FXP840.07.0055B
FXP840.07.0055B
    TAOGLASLIMITED
    FXP840.07.0055B
FXP840.07.0055B 数据手册
Freedom Part No: FXP840.07.0055B Description FXP840 Freedom Series super small Wi-Fi 2.4/5.8/7.125GHz flexible monopole antenna with Wi-Fi 6 capabilities Features: Wi-Fi (Including Wi-Fi 6) 2.4-2.5, 4.9-5.8, 5.9-7.125 GHz Flexible and Tiny - Ultra Low Profile Adheres directly inside of product plastic or glass housing Form factor and cable routing convenient for integration I-PEX MHF I Connector (U.FL compatible) 55mm Ø 0.81mm mini-coaxial cable Dimensions: 14*5*0.1mm RoHS & Reach Compliant SPE-12-8-115-K 1. Introduction 3 2. Specification 5 3. Antenna Characteristics 6 4. Radiation Patterns 10 5. Mechanical Drawing 20 6. Packaging 21 Changelog 22 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. 2 SPE-12-8-115-K www.taoglas.com 1. Introduction The patent pending FXP840 is a super small, ultra-low profile monopole antenna for Wi-Fi applications over the 2.4, 4.9-5.8 and 5.8-7.125GHz bands. Engineered for Wi-Fi (including Wi-Fi 6), Bluetooth, ZigBee and other applications in these bands, including C-V2X and DSRC. This Taoglas patent pending antenna is unique in the market because it is made from poly-flexible material, has a tiny form factor, just 14mm*5.0mm*0.1mm, and has double-sided 3M tape for easy “peel and stick” mounting. The cable routes conveniently directly from the edge of the antenna, reducing the volume the antenna takes up in the device to an absolute minimum, compared to other antenna designs. The FXP840 is the ideal all-round antenna solution for fitting into compact spaces and still maintaining high performance, for example on the inside top or adjacent side applied directly to the plastic housing of LCD monitors, tablets, smartphones. Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. 3 SPE-12-8-115-K www.taoglas.com For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. The cable and connector are fully customizable. For more information, or how to integrate the antenna into your device, contact your local Taoglas customer service team. 4 SPE-12-8-115-K www.taoglas.com 2. Specification Wi-Fi Electrical Band Frequency (MHz) Average Gain Peak Gain (dBi) (dB) Efficiency (%) Wi-Fi - 2GHz 2400-2500 39.8 -4.00 3.35 Wi-Fi - 5GHz 5150-5850 28.3 -5.48 3.37 Wi-Fi - 6GHz 5925-7125 35.4 -4.51 5.31 Impedance Polarization Radiation Pattern Max. input power 50 Ω Linear Omni 2W Tested on 1mm ABS (Plastic) Mechanical Dimensions 14 x 5 x 0.1 mm Material Polymer Connector I-PEX MHF I (U.FL Compatible) Cable 55mm of Ø0.81mm Weight 1g Environmental Operation Temperature -40°C to +85°C Storage Temperature -40°C to +85°C Humidity Non-condensing 65°C 95% RH RoHS Compliant Yes REACH Compliant Yes 5 SPE-12-8-115-K www.taoglas.com 3. Antenna Characteristics 3.1 Test Setup VNA test setup on 1mm ABS (Plastic) Ground Plane 6 SPE-12-8-115-K www.taoglas.com 3.2 Return Loss 3.3 VSWR 7 SPE-12-8-115-K www.taoglas.com 3.4 Efficiency 3.5 Average Gain 8 SPE-12-8-115-K www.taoglas.com 3.6 Peak Gain 9 SPE-12-8-115-K www.taoglas.com 4. Radiation Patterns 4.1 Test Setup Z Y X Chamber test setup on 1mm ABS (Plastic) Ground Plane 10 SPE-12-8-115-K www.taoglas.com 4.2 Patterns at 2400 MHz XZ Plane YZ Plane XY Plane 11 