ANT6230LL01R1575A
ANT6230LL01R1575A
    YAGEO(国巨)
    CHIP ANTENNA GPS 6.2X3.0X1.25 MM
ANT6230LL01R1575A 数据手册
DATA SHEET WIRELESS COMPONENTS Ceramic Chip Antenna ANT6230LL01R1575A GPS Product Specification –February 5, 2013 V.0 6230 Series Product specification WIRELESS COMPONENTS FEATURES z Compact size z High radiation efficiency z Reflow process compatible z RoHS compliant APPLICATIONS z Tablet z Navigation device z Telematics box z Fleet management Ceramic Chip Antenna 2 6 ORDERING INFORMATION All part numbers are identified by the series, packing type, material, size, antenna type, working frequency and packing quantity. PART NUMBER ANT 6230 L L01 R 1575A (1) (2) (3) (4) (5) (6) (1) PRODUCT ANT = Antenna (2) SIZE 6230 =6.2 × 3.0 mm (3) ANTENNA TYPE L,F,A = Chip Antenna (4) SERIAL NO. L01 (5) PACKING STYLE R = Tape and Reel (6) WORKING FREQUENCY 1575 = 1.575GHz PHYCOMP CTC CAN4311763011582K 12NC 431176301158 www.yageo.com Feb. 5, 2013 V0 Product specification WIRELESS COMPONENTS Ceramic Chip Antenna 3 6 SPECIFICATION Table 1 VALUE DESCRIPTION Centre Frequency 1.575GHz Bandwidth 55 MHz(Typ.) Return Loss 10 dB (min) Polarization Linear Azimuth Beamwidth Omni-directional Peak Gain 2.52 dBi(Typ.) Impedance 50 Ω - 40~105 ℃ Operating Temperature Maximum Power 1W Termination Ni / Sn (Environmentally-Friendly Leadless) Resistance to Soldering Heats 260℃ , 10sec. NOTE 1. The specification is defined on Yageo evaluation board DIMENSIONS Table 2 Machinical Dimension DIMENSION L (mm) 6.15 ±0.25 W (mm) 3.00 ±0.25 T (mm) 1.25 ±0.15 A (mm) 0.50 ±0.20 OUTLINES Table 3 Termination configuration TERMINAL NAME FUNCTION S1 Feeding Point S2 Soldering Point Fig. 1 Antenna outlines www.yageo.com Feb. 5, 2013 V0 Product specification WIRELESS COMPONENTS 4 6 Ceramic Chip Antenna REFERENCE DESIGN OF EVALUATION BOARD 100 50 12 7 Fig. 3 Outlook and dimension of evaluation board Unit : mm 2.9 Top Layer 3.6 Bottom Layer / GND 1.7 Unit : mm 5.2 Matching Circuit 1.3 1.5 5.4 YNH0057 Fig. 4 Details of soldering Pad www.yageo.com Feb. 5, 2013 V0 Product specification WIRELESS COMPONENTS 5 6 Ceramic Chip Antenna ELECTRICAL PERFORMANCES Return loss (dB) 50 YNH0058 30 10 −10 3 1 −30 −50 1.475 2 1.515 1.555 1.595 1.635 1.675 f (GHz) Marker data 1. 1.553GHz, -10dB 2. 1.575GHz, -38.3dB 3. 1.594GHz, -10dB Fig. 5 Return loss Gain (dBi) 5.00 − Z axle 0.00 − X Y − 5.00 − − 10.00 − Z − 15.00 − − 20.00 − − 25.00 − X axle Y axle − 30.00 − Evaluation board and XYZ direction − 35.00 − YNH0055 Frequency= 1.575 GHz Max gain = 1.51 dBi, at (150,240) MEG (mean effective gain)= -2.66 dBi Directivity (dB) = 4.07 Efficiency = -2.56 dB, 55.45 % Fig. 6 Radiation pattern www.yageo.com Feb. 5, 2013 V0 Product specification WIRELESS COMPONENTS 6 6 Ceramic Chip Antenna REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version 0 - Feb. 05, 2013 DESCRIPTION - New datasheet for SMD type antenna, 1.575 GHz application, 6230 series www.yageo.com Feb. 5, 2013 V0
ANT6230LL01R1575A 价格&库存
很抱歉,暂时无法提供与“ANT6230LL01R1575A”相匹配的价格&库存,您可以联系我们找货
