BLM7G1822S-80ABGY
BLM7G1822S-80ABGY
    AMPLEON(安谱隆)
    SOT-1212-1
    IC MMIC DUAL 2-STAGE 16HSOP
BLM7G1822S-80ABGY 数据手册
BLM7G1822S-80AB; BLM7G1822S-80ABG LDMOS 2-stage power MMIC Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description The BLM7G1822S-80AB(G) is a dual section, asymmetric, 2-stage power MMIC using Ampleon’s state of the art GEN7 LDMOS technology. This multiband device is perfectly suited as small cell final stage in Doherty configuration, or as general purpose driver in the 1805 MHz to 2170 MHz frequency range. Available in gull wing or straight lead outline. Table 1. Performance Typical RF performance at Tcase = 25 C. Test signal: 3GPP test model 1; 64 DPCH; PAR = 9.9 dB at 0.01% probability on CCDF; specified in a class-AB production circuit. f IDq1 [1] IDq2 [1] VDS PL(AV) Gp D ACPR5M (MHz) (mA) (mA) (V) (W) (dB) (%) (dBc) carrier section 2167.5 40 120 28 4 30 24 39.5 peaking section 2167.5 80 240 28 8 28.3 24 36 Test signal single carrier W-CDMA [1] IDq1 represents driver stage; IDq2 represents final stage. 1.2 Features and benefits           Designed for broadband operation (frequency 1805 MHz to 2170 MHz) High section-to-section isolation enabling multiple combinations High Doherty efficiency thanks to 2 : 1 asymmetry Integrated temperature compensated bias Biasing of individual stages is externally accessible Integrated ESD protection Excellent thermal stability High power gain On-chip matching for ease of use Compliant to Directive 2002/95/EC, regarding restriction of hazardous substances (RoHS) 1.3 Applications  RF power MMIC for W-CDMA base stations in the 1805 MHz to 2170 MHz frequency range. Possible circuit topologies are the following as also depicted in Section 8.1:  Asymmetric final stage in Doherty configuration  Asymmetric driver for high power Doherty amplifier BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 2. Pinning information 2.1 Pinning pin 1 index VDS(A1) VGS(A2) VGS(A1) RF_IN_A n.c. n.c. n.c. n.c. n.c. n.c. RF_IN_B VGS(B1) VGS(B2) VDS(B1) 1 2 3 4 5 6 7 16 RF_OUT_A / VDS(A2) 8 9 10 11 12 13 14 15 RF_OUT_B / VDS(B2) aaa-009322 Transparent top view The exposed backside of the package is the ground terminal of the device. Fig 1. Pin configuration 2.2 Pin description Table 2. Pin description Symbol Pin Description VDS(A1) 1 drain-source voltage of carrier section, driver stage (A1) VGS(A2) 2 gate-source voltage of carrier section, final stage (A2) VGS(A1) 3 gate-source voltage of carrier section, driver stage (A1) RF_IN_A 4 RF input carrier section (A) n.c. 5 not connected n.c. 6 not connected n.c. 7 not connected n.c. 8 not connected n.c. 9 not connected n.c. 10 not connected RF_IN_B 11 RF input peaking section (B) VGS(B1) 12 gate-source voltage of peaking section, driver stage (B1) VGS(B2) 13 gate-source voltage of peaking section, final stage (B2) VDS(B1) 14 drain-source voltage of peaking section, driver stage (B1) BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC Table 2. Pin description …continued Symbol Pin Description RF_OUT_B/VDS(B2) 15 RF output peaking section (B) / drain-source voltage of peaking section, final stage (B2) RF_OUT_A/VDS(A2) 16 RF output carrier section (A) / drain-source voltage of carrier section, final stage (A2) GND flange RF ground 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLM7G1822S-80AB HSOP16F plastic, heatsink small outline package; 16 leads (flat) SOT1211-2 BLM7G1822S-80ABG HSOP16 plastic, heatsink small outline package; 16 leads SOT1212-2 4. Block diagram VDS(A1) carrier RF_IN_A RF_OUT_A / VDS(A2) VGS(A1) VGS(A2) TEMPERATURE COMPENSATED BIAS VGS(B1) VGS(B2) TEMPERATURE COMPENSATED BIAS RF_OUT_B / VDS(B2) RF_IN_B VDS(B1) peaking aaa-016004 Fig 2. Block diagram 5. