.7
2.6
2.2
0.4
Notes
1. Terminal dimensions are uncontrolled in this zone.
2. Positional accuracy of the terminals is controlled in this zone.
OUTLINE
VERSION
SOT263B
REFERENCES
IEC
JEDEC
EIAJ
EUROPEAN
PROJECTION
ISSUE DATE
01-01-11
5-lead TO-220
Fig 18. Package outline SOT263B (TO-220)
BUK7905-40AIE_5
Product data sheet
12 of 15
BUK7905-40AIE
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK7905-40AIE_5
20090210
Product data sheet
BUK71_7905_40AIE-04
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Type number BUK7905-40AIE separated from data sheet BUK71_7905_40AIE-04.
BUK71_7905_40AIE-04
20040206
Product data
BUK71_7905_40AIE-03
BUK71_7905_40AIE-03
20030523
Product data
BUK71_7905_40AIE-02
BUK71_7905_40AIE-02
20021001
Product data
BUK71_7905_40AIE-01
BUK71_7905_40AIE-01
20020725
Product data
BUK7905-40AIE_5
Product data sheet
13 of 15
BUK7905-40AIE
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BUK7905-40AIE_5
Product data sheet
14 of 15
Nexperia
BUK7905-40AIE
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .13
Legal information. . . . . . . . . . . . . . . . . . . . . . . .14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14
Contact information. . . . . . . . . . . . . . . . . . . . . .14
Date of release: 10 February 2009
很抱歉,暂时无法提供与“BUK7905-40AIE,127”相匹配的价格&库存,您可以联系我们找货
