OT407,412
OT407,412
    WEEN(瑞能)
    TO92-2
    TRIAC SOT54A
OT407,412 数据手册
OT407 Four-quadrant triac, enhanced noise immunity Rev. 01 — 19 May 2008 Product data sheet 1. Product profile 1.1 General description Passivated sensitive gate triac in a SOT54A (wide pitch) plastic package 1.2 Features n Sensitive gate n Direct interfacing to logic level ICs n Gate triggering in four quadrants n Direct interfacing to low power gate drive circuits n High blocking voltage to 800 V n Enhanced immunity to voltage transients and noise 1.3 Applications n Home appliances n Low power AC fan speed controllers n Low power motor control n Low power loads in industrial process control 1.4 Quick reference data n VDRM ≤ 800 V n ITSM ≤ 12.5 A (t = 20 ms) n IT(RMS) ≤ 1 A n IGT ≤ 5 mA n IGT ≤ 7 mA (T2− G+) 2. Pinning information Table 1. Pinning Pin Description Simplified outline Graphic symbol 1 main terminal 2 (T2) 2 gate (G) T2 3 main terminal 1 (T1) sym051 T1 G 3 2 SOT54A 1 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 3. Ordering information Table 2. Ordering information Type number OT407 Package Name Description Version - plastic single-ended leaded (through hole) package; 3 leads (wide pitch) SOT54A 4. Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VDRM repetitive peak off-state voltage Conditions - 800 V VRRM repetitive peak reverse voltage - 800 V IT(RMS) RMS on-state current full sine wave; Tlead ≤ 38 °C; see Figure 4 and 5 - 1 A ITSM non-repetitive peak on-state current full sine wave; Tj = 25 °C prior to surge; see Figure 2 and 3 t = 20 ms - 12.5 A t = 16.7 ms - 13.8 A - 1.28 A2s T2+ G+ - 50 A/µs T2+ G− - 50 A/µs T2− G− - 50 A/µs T2− G+ - 10 A/µs I2t I2t for fusing tp = 10 ms dIT/dt rate of rise of on-state current ITM = 1 A; IG = 20 mA; dIG/dt = 0.2 A/µs IGM peak gate current - 1 A PGM peak gate power - 2 W PG(AV) average gate power - 0.1 W Tstg storage temperature −40 +150 °C Tj junction temperature - 125 °C over any 20 ms period OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 2 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 003aac259 2.0 Ptot (W) 1.6 1.2 conduction angle (degrees) form factor a 30 60 90 120 180 4 2.8 2.2 1.9 1.57 α = 180° α 120° 90° 60° 0.8 30° 0.4 0.0 0 0.2 0.4 0.6 0.8 1 1.2 IT(RMS) (A) α = conduction angle Fig 1. Total power dissipation as a function of RMS on-state current; maximum values 003aac260 16 ITSM (A) 12 8 ITSM IT 4 t 1/f Tj(init) = 25 °C max 0 1 102 10 number of cycles 103 f = 50 Hz Fig 2. Non-repetitive peak on-state current as a function of the number of sinusoidal current cycles; maximum values OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 3 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 003aac262 103 ITSM IT ITSM (A) t tp Tj(init) = 25 °C max 102 (1) (2) 10 1 10-5 10-4 10-3 10-2 10-1 tp (s) tp ≤ 20 ms (1) dIT/dt limit (2) T2− G+ quadrant limit Fig 3. Non-repetitive peak on-state current as a function of pulse width; maximum values 003aac263 16 IT(RMS) (A) 003aac264 1.2 IT(RMS) (A) 12 0.8 8 0.4 4 0 10-2 10-1 0 -50 1 10 surge duration (s) 0 50 100 150 Tlead (°C) f = 50 Hz Tlead = 38 °C Fig 4. RMS on-state current as a function of surge duration; maximum values Fig 5. RMS on-state current as a function of solder point temperature; maximum values OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 4 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 5. Thermal characteristics Table 4. Thermal characteristics Symbol Parameter Rth(j-lead) Rth(j-a) Conditions Min Typ Max Unit thermal resistance from junction to full cycle; see Figure 6 lead - - 60 K/W thermal resistance from junction to full cycle; printed-circuit ambient board mounted; lead length = 4 mm - 150 - K/W 003aac206 102 Zth(j-lead) (K/W) 10 1 P 10−1 tp t 10−2 10−5 Fig 6. 