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C - 225 C - 150 C Tj junction temperature Tcase case temperature [1] [1] Continuous use at maximum temperature will affect the reliability. For details refer to the online MTF calculator. BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 6. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Value Unit Carrier section Rth(j-c) thermal resistance from junction to case final stage; Tcase = 90 C; PL = 1.26 W [1] 2.4 K/W driver stage; Tcase = 90 C; PL = 1.26 W [1] 7.6 K/W final stage; Tcase = 90 C; PL = 2.52 W [1] 1.5 K/W driver stage; Tcase = 90 C; PL = 2.52 W [1] 5.5 K/W Peaking section Rth(j-c) [1] thermal resistance from junction to case When operated with a CW signal. 7. Characteristics Table 6. DC characteristics Tcase = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VGS = 0 V; ID = 0.302 mA 65 - - V VDS = 28 V; ID = 120 mA 1.6 2 2.45 V Carrier section Final stage V(BR)DSS drain-source breakdown voltage VGSq gate-source quiescent voltage VDS = 28 V; ID = 120 mA [1] 1.9 2.6 3.3 V [1] - 1.5 - % IDq/T quiescent drain current variation with temperature Tcase = 40 C to +85 C IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 1.4 A IDSX drain cut-off current VGS = 5.55 V; VDS = 10 V - 5.4 - A IGSS gate leakage current VGS = 1.0 V; VDS = 0 V - - 140 nA Driver stage V(BR)DSS drain-source breakdown voltage VGSq gate-source quiescent voltage VGS = 0 V; ID = 0.058 mA 65 - - V VDS = 28 V; ID = 40 mA 1.7 2.1 2.55 V VDS = 28 V; ID = 40 mA [2] 1.9 2.6 3.2 V [2] - 1.5 - % IDq/T quiescent drain current variation with temperature Tcase = 40 C to +85 C IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 1.4 A IDSX drain cut-off current VGS = 5.55 V; VDS = 10 V - 1.05 - A IGSS gate leakage current VGS = 1.0 V; VDS = 0 V - - 140 nA VGS = 0 V; ID = 0.604 mA 65 - - V 1.6 2.15 2.6 V 2 3 3.8 V Peaking section Final stage V(BR)DSS drain-source breakdown voltage VGSq gate-source quiescent voltage VDS = 28 V; ID = 240 mA VDS = 28 V; ID = 240 mA [3] [3] IDq/T quiescent drain current variation with temperature Tcase = 40 C to +85 C - 2 - % IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 1.4 A IDSX drain cut-off current VGS = 5.55 V; VDS = 10 V - 11 - A IGSS gate leakage current VGS = 1.0 V; VDS = 0 V - - 140 nA BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC Table 6. DC characteristics …continued Tcase = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Driver stage V(BR)DSS drain-source breakdown voltage VGSq gate-source quiescent voltage VGS = 0 V; ID = 0.116 mA 65 - - V VDS = 28 V; ID = 80 mA 1.7 2.15 2.55 V VDS = 28 V; ID = 80 mA [4] 2 2.7 3.3 V [4] - 2 - % IDq/T quiescent drain current variation with temperature Tcase = 40 C to +85 C IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 1.4 A IDSX drain cut-off current VGS = 