SPE-12-8-115-K www.taoglas.com 4.3 Patterns at 2450 MHz XZ Plane YZ Plane XY Plane 12 SPE-12-8-115-K www.taoglas.com 4.4 Patterns at 2500 MHz XZ Plane YZ Plane XY Plane 13 SPE-12-8-115-K www.taoglas.com 4.5 Patterns at 5150 MHz XZ Plane YZ Plane XY Plane 14 SPE-12-8-115-K www.taoglas.com 4.6 Patterns at 5350 MHz XZ Plane YZ Plane XY Plane 15 SPE-12-8-115-K www.taoglas.com 4.7 Patterns at 5850 MHz XZ Plane YZ Plane XY Plane 16 SPE-12-8-115-K www.taoglas.com 4.8 Patterns at 5925 MHz XZ Plane YZ Plane XY Plane 17 SPE-12-8-115-K www.taoglas.com 4.9 Patterns at 6525 MHz XZ Plane YZ Plane XY Plane 18 SPE-12-8-115-K www.taoglas.com 4.10 Patterns at 7125 MHz XZ Plane YZ Plane XY Plane 19 SPE-12-8-115-K www.taoglas.com 5. Mechanical Drawing 20 SPE-12-8-115-K www.taoglas.com 6. Packaging 1pcs FXP840.07.0055B per PE Bag Weight - 1g 2000pcs FXP840.07.0055B per carton Dimensions - 230*160*175mm Weight - 6.8Kg 21 SPE-12-8-115-K www.taoglas.com Changelog for the datasheet SPE-12-8-115 - FXP840.07.0055B Revision: K (Current Version) Date: Changes: Changes Made by: 2024-02-13 Full datasheet update. Gary West Previous Revisions Revision: E Revision: J Date: Changes: Changes Made by: 2020-09-04 Updated Wi-Fi 6 info Jack Conroy Revision: I Date: Changes: Changes Made by: 2017-03-08 Added Note on Intro Aine Doyle Revision: D Date: Changes: Changes Made by: 2017-03-08 ECR-18-8-259 Russell Meyler Revision: H Date: Changes: Changes Made by: 2012-11-19 Packaging Details Updated Aine Doyle Revision: C Date: Changes: Changes Made by: 2018-06-27 Updated Peak Gain Jack Conroy Revision: G Date: Changes: Changes Made by: Changes Made by: Changes Made by: 2012-10-02 Updated Drawing Aine Doyle Revision: B 2018-06-27 Updated Peak Gain Carol Faughnan Revision: F Date: Changes: Date: Changes: Date: Changes: Changes Made by: 2012-09-27 Packaging Details Updated Aine Doyle Revision: A (Original First Release) 2017-05-07 PCN-17-8-081 Aine Doyle Date: Notes: Author: 2012-09-13 Technical Writer 22 SPE-12-8-115-K www.taoglas.com 23 SPE-12-8-115-K www.taoglas.com
FXP840.07.0055B 价格&库存
很抱歉,暂时无法提供与“FXP840.07.0055B”相匹配的价格&库存,您可以联系我们找货
FXP840.07.0055B
  • 4+47.163234+6.11326
  • 10+41.4142410+5.36808
  • 25+40.9414225+5.30679
  • 100+29.63222100+3.84090
  • 250+29.34060250+3.80310
  • 500+29.32440500+3.80100
  • 1000+29.138081000+3.77685
库存:4600
FXP840.07.0055B
  • 1+72.975391+9.45900
  • 10+56.5140910+7.32531
  • 25+52.3922225+6.79103
  • 100+47.86480100+6.20419
  • 250+45.70594250+5.92436
  • 500+44.40468500+5.75570
  • 1000+43.333631000+5.61687
库存:3591
FXP840.07.0055B
  • 1+46.354721+6.00846
  • 10+40.7042810+5.27605
  • 25+40.2395725+5.21582
  • 100+29.12424100+3.77506
  • 250+28.83762250+3.73791
  • 500+28.82170500+3.73584
  • 1000+28.638571000+3.71211
库存:4600
FXP840.07.0055B
    • 100+35.17273
    库存:102
    FXP840.07.0055B
    库存:20
    FXP840.07.0055B
      FXP840.07.0055B
      • 2+54.115752+7.01443
      • 10+48.1625910+6.24279
      • 25+47.6575325+6.17733
      • 100+34.62223100+4.48770
      • 250+34.28200250+4.44360
      • 500+33.93368500+4.39845
      • 1000+33.885071000+4.39215
      库存:1963
      FXP840.07.0055B
        FXP840.07.0055B
          • 1+101.12040
          • 200+40.34880
          • 500+38.99880
          • 1000+38.34000
