FXP40.07.0085A
FXP40.07.0085A
    TAOGLASLIMITED
    FXP40.07.0085A
FXP40.07.0085A 数据手册
FXP40 Flexible PCB Antenna Part No: FXP40.07.0085A Description: 4G LTE CAT-M NB-IoT Flexible PCB Antnna Features: 700-960/1710-2200MHz Bands 1.9 dBi Peak Gain Easy peel and stick adhesive Dimension: 42.6*12.1*0.15mm Connector: IPEX MHFI (U.FL Compatible) Cable: 85mm 1.13mm cable REACH & RoHS Compliant SPE-14-8-053-D 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing 24 6. Packaging 25 7. Application Note 26 Changelog 28 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-14-8-053-D www.taoglas.com 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The Taoglas FXP40 is a super small monopole ultra low profile antenna for cellular and NB-IoT bands between 700 and 2200 MHz. The FXP40 has a peak gain of 1.3dBi and efficiencies of 56% are achievable if integrated correctly. 1. It is manufactured from a poly-flexible material, has a tiny form factor of just 42.6 x 12.1 x 0.15mm and is supplied with a double-sided 3M tape for easy “peel and stick” mounting. It is designed to be mounted directly onto a plastic and is an ideal choice for any device maker that needs to keep manufacturing costs at a minimum over the lifetime of a product. 1. 1. Introduction Introduction Introduction Typical Applications include: - Wearables - Remote Monitoring - Handheld devices Introduction The cables length can be customizable for customers. Contact your regional customer support team for further information. SPE-14-8-053-D www.taoglas.com 2. Specifications 3. Antenna Characteristics2. Band Frequency (MHz) 4G/3G Efficiency Average Peak Gain Impedance Gain (%) (dBi) (dB) Freespace 12 -9.4 -2.7 698~806 3.Band 12,13,14,17,28,29 Antenna Characteristics 2mm ABS 17 4G/3G/NB-IoT/Cat M Band 5,8,18,19,20,26,27 4. 824~960 Specifications Electrical -9.2 -3.1 Freespace 16 -8.1 -0.5 2mm ABS 25 -6.4 1.3 Max Input Power 50 Ω 2mm ABS Characteristics2. 4G/3G Band 7,30,38,40,41 2300~2690 -5.3 3.8 Specifications Freespace 18 -7.9 0.7 2mm ABS 34 11 -10.8 Radiation Properties Linear Omni-Directional 5W Freespace 56 -2.5 5.3 Antenna 1710~2200 Radiation Patterns3. Antenna 4G/3G Band 1,2,3,4,9,23,25,35,39,66 Polarization 1.6 Mechanical 3. 3. 4. Dimensions (mm) Antenna MaterialCharacteristics2. 46.2*12.1*0.15 mm Specifications Flexible Polymer Connector and Cable IPEX MHFI (U.FL Compatible) and 1.13 mm mini coax Weight 1g Operation Temperature Antenna Characteristics Environmental -40°C to 85°C Storage Temperature -40°C to 85°C Relative Humidity 40% to 95% RoHs Compliant Yes Antenna Radiation Patterns3.Antenna *All results were measured with 85mm length 1.13mm coaxial cable and on 2mm thickness ABS base. Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-14-8-053-D Specifications www.taoglas.com 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 0 4. Antenna Radiation Patterns 4. Return Loss [dB] -5 -10 -15 -20 Antenna Radiation Patterns3.Antenna -25 Characteristics -30 Freespace -35 4. Antenna Radiation Patterns3.Antenna -40 600 Characteristics 3.2 4. 900 1200 1500 1800 2mm ABS 2100 2400 2700 3000 Frequency [MHz] Efficiency Antenna Radiation Patterns 100 Freespace 90 2mm ABS 80 4. Antenna Radiation Patterns 70 Efficiency [%] 4. 60 50 40 Antenna Radiation Patterns 30 20 4. 10 Antenna Radiation Patterns3.Antenna 0 600 Characteristics 900 1200 1500 1800 2100 2400 2700 3000 Frequency [MHz] 4. Antenna Radiation Patterns3.Antenna SPE-14-8-053-D www.taoglas.com 3.3 Peak Gain 8 Freespace 6 2mm ABS 4 Gain [dBi] 2 0 -2 -4 -6 -8 -10 600 900 1200 1500 1800 2100 2400 2700 2100 2400 2700 3000 Frequency [MHz] 3.4 Average Gain 0 -2 -4 Aver Gain [dB] -6 -8 -10 -12 -14 -16 Freespace -18 2mm ABS -20 600 900 1200 1500 1800 3000 Frequency [MHz] SPE-14-8-053-D www.taoglas.com 4. Radiation Patterns 4. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4.1 Test Setup Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-14-8-053-D www.taoglas.com 4.2 750MHz Freespace - 3D and 2D Radiation Patterns XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 825MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 880MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 960MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 1710MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 1880MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 1990MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 2170MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 4.3 750MHz On 2mm ABS - 3D and 2D Radiation Patterns XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 825MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 880MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 960MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 1710MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 1880MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 1990MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 2170MHz XY Plane SPE-14-8-053-D XZ Plane YZ Plane www.taoglas.com 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-053-D Mechanical Drawing www.taoglas.com 8. 6. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-053-D Mechanical Drawing www.taoglas.com 8. 7. Packaging Note Application The FXP40 antenna measurement with difference cable length on plastic plate of 2 mm thickness, the is shown as below. 6.performance Packaging5. Mechanical Drawing 3.1 Return Loss 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 6. Packaging 3.2 Mechanical Drawing Efficiency 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-14-8-053-D Mechanical Drawing www.taoglas.com 3.3 Peak Gain 3.4 Average Gain SPE-14-8-053-D www.taoglas.com Changelog for the datasheet SPE-14-8-053 - FXP40.07.0085A Revision: D (Current Version) Date: Changes: Changes Made by: 2022-04-21 Full datasheet update Gary West Previous Revisions Revision: C Date: Changes: Changes Made by: 2020-07-01 Updated Weight Jack Conroy Revision: B Date: Changes: Changes Made by: 2019-04-11 Page 1 Features, page 3 Specification, page 4~5 Antenna Characteristicspage7~9 Antenna radiation patterns, page11~12 Application Note. David Connolly Revision: A (Original First Release) Date: Notes: Author: SPE-14-8-053-D 2014-05-26 Technical Writer www.taoglas.com © Taoglas SPE-14-8-053-D www.taoglas.com
FXP40.07.0085A 价格&库存
很抱歉,暂时无法提供与“FXP40.07.0085A”相匹配的价格&库存,您可以联系我们找货
FXP40.07.0085A
    • 100+15.23467
    库存:5
    FXP40.07.0085A