5.55 V; VDS = 10 V - 1.9 - A IGSS gate leakage current VGS = 1.0 V; VDS = 0 V - - 140 nA [1] In production circuit with 825  gate feed resistor. [2] In production circuit with 850  gate feed resistor. [3] In production circuit with 1205  gate feed resistor. [4] In production circuit with 460  gate feed resistor. Table 7. RF Characteristics Typical RF performance at f = 2167.5 MHz; Tcase = 25 C; VDS = 28 V; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 120 mA (carrier section, final stage); PL(AV) = 4 W (carrier section); IDq1 = 80 mA (peaking section, driver stage); IDq2 = 240 mA (peaking section, final stage); PL(AV) = 8 W (peaking section) unless otherwise specified, measured in an Ampleon straight lead production circuit. Symbol Parameter Conditions Min Typ Max Unit Carrier section Test signal: single carrier W-CDMA [1] Gp power gain 29.5 31 32.5 dB D drain efficiency 21 24 - % RLin input return loss - 13.5 10 dB ACPR5M adjacent channel power ratio (5 MHz) - 39.5 36.5 dBc PARO output peak-to-average ratio 7 7.8 - dB Peaking section Test signal: single carrier W-CDMA [1] Gp power gain 26.8 28.3 29.8 dB D drain efficiency 20 24 - % RLin input return loss - 20 10 dB ACPR5M adjacent channel power ratio (5 MHz) - 36 31 dBc PARO output peak-to-average ratio 5.2 7 - dB Test signal: CW [2] s21 phase response difference normalized; between sections 15 - +15 deg s212 insertion power gain difference normalized; between sections 0.6 - +0.6 dB [1] 3GPP test model 1; 64 DPCH; PAR = 9.9 dB at 0.01% probability on CCDF. [2] f = 2170 MHz. BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 8. Application information Table 8. Doherty typical performance Test signal: 1-tone CW; RF performance at Tcase = 25 C; VDS = 28 V; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 90 mA (carrier section, final stage); IDq1 = 20 mA (peaking section, driver stage); VGS = 0.9 V (peaking section, final stage); unless otherwise specified, measured in an Ampleon, f = 1805 MHz to 1880 MHz, Doherty application circuit (see Figure 3 and Figure 4). Symbol Parameter Conditions Min Typ Max Unit PL(3dB) output power at 3 dB gain compression f = 1842.5 MHz; 1-tone pulsed CW (10 % duty cycle) - 89 - W D drain efficiency at PL(3dB); f = 1842.5 MHz; 1-tone pulsed CW (10 % duty cycle) - 52.5 - % Gp power gain PL(AV) = 14.12 W; f = 1842.5 MHz - 26.3 - dB Bvideo video bandwidth PL(AV) = 6.3 W; f = 1842.5 MHz; 2-tone CW - 70 - MHz Gflat gain flatness PL(AV) = 14.12 W - 0.5 - dB K Rollett stability factor Tcase = 40 C; f = 0.1 GHz to 3 GHz - >1 - [1] [1] For carrier and peaking sections (S-parameters measured with load-pull jig). 0Ω 0Ω 0Ω 0Ω 100 Ω 24 pF 820 Ω BLM7G1822S-80AB 820 Ω 24 pF 24 pF 820 Ω 100 Ω 100 Ω 100 pF 100 Ω 820 Ω 10 μF 100 pF 100 Ω 0Ω 0Ω 470 μF 100 pF 10 μF 10 μF 100 pF 10 μF 10 μF 10 μF 100 Ω 0.4 pF 24 pF 24 pF 0.4 pF 24 pF 10 μF 10 μF 0Ω 0Ω 470 μF aaa-016005 Printed-Circuit Board (PCB): Rogers 4350; thickness = 0.508 mm. Fig 3. Component layout BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 18 xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxx x x x xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xx xx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxx x x xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxx xxx