BT151-500RT,127
BT151-500RT,127
    WEEN(瑞能)
    TO-220-3
    THYRISTOR 12A 500V TO220AB
BT151-500RT,127 数据手册
BT151-500RT SCR 22 February 2018 Product data sheet 1. General description Planar passivated Silicon Controlled Rectifier (SCR) in a SOT78 (TO-220AB) plastic package intended for use in applications requiring good bidirectional blocking voltage capability, high surge current capability, high junction temperature capability and high thermal cycling performance. 2. Features and benefits • • • • • Good bidirectional blocking voltage capability High junction operating temperature capability High surge current capability High thermal cycling performance Planar passivated for voltage ruggedness and reliability 3. Applications • • • • • Capacitive Discharge Ignition (CDI) Crowbar protection Inrush protection Motor control Voltage regulation 4. Quick reference data Table 1. Quick reference data Symbol Parameter VDRM Conditions Min Typ Max Unit repetitive peak offstate voltage - - 500 V VRRM repetitive peak reverse voltage - - 500 V ITSM non-repetitive peak on- half sine wave; Tj(init) = 25 °C; tp = 8.3 ms state current - - 132 A half sine wave; Tj(init) = 25 °C; tp = 10 ms; Fig. 4; Fig. 5 - - 120 A - - 150 °C Tj junction temperature IT(AV) average on-state current half sine wave; Tmb ≤ 133 °C - - 8 A IT(RMS) RMS on-state current half sine wave; Tmb ≤ 133 °C; Fig. 1; Fig. 2; Fig. 3 - - 12.5 A VD = 12 V; IT = 0.1 A; Tj = 25 °C; Fig. 7 - 2 15 mA Static characteristics IGT gate trigger current BT151-500RT WeEn Semiconductors SCR Symbol Parameter Conditions Min Typ Max Unit VDM = 335 V; Tj = 150 °C; (VDM = 67% of VDRM); gate open circuit; exponential waveform; Fig. 12 - 300 - V/µs Simplified outline Graphic symbol Dynamic characteristics dVD/dt rate of rise of off-state voltage 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K cathode mb A K G 2 A anode 3 G gate mb A mounting base; connected to anode sym037 1 2 3 TO-220AB (SOT78) 6. Ordering information Table 3. Ordering information Type number BT151-500RT BT151-500RT Product data sheet Package Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 2 / 12 BT151-500RT WeEn Semiconductors SCR 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDRM Min Max Unit repetitive peak off-state voltage - 500 V VRRM repetitive peak reverse voltage - 500 V IT(AV) average on-state current half sine wave; Tmb ≤ 133 °C - 8 A IT(RMS) RMS on-state current half sine wave; Tmb ≤ 133 °C; Fig. 1; Fig. 2; Fig. 3 - 12.5 A ITSM non-repetitive peak onstate current half sine wave; Tj(init) = 25 °C; tp = 8.3 ms - 132 A half sine wave; Tj(init) = 25 °C; tp = 10 ms; Fig. 4; Fig. 5 - 120 A 2 Conditions 2 I t I t for fusing tp = 10 ms; SIN - 72 A²s dIT/dt rate of rise of on-state current IG = 30 mA - 50 A/µs IGM peak gate current - 4 A VRGM peak reverse gate voltage - 5 V PGM peak gate power - 5 W PG(AV) average gate power - 1 W Tstg storage temperature -40 150 °C Tj junction temperature - 150 °C over any 20 ms period 003a a d205 30 I T(RMS ) (A) 25 003aad206 16 IT(RMS) (A) 133 °C 12 20 8 15 10 4 5 0 10-2 10-1 0 -50 1 10 s urge duratio n (s ) f = 50 Hz; Tmb = 133 °C Fig. 1. RMS on-state current as a function of surge duration; maximum values BT151-500RT Product data sheet 0 50 100 150 Tmb (°C) Fig. 2. RMS on-state current as a function of mounting base temperature; maximum values All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 3 / 12 BT151-500RT WeEn Semiconductors SCR 003aad202 15 Tmb(max) (°C) a = 1.57 Ptot (W) 1.9 2.2 2.8 10 130.5 137 4.0 5 0 0 2 conduction angle (degrees) form factor a 30 60 90 120 180 4 2.8 2.2 1.9 1.57 4 143.5 α 6 8 IT(AV) (A) 150 α = conduction angle a = form factor = IT(RMS) / IT(AV) Fig. 3. Total power dissipation as a function of average on-state current; maximum values 003aad203 160 ITSM (A) 120 80 IT ITSM 40 0 t tp Tj(init) = 25 °C max 1 102 10 number of cycles 103 f = 50 Hz Fig. 4. Non-repetitive peak on-state current as a function of the number of sinusoidal current cycles; maximum values BT151-500RT Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 4 / 12 BT151-500RT WeEn Semiconductors SCR 003aad204 103 ITSM (A) (1) 102 IT 10 10-5 ITSM t tp Tj(init) = 25 °C max 10-4 10-3 tp (s) 10-2 tp ≤ 10 ms (1) dIT/dt limit Fig. 5. Non-repetitive peak on-state current as a function of pulse width for sinusoidal currents; maximum values BT151-500RT Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 5 / 12 BT151-500RT WeEn Semiconductors SCR 8. