SPECIFICATION
Part No.
AGGBP.25A.07.0060A
Description
25x25mm One Stage GPS-GLONASS-GALILEO-BeiDou
Embedded Active Patch Antenna Module with Front-End
SAW Filter
Features
Full GPS-GLONASS-GALILEO-BeiDou Coverage
18dB One-stage LNA
Ceramic patch element
Front-end SAW filter to reduce out of band noise
Wide input voltage 1.8V to 5.5V
25.1 x 25.1 x 7.9mm
60mm Ø1.13 IPEX MHFI (U.FL)
Automotive TS16949 Production and Quality Approved
Cable length and connector type customizable
RoHS compliant
SPE-15-8-021/A/WY Page 1 of 13
1. Introduction
The AGGBP.25A is an internal GPS/GLONASS/GALILEO/BeiDou active patch antenna with
Ø1.13 cable and IPEX MHFI (U.FL compatible) connector. It is the ideal antenna for next
generation GNSS devices to achieve good sensitivity across all bands in a small form
factor.
The active patch antenna, by means of a double resonance design, has a wide-band
operation over GPS/GLONASS/GALILEO/BeiDou systems from 1561MHz to 1606MHz. It
includes a one-stage LNA and front-end SAW filter to reduce out of band noise, such as
from nearby cellular transceivers. This antenna offers better protection from nearby
radiated power surges and greatly reduces the probability of damaging your
GPS/GLONASS/GALILEO/BeiDou receiver due to nearby transmissions.
The patch, the ground plane, the LNA, and front-end SAW components are all integrated
in a dimension of 25.1 x 25.1 x 7.9 mm, connecting with a Ø1.13 60mm long coaxial cable
and an IPEX MHFI connector. The AGGBP.25A is manufactured and tested in a TS16949
first tier automotive approved facility. The cable length and connector type can be
adjusted for a MOQ.
For further optimization to customer specific device environments, custom tuned patch
antennas can be supplied, again to a MOQ. For more details please contact your regional
Taoglas sales office.
SPE-15-8-021/A/WY Page 2 of 13
2. Specification
2.1.
Patch Antenna
ELECTRICAL
GPS: 1575.42 ± 1.023MHz
Frequency
Galileo: 1575.42 ± 4GHz
GLONASS: 1602 ± 5MHz
BeiDou: 1561.098 ± 2.046MHz.
Polarization
Antenna Gain at Zenith
(Ceramic Patch only)
RHCP
GPS/Galileo 1575.42MHz: -2.5 dBi typ. @zenith
GLONASS 1602MHz: -1.5 dBi typ. @zenith
BeiDou 1561MHz: -1 dBi typ. @zenith
Total Antenna Gain at Zenith
GPS/Galileo 1575.42MHz: 15.5 3dBi
(Antenna+SAW+LNA+
GLONASS 1602MHz: 16.5 3dBi
Cable+Connector)
BeiDou 1561MHz: 17 3dBi
Impedance
50 ohms
Output VSWR
Max 2.0
MECHANICAL
Ceramic Dimension
Total Dimension
(including shielding case)
25.1 x 25.1 x 4.7mm
25.1 x 25.1 x 7.9mm
Connector
IPEX MHFI (U.FL)
Cable
coaxial cable Ø1.13, length 60mm
Weight (g)
11.38
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to + 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-15-8-021/A/WY Page 3 of 13
2.2.
LNA
ELECTRICAL
Frequency
Out of Band Attenuation
1558~1610 MHz.
0-1534MHz, 13dB Min.
1634MHz-6000MHz, 20dB Min.
Output Impedance
50Ω
Output VSWR
2.0 Max
Pout at 1dB Gain
-6 dBm Min.
Compression Point
-2 dBm Typical
LNA Gain, Power Consumption and Noise Figure
Power Consumption(mA)
Voltage
LNA Gain(Typ)
Min 1.8V
12dB
5mA
3.0dB
Typ 3.0V
18dB
10mA
2.8dB
Max 5.5V
22dB
23mA
3.0dB
Typ
Noise Figure (Typ)
SPE-15-8-021/A/WY Page 4 of 13
3. LNA Gain and Noise Figure @3.0V
SPE-15-8-021/A/WY Page 5 of 13
4. Antenna Return Loss
BeiDou
GPS
GLONASS
SPE-15-8-021/A/WY Page 6 of 13
5. Antenna Radiation Properties
5.1.
Test Setup
SPE-15-8-021/A/WY Page 7 of 13
5.2.
2D Radiation Pattern
XY Plane
XZ Plane
SPE-15-8-021/A/WY Page 8 of 13
YZ Plane
5.3.
3D Radiation Pattern
1561MHz
SPE-15-8-021/A/WY Page 9 of 13
1575.42MHz
1602MHz
SPE-15-8-021/A/WY Page 10 of 13
6. Connector Usage Precautions
SPE-15-8-021/A/WY Page 11 of 13
7. Mechanical Drawing
Unit:mm
SPE-15-8-021/A/WY Page 12 of 13
8. Packaging
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-15-8-021/A/WY Page 13 of 13
很抱歉,暂时无法提供与“AGGBP.25A.07.0060A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+190.128971+24.71615
- 10+151.8975610+19.74619
- 25+142.3557425+18.50579
- 100+131.86370100+17.14186
- 300+126.01313300+16.38130
- 500+123.85045500+16.10016