BLM7G1822S-80AB_S-80ABG#3 Product data sheet VGS (carrier) 2.65 V VDS (carrier / driver) 28 V 10 μF 50 V 100 Ω 10 μF 50 V 10 pF ATC 600F VGS (carrier / final) 820 Ω VGS(A2) 2 VGS(A1) 3 10 pF ATC 600F 820 Ω RF_IN_A 4 n.c. n.c. 24 pF ATC 600F n.c. Driver clamped RF FET 10 μF 50 V Final clamped RF FET 24 pF ATC 600F 5 6 7 0.4 pF ATC 600F 16 RF_OUT_A/VDS(A2) Driver RF power FET 24 pF ATC 600F Final RF power FET 24 pF ATC 600F X3C19P1-05 n.c. 100 Ω RF in 100 Ω 24 pF ATC 600F n.c. n.c. Driver RF power FET 8 15 RF_OUT_B/VDS(B2) 10 μF 50 V V GS (peaking / driver) 100 Ω 10 pF ATC 600F Driver clamped RF FET Final clamped RF FET 10 μF 50 V 24 pF ATC 600F VGS(B1) 12 820 Ω VGS(B2) 13 470 μF 35 V 7 of 18 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 pF ATC 600F V DS(B1) 14 Peaking section Electrical schematic VDS (peaking / driver) 28 V BLM7G1822S-80AB VDS (peaking / final) 28 V aaa-016007 LDMOS 2-stage power MMIC 820 Ω 10 μF 50 V VGS (peaking) 2.5 V RF out 10 V GS (peaking / final) 10 μF 50 V Fig 4. 0.4 pF ATC 600F 9 RF_IN_B 11 100 Ω Final RF power FET BLM7G1822S-80AB(G) Rev. 3 — 1 September 2015 All information provided in this document is subject to legal disclaimers. 10 μF 50 V 470 μF 35 V Carrier section BLM7G1822S-80AB V DS(A1) 1 V GS (carrier / driver) 100 Ω VDS (carrier / final) 28 V BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 8.1 Possible circuit topologies -3 dB / Φ-0° In A Out A -3 dB / Φ-0° In B Out B aaa-016006 Fig 5. Dual section Splitter Combiner In -3 dB / Φ-0° λ/4 λ/4 -3 dB / Φ-90° Out aaa-009325 Fig 6. Doherty 8.2 Ruggedness in class-AB operation The BLM7G1822S-80AB and BLM7G1822S-80ABG are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: f = 2140 MHz; VDS = 32 V; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 120 mA (carrier section, final stage); IDq1 = 80 mA (peaking section, driver stage); IDq2 = 180 mA (peaking section, final stage); Pi = 16 dBm (carrier section); Pi = 22 dBm (peaking section). Pi is measured at CW and corresponding to PL(3dB) under ZS = 50  load. BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 8.3 Impedance information Table 9. Typical impedance Measured load-pull data at 3 dB gain compression point; test signal: pulsed CW; Tcase = 25 C; VDS = 28 V; tp = 100 s;  = 10 %; ZS = 50 ; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 110 mA (carrier section, final stage); IDq1 = 80 mA (peaking section, driver stage); IDq2 = 200 mA (peaking section, final stage). Typical values unless otherwise specified. tuned for maximum output power tuned for maximum power added efficiency f ZL Gp(max) PL add AM-PM ZL conversion Gp(max) PL add AM-PM conversion (MHz) () (dB) (%) (deg) (dB) (W) (%) (deg) (W) () Carrier section BLM7G1822S-80AB 1805 7.7  j10.6 32.2 45.8 51 0.3 16.7  j4.2 33.5 43.9 58.8 4.9 1842.5 7.8  j10.6 32.3 45.8 51.8 0.9 16.2  j5.6 33.4 44 58.5 3 1880 7.7  j10.6 32.3 45.8 52.1 1.4 12.2  j4.6 33.4 44.5 58.4 2.8 1930 6.7  j10.8 32 45.7 48.8 0.3 11.6  j3.4 33.5 44.1 57.7 4.3 1960 7.8  j10.6 32.6 45.7 51.4 1.6 9.9  j4.4 33.6 44.6 57.6 2.3 1990 6.3  j9.5 32.5 45.7 49.1 0.5 8.6  j4.3 33.6 44.6 57 3.1 2110 6.3  j9.5 33 45.8 51.4 4 7.3  j4.8 33.8 44.6 56.4 4.4 2140 6.3  j9.5 33 45.7 51.8 5.9 7.3  j4.8 33.8 44.5 56.2 5.4 2170 6.8  j10.8 32.8 45.6 50.1 7.5 7.0  j6.3 33.6 44.9 56.5 