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base Fig. 6 - - 1.3 K/W Rth(j-a) thermal resistance from junction to ambient free air in free air - 60 - K/W 001aaa962 10 Zth(j-mb) (K/W) 1 10-1 10-2 10-3 10-5 10-4 10-3 10-2 10-1 1 tp (s) 10 Fig. 6. Transient thermal impedance from junction to mounting base as a function of pulse width BT151-500RT Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 6 / 12 BT151-500RT WeEn Semiconductors SCR 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics IGT gate trigger current VD = 12 V; IT = 0.1 A; Tj = 25 °C; Fig. 7 - 2 15 mA IL latching current VD = 12 V; IG = 0.1 A; Tj = 25 °C; Fig. 8 - 10 40 mA IH holding current VD = 12 V; Tj = 25 °C; Fig. 9 - 7 20 mA VT on-state voltage IT = 23 A; Tj = 25 °C; Fig. 10 - 1.4 1.75 V VGT gate trigger voltage VD = 12 V; IT = 0.1 A; Tj = 25 °C; Fig. 11 - 0.6 1 V VD = 500 V; IT = 0.1 A; Tj = 150 °C; Fig. 11 0.25 0.4 - V ID off-state current VD = 500 V; Tj = 150 °C - 0.5 2.5 mA IR reverse current VR = 500 V; Tj = 150 °C - 0.5 2.5 mA Dynamic characteristics dVD/dt rate of rise of off-state voltage VDM = 335 V; Tj = 150 °C; (VDM = 67% of VDRM); gate open circuit; exponential waveform; Fig. 12 - 300 - V/µs tgt gate-controlled turn-on ITM = 40 A; VD = 500 V; IG = 0.1 A; dIG/ time dt = 5 A/µs; Tj = 25 °C - 2 - µs tq commutated turn-off time - 70 - µs VDM = 335 V; Tj = 150 °C; ITM = 20 A; VR = 25 V; (dIT/dt)M = 30 A/µs; dVD/ dt = 50 V/µs; RGK(ext) = 100 Ω; (VDM = 67% of VDRM) 003aab824 3 IGT IGT(25°C) IL IL(25°C) 2 2 1 1 0 -50 0 50 100 Tj (°C) 0 -50 150 Fig. 7. Normalized gate trigger current as a function of junction temperature BT151-500RT Product data sheet 003aab825 3 0 50 100 Tj (°C) 150 Fig. 8. Normalized latching current as a function of junction temperature All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 7 / 12 BT151-500RT WeEn Semiconductors SCR 003aab826 3 003a a f776 25 IT (A) IH IH(25°C) 20 2 15 10 (1) 1 (2) 5 0 -50 0 50 100 Tj (°C) 0 150 (3) 0 1 VT (V) 2 Vo = 0.825 V; Rs = 0.41 Ω (1) Tj = 150°C; typical values (2) Tj = 150°C; maximum values (3) Tj = 25°C; maximum values Fig. 9. Normalized holding current as a function of junction temperature Fig. 10. On-state current as a function of on-state voltage 003aab823 1.6 VGT VGT(25°C) dVD/dt (V/µs) 1.2 103 0.8 102 0.4 -50 0 50 100 Tj (°C) 10 150 Fig. 11. Normalized gate trigger voltage as a function of junction temperature BT151-500RT Product data sheet 003aab827 104 0 50 100 Tj (°C) 150 gate open circuit Fig. 12. Critical rate of rise of off-state voltage as a function of junction temperature; typical values All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 8 / 12 BT151-500RT WeEn Semiconductors SCR 10. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) e c e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig. 13. Package outline TO-220AB (SOT78) BT151-500RT Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 9 / 12 BT151-500RT WeEn Semiconductors SCR Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 11. Legal information Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. Product data sheet Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. BT151-500RT Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 10 / 12 BT151-500RT WeEn Semiconductors SCR Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BT151-500RT Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 11 / 12 BT151-500RT WeEn Semiconductors SCR 12. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Limiting values............................................................. 3 8. Thermal characteristics............................................... 6 9. Characteristics..............................................................7 10. Package outline.......................................................... 9 11. Legal information..................................................... 10 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved For more information, please visit: http://www.ween-semi.com For sales office addresses, please send an email to: salesaddresses@ween-semi.com Date of release: 22 February 2018 BT151-500RT Product data sheet All information provided in this document is subject to legal disclaimers. 22 February 2018 © WeEn Semiconductors Co., Ltd. 2018. All rights reserved 12 / 12
BT151-500RT,127
物料型号:BT151-500RT
器件简介: - 该SCR为平面钝化硅控整流器,封装在SOT78(TO-220AB)塑料包中。 - 适用于需要良好双向阻断电压能力、高浪涌电流能力、高结温能力和高热循环性能的应用。
引脚分配: - 引脚1:K(阴极) - 引脚2:A(阳极) - 引脚3:G(门极)
参数特性: - 重复峰值反向电压(VRRM):500V - 非重复峰值导通电流(ITSM):8.3ms半正弦波时132A,10ms时120A - 结温(T):最高150°C - 栅极触发电流(IGT):在12V电压和0.1A电流下,典型值2mA到15mA - 关断状态电压上升率(dVp/dt):在335V下,典型值300V/µs
功能详解: - 该器件具有良好的双向阻断电压能力,适用于电容放电点火(CDI)、保护电路、电动机控制和电压调节等应用。
应用信息: - 适用于电容放电点火系统、保护电路、电动机控制和电压调节。
封装信息: - 封装类型:TO-220AB(SOT78) - 封装描述:塑料单端封装,散热器安装,1个安装孔,3引脚
其他信息: - 文档中还包含了限制值、热特性、特性图表和封装轮廓图。 - 文档的法律信息部分明确了数据表的状态、产品状态定义、免责声明等。
BT151-500RT,127 价格&库存
很抱歉,暂时无法提供与“BT151-500RT,127”相匹配的价格&库存,您可以联系我们找货
BT151-500RT,127
  • 1+10.573561+1.36798