10−4 10−3 10−2 10−1 1 tp (s) 10 Transient thermal impedance from junction to lead as a function of pulse width OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 5 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 6. Static characteristics Table 5. Static characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter IGT IL gate trigger current latching current Conditions Min Typ Max Unit T2+ G+ 0.25 - 5 mA T2+ G− 0.25 - 5 mA T2− G− 0.25 - 5 mA T2− G+ 0.35 - 7 mA T2+ G+ - - 10 mA T2+ G− - - 25 mA T2− G− - - 10 mA T2− G+ VD = 12 V; IT = 0.1 A; see Figure 8 VD = 12 V; IG = 0.1 A; see Figure 10 - - 10 mA IH holding current VD = 12 V; IG = 0.1 A; see Figure 11 - - 10 mA VT on-state voltage IT = 1 A; see Figure 9 - 1.3 1.6 V VGT gate trigger voltage VD = 12 V; IT = 0.1 A; see Figure 7 - - 1.3 V ID off-state current VD = VDRM; IT = 0.1 A; Tj = 125 °C 0.2 - - V VD = VDRM(max); Tj = 125 °C - - 0.5 mA OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 6 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 7. Dynamic characteristics Table 6. Dynamic characteristics Symbol Parameter Conditions rate of rise of off-state voltage VDM = 0.67VDRM(max); Tj = 110 °C; exponential waveform; gate open circuit dVD/dt dVcom/dt rate of change of commutating voltage VDM = 400 V; Tj = 110 °C; ITM = 1 A; dIcom/dt = 0.44 A/ms 003aaa209 1.6 Min Typ Max Unit 20 - - V/µs 1 - - V/µs 003aaa205 4 VGT IGT VGT(25°C) IGT(25°C) 3 1.2 (1) (2) (3) (4) 0.8 2 0.4 1 0 −50 0 50 100 0 −50 150 0 50 100 150 Tj (°C) Tj (°C) (1) T2+ G+ (2) T2+ G− (3) T2− G− (4) T2− G+ Fig 7. Normalized gate trigger voltage as a function of junction temperature Fig 8. Normalized gate trigger current as a function of junction temperature OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 7 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 003aac258 2 003aaa203 3 IT (A) IL IL(25°C) 1.6 2 1.2 0.8 (1) (2) (3) 1 0.4 0 0 0.4 0.8 1.2 1.6 VT (V) 0 −50 2 0 50 100 150 Tj (°C) Vo = 1.254 V; Rs = 0.31 Ω (1) Tj = 125 °C; typical values (2) Tj = 125 °C; maximum values (3) Tj = 25 °C; maximum values Fig 9. On-state current as a function of on-state voltage Fig 10. Normalized latching current as a function of junction temperature 003aaa204 3 IH IH(25°C) 2 1 0 −50 0 50 100 150 Tj (°C) Fig 11. Normalized holding current as a function of junction temperature OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 8 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 8. Package outline Plastic single-ended leaded (through hole) package; 3 leads (wide pitch) SOT54A c E A L d L2 b 1 e1 e D 2 3 b1 L1 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A b b1 c D d E e e1 L L1(1) mm 5.2 5.0 0.48 0.40 0.66 0.55 0.45 0.38 4.8 4.4 1.7 1.4 4.2 3.6 5.08 2.54 14.5 12.7 3 max. L2 3 2 Note 1. Terminal dimensions within this zone are uncontrolled to allow for flow of plastic and terminal irregularities. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 97-05-13 04-06-28 SOT54A Fig 12. Package outline SOT54A OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 9 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 9. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes OT407_1 20080519 Product data sheet - - OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 10 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 10. Legal information 10.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 10.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 10.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 10.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 11. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com OT407_1 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 01 — 19 May 2008 11 of 12 OT407 NXP Semiconductors Four-quadrant triac, enhanced noise immunity 12. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 10.1 10.2 10.3 10.4 11 12 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics. . . . . . . . . . . . . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2008. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 19 May 2008 Document identifier: OT407_1
OT407,412 价格&库存
很抱歉,暂时无法提供与“OT407,412”相匹配的价格&库存,您可以联系我们找货