7 BLM7G1822S-80ABG 1805 8.0  j13.4 31.8 45.8 50.3 1.7 14.8  j8.7 33 44.6 58.1 5.5 1842.5 8.0  j13.4 31.9 45.8 49.2 1 16.3  j4.3 33.3 44.7 57.5 7.4 1880 8.0  j13.4 32.1 45.8 50 0.3 12.7  j7.1 33.2 44.5 57.3 4.3 1930 8.0  j13.4 32.1 45.8 50.3 0.6 12.8  j7.3 33.2 44.4 56.3 3.4 1960 8.0  j13.4 32.4 45.7 49.9 0.4 11.1  j6.8 33.5 44.5 56.1 3.6 1990 7.7  j15.2 32.2 45.7 47 0.7 9.0  j7.7 33.4 44.8 55.9 3.4 2110 8.1  j13.4 33 45.8 52.1 6.1 7.6  j8.0 33.6 44.7 56.1 6.7 2140 6.5  j12.8 32.7 45.7 50.8 8.9 7.6  j8.0 33.5 44.5 55.7 7.7 2170 7.0  j14.1 32.4 45.6 49.1 10 8.6  j9.0 33.3 44.8 55.8 7.8 Peaking section BLM7G1822S-80AB 1810 2.6  j5.9 29.2 48.6 49.6 2.7 5.4  j5.1 30.3 47.4 56.4 5.6 1840 2.7  j5.8 29.9 48.5 49.3 3.8 4.9  j4.8 30.9 47.5 56.3 6.2 1880 2.6  j5.8 29.6 48.5 48.5 2.4 4.8  j4.3 30.6 47.4 55.3 5 1930 2.6  j5.8 29.9 48.4 47.9 1.1 4.3  j4.2 30.8 47.4 54.3 2.9 1960 2.6  j5.8 29.9 48.4 48 1 4.2  j4.2 30.8 47.5 54.3 2.2 1990 2.6  j5.7 29.6 48.3 47.5 2.1 3.6  j4.0 30.4 47.4 53.8 3.9 2110 2.6  j5.8 29.8 48.3 48.3 3.6 3.1  j4.1 30.2 47.4 52.6 4.7 2140 2.6  j5.8 29.8 48.3 48.6 4.1 3.1  j4.7 30.3 47.6 51.9 3.9 2170 2.6  j5.8 29.5 48.2 46 5.4 2.6  j4.7 30.1 47.5 51.2 6.4 BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC Table 9. Typical impedance …continued Measured load-pull data at 3 dB gain compression point; test signal: pulsed CW; Tcase = 25 C; VDS = 28 V; tp = 100 s;  = 10 %; ZS = 50 ; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 110 mA (carrier section, final stage); IDq1 = 80 mA (peaking section, driver stage); IDq2 = 200 mA (peaking section, final stage). Typical values unless otherwise specified. tuned for maximum output power tuned for maximum power added efficiency f ZL Gp(max) PL add AM-PM ZL conversion Gp(max) PL add AM-PM conversion (MHz) () (dB) (W) (%) (deg) () (dB) (W) (%) (deg) BLM7G1822S-80ABG 1810 3.0  j8.9 29.3 48.4 50.6 1.7 5.3  j7.6 30.3 47.5 57.5 5.3 1840 2.7  j8.7 29.1 48.3 48.4 4.4 5.0  j7.5 30.2 47.5 56.9 7.5 1880 3.0  j8.8 29.4 48.4 50.5 2.3 4.7  j7.1 30.3 47.4 56.4 5.1 1930 2.7  j9.0 29.6 48.4 48.7 2.7 4.4  j7.0 30.6 47.4 56.1 5.5 1960 2.7  j9.0 29.6 48.4 48.7 2.7 4.0  j6.8 30.6 47.4 55.9 5.3 1990 2.7  j8.9 29.7 48.4 48 2 3.8  j7.1 30.6 47.5 55 3.7 2110 2.7  j9.5 29.9 48.5 49.5 3.4 2.8  j7.6 30.6 47.6 54.9 4.2 2140 2.6  j9.5 29.9 48.3 49.1 4 2.6  j7.9 30.5 47.6 53.7 3.2 2170 2.4  j9.7 29.7 48.3 47.4 5.5 2.6  j8.2 30.5 47.7 53 4.6 8.4 Graphs aaa-015648 29 Gp (dB) -3 aaa-015649 28 RLin (dB) Gp (dB) 0 RLin (dB) (1) 27 (1) 25 -11 26 -19 24 -10 -20 (2) (2) 23 21 1700 1750 1800 -27 1850 1900 1950 f (MHz) 22 -35 2000 -30 20 -40 1800 1810 1820 1830 1840 1850 1860 1870 1880 f (MHz) Tcase = 25 C; VDS = 28 V; PL = 7.6 W; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 90 mA (carrier section, final stage); IDq1 = 20 mA (peaking section, driver stage); VGS = 0.9 V (peaking section, final stage). Tcase = 25 C; VDS = 28 V; PL = 7.6 W; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 90 mA (carrier section, final stage); IDq1 = 20 mA (peaking section, driver stage); VGS = 0.9 V (peaking section, final stage). Test signal: CW. Test signal: CW. (1) magnitude of Gp (1) magnitude of Gp (2) magnitude of RLin (2) magnitude of RLin Fig 7. Wideband power gain and input return loss as function of frequency; typical values Fig 8. In-band power gain and input return loss as function of frequency; typical values BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC aaa-015672 29 80 Gp (dB) ηD . (%) 27 Gp (1) (2) (3) 25 23 (. aaa-015671 2 φs21/φs21(norm) (deg) 60 0 40 -2 20 -4 0 -6 (1) (2) (3) ηD 21 25 30 35 40 45 PL (dBm) 50 20 Tcase = 25 C; VDS = 28 V; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 90 mA (carrier section, final stage); IDq1 = 20 mA (peaking section, driver stage); VGS = 0.9 V (peaking section, final stage). 25 30 40 45 PL (dBm) 50 Tcase = 25 C; VDS = 28 V; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 90 mA (carrier section, final stage); IDq1 = 20 mA (peaking section, driver stage); VGS = 0.9 V (peaking section, final stage). Test signal: pulsed CW (tp = 200 s;  = 10 %). Test signal: pulsed CW (tp = 200 s;  = 10 %). (1) f = 1805 MHz (1) f = 1805 MHz (2) f = 1842.5 MHz (2) f = 1842.5 MHz (3) f = 1880 MHz (3) f = 1880 MHz Fig 9. 35 Power gain and drain efficiency as function of output power; typical values Fig 10. Normalized phase response as a function of output power; typical values aaa-015673 -10 IMD (dBc) (1) (2) IMD3 -30 IMD5 (1) (2) IMD7 (1) (2) -50 -70 -90 1 10 102 tone spacing (MHz) 103 Tcase = 25 C; VDS = 28 V; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 90 mA (carrier section, final stage); IDq1 = 20 mA (peaking section, driver stage); VGS = 0.9 V (peaking section, final stage). Test signal: 2-tone CW (fc = 1842.5 MHz). (1) IMD low (2) IMD high Fig 11. Intermodulation distortion as a function of tone spacing; typical values BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC aaa-015674 -25 ACPR (dBc) 45 ηD (%) -35 35 -45 25 ACPR5M -55 15 ηD -65 5 ACPR10M -75 -5 28 30 32 34 36 38 40 PL (dBm) 42 Tcase = 25 C; VDS = 28 V; IDq1 = 40 mA (carrier section, driver stage); IDq2 = 90 mA (carrier section, final stage); IDq1 = 20 mA (peaking section, driver stage); VGS = 0.9 V (peaking section, final stage). Test signal: 3GPP test model 1; 64 DPCH; PAR = 9.9 dB at 0.01 % probability on CCDF; f = 1842.5 MHz. Fig 12. Adjacent channel power ratio and drain efficiency as function of output power; typical values BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 9. Package outline HSOP16F: plastic, heatsink small outline package; 16 leads(flat) SOT1211-2 D E X c D3 E3 B y A HE v A D1 D2 e1 b1(2x) w 16 B 15 (8x) METAL PROTRUSIONS (SOURCE) e6 (2x) F(16x) e5 (2x) E2 A E1 A2 Q1 pin 1 index A1 detail X 1 14 b(14x) e2 w B e (12x) e3 (2x) HE e4 (2x) 0 Q1 v w y 16.16 1.62 0.1 15.96 1.57 0.25 0.25 15.76 1.52 10 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A 3.9 A1 A2 b b1 c D(1) D1 D2 D3 E(1) E1 E2 E3 e e1 e2 0.2 3.65 0.40 5.55 0.27 20.62 19.00 16.05 20.44 10.01 8.18 5.89 9.83 0.1 3.60 0.35 5.50 0.22 20.57 18.95 16.00 20.39 9.96 8.13 5.84 9.78 1.0 7.45 1.5 0 3.55 0.30 5.45 0.17 20.52 18.90 15.95 20.34 9.91 8.08 5.79 9.73 e3 e4 References IEC JEDEC JEITA e6 F 8.45 9.55 2.97 4.07 0.2 Note 1. Package body dimensions “D and “E do not include mold and metal protrusions. Allowable protrusion is 0.25 mm per side. 2. Lead width dimensions “b and “ b1 do not include dambar protrusions. Allowable dambar protrusion is 0.25 mm in total per lead. Outline version e5 European projection sot1211-2_po Issue date 15-01-12 15-06-09 SOT1211-2 Fig 13. Package outline SOT1211-2 (HSOP16F) BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC HSOP16: plastic, heatsink small outline package; 16 leads SOT1212-2 E X E3 A D c B D3 y v HE A D1 D2 e1 b1(2x) w 16 B (8x) METAL PROTRUSIONS (SOURCE) 15 e6 e5 (2x) (2x) Q E2 E1 A A2 (A3) A1 A4 pin 1 index θ 1 H 14 Lp detail X e2 e (12x) b (14x) w B e3 (2x) e4 (2x) HE 0 Unit mm max nom min A 3.9 A1 A2 A3 A4 b b1 c D(1) 10 mm D1 D2 D3 E(1) Q v w E1 E2 E3 e e1 e2 e3 e4 e5 θ 7° 3° 0° e6 0.2 3.65 0.06 0.40 5.55 0.27 20.62 19.00 16.05 20.44 10.01 8.18 5.89 9.83 0.1 3.60 0.35 0 0.35 5.50 0.22 20.57 18.95 16.00 20.39 9.96 8.13 5.84 9.78 1.0 7.45 1.5 8.45 9.55 2.97 4.07 0 3.55 -0.02 0.30 5.45 0.17 20.52 18.90 15.95 20.34 9.91 8.08 5.79 9.73 Note 1. Package body dimensions “D'' and `'E'' do not include mold and metal protrusions. Allowable protrusion is 0.25 mm per side. 2. Lead width dimensions `'b'' and `'b1'' do not include dambar protrusions. Allowable dambar protrusion is 0.25 mm in total per lead. 3. Dimension A4 is measured with respect to bottom of the heatsink DATUM H. Positive value means that the bottom of the heatsink is higher than the bottom of the lead. Outline version y 13.5 1.10 2.07 0.1 13.2 0.95 2.02 0.25 0.25 12.9 0.80 1.97 scale Dimensions (mm are the original dimensions) Lp References IEC JEDEC JEITA European projection sot1212-2_po Issue date 15-01-14 15-06-09 SOT1212-2 Fig 14. Package outline SOT1212-2 (HSOP16) BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 10. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 11. Abbreviations Table 10. Abbreviations Acronym Description AM Amplitude Modulation 3GPP 3rd Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge GEN7 Seventh Generation LDMOS Laterally Diffused Metal Oxide Semiconductor MMIC Monolithic Microwave Integrated Circuit MTF Median Time to Failure PAR Peak-to-Average Ratio PM Phase Modulation VSWR Voltage Standing-Wave Ratio W-CDMA Wideband Code Division Multiple Access 12. Revision history Table 11. Revision history Document ID Release date Data sheet status BLM7G1822S-80AB_S-80ABG#3 20150901 Product data sheet Modifications: Change notice Supersedes BLM7G1822S-80AB_S -80ABG v.2 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLM7G1822S-80AB_S-80ABG v.2 20150701 Product data sheet - BLM7G1822S-80AB_ S-80ABG v.1 BLM7G1822S-80AB_S-80ABG v.1 20141128 Product data sheet - - BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 15 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 16 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLM7G1822S-80AB_S-80ABG#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 17 of 18 BLM7G1822S-80AB(G) LDMOS 2-stage power MMIC 15. Contents 1 1.1 1.2 1.3 2 2.1 2.2 3 4 5 6 7 8 8.1 8.2 8.3 8.4 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 6 Possible circuit topologies . . . . . . . . . . . . . . . . 8 Ruggedness in class-AB operation . . . . . . . . . 8 Impedance information . . . . . . . . . . . . . . . . . . . 9 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Handling information. . . . . . . . . . . . . . . . . . . . 15 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLM7G1822S-80AB_S-80ABG#3
BLM7G1822S-80ABGY 价格&库存
很抱歉,暂时无法提供与“BLM7G1822S-80ABGY”相匹配的价格&库存,您可以联系我们找货
