Hercules 2-in-1
Part No:
MA520.A.BC.008
Description:
Hercules 2-in-1 Cellular and Wi-Fi Permanent Mount
with 2m of RG-316 with SMA(M) for Cellular and RP-SMA(M) Wi-Fi
Features:
Cellular 4G/3G/2G
Dual Band Wi-Fi 2.4 GHz / 5.8 GHz
Low Profile and Vandal Proof
IP65 Rated Enclosure
Heavy Duty Permanent Mount
Cellular: 2m RG-316 SMA(M)
Wi-Fi: 2m RG-316 RP-SMA(M)
RoHS & REACH Compliant
SPE-13-8-071-H
1.
Introduction
3
2.
Specifications
5
3.
Antenna Characteristics
6
4.
Radiation Patterns
11
5.
Mechanical Drawing
25
6.
Packaging
26
7.
Installation Guidelines
27
8.
Application Note
28
Changelog
31
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make
changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the
information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-13-8-071-H
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
The MA520 Hercules 2-in-1 Cellular and 2.4/5.8GHz Antenna is the smallest package high performance
screw-mount (permanent mount) antenna available, for external use on vehicles and outdoor
assets worldwide. Everything is in the one housing reducing the need for multiples antenna installations.
This is the ideal antenna for 3G gateway routers that provide Wi-Fi hotspots.
Typical Applications Include:
1.
Smart Metering
Routers and Gateways
Connected Enterprise
Introduction
It has been designed for heavy duty work with extra thick threads; with durable UV-resistant, IP65 rated
enclosure, ABS housing is resistant to vandalism and direct attack. At only 29mm high and 49mm in
diameter this antenna enables covert operation and its quality is proven by growing adoption by many of
the world's largest wireless brands. The standard cable length is 2 meters. The Hercules MA520’s
exceptional design means it can work equally well mounted on or without ground-plane.
1.
Introduction
The cables and connectors are fully customizable, for further information please contact your regional
Taoglas customer support team.
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
SPE-13-8-071-H
www.taoglas.com
3
2.
Specifications
Cellular Electrical
3.
Frequency
Efficiency Average Gain
Peak Gain Max Input
Antenna
Characteristics2.
Specifications
Impedance
(MHz)
Power
(dB)
(dBi)
Band
5GNR/4G
Band 5,8,18,19,20,
26,27,28, 29
3.
700~960
37.4
-4.3
30*30cm
Ground Plane
32.2
-4.9
0.7
-4.9
0.9
32
Free space
4G/3G
1710~2200
Band
1,2,3,4,9,23,25,35,39,66
4.
Free space
4G/3G
Band 7,38,41
30*30cm
Ground Plane
30.9
-5.1
2.4
Free space
7.9
-11
-4.2
Antenna Radiation
30*30cm Patterns3.Antenna
10.3
-9.9
-2.9
2490~2690
10W
Polarization
Radiation
Pattern
Linear
Omni
50 Ω
Ground Plane
5GNR/4G
Characteristics2.
Band
22,42,43,48,77,78,79
3.
LTE5200/
Wi-Fi 5800
3300~3800
9.1
-10.4
Specifications
Free space
-2.2
30*30cm
Ground Plane
15.2
-8.2
-0.3
Free space
13.6
-8.7
1.7
5150~5925
30*30cm
21.2
Antenna Characteristics2.
Ground Plane
-6.7
1.1
Specifications
Wi-Fi Electrical
Frequency
(MHz)
Band
3.
Peak Gain
(dBi)
Antenna
Characteristics
2.4GHz Wi-Fi
2400~2500
5.8GHz Wi-Fi
4.
Efficiency
Average Gain
25
(dB)
5150~5850
Max Power Input
Radiation
Pattern
2.1
10W
50 Ω
Linear
Omni
Mechanical
Antenna Radiation Patterns3.Antenna29*Ø49mm
Dimensions
Cable
2m RG-316
Characteristics
Connector
4.
Impedance Polarization
Cellular: SMA(M) Straight
Wi-Fi: Reverse Polarity SMA(M) Straight
Thread Diameter
18mm
Casing
UV Resistant ABS
Weatherproof Gasket
Antenna
Radiation Patterns CR4305 Foam with 3M9448B Double sided adhesive
Sealant
Rubber Stopper
Base Thread
Nickel Plated
Environmental
4.
Corrosion
5% NaCI for 96hrs
Antenna
Temperature Range
-40°C to +85°C
Thermal Shock
Characteristics
Humidity
4.
100 cycles -40°C to +85°C
Non-condensing 65°C 95% RH
Shock (Drop Test)
1m drop on concrete 6 axes
RoHs & REACH Compliant
Yes
Ingress Protection
Antenna
Characteristics2.
SPE-13-8-071-H
Specifications
IP65
www.taoglas.com
4
5G/4G Bands
Band Number
5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746
18
UL: 815 to 830
DL: 860 to 875
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200
24
UL:1625.5 to 1660.5
DL: 1525 to 1559
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869
28
UL: 703 to 748
DL: 758 to 803
29
UL: -
DL: 717 to 728
30
UL: 2305 to 2315
DL: 2350 to 2360
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5
32
UL: -
DL: 1452 – 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
48
3550 to 3700
66
UL: 1710-1780
DL: 2110-2200
71
617 to 698
74/75/76
1427 to 1518
77
3300 to 4200
78
3300 to 3800
79
4400 to 5000
SPE-13-8-071-H
Covered
www.taoglas.com
5
3.
3.1
4.
Test Setup – 30*30cm Ground Plane
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4. SPE-13-8-071-H
www.taoglas.com
6
3.2
Return Loss – Cellular
SPE-13-8-071-H
www.taoglas.com
7
3.3
Efficiency – Cellular
3.4
Average Gain – Cellular
SPE-13-8-071-H
www.taoglas.com
8
3.5
Peak Gain – Cellular
3.6
Return Loss – Wi-Fi
SPE-13-8-071-H
www.taoglas.com
9
3.7
Efficiency – Wi-Fi
SPE-13-8-071-H
www.taoglas.com
10
4.
4.1
4.
Radiation Patterns
890MHz 3D and 2D Radiation Patterns – Free Space
4.
4.
4.
4.
4.
XY Plane
XZ Plane
YZ Plane
4.
4.
Radiation Patterns (Measured on 130 X 42mm EVB)
4.
4.
4.
SPE-13-8-071-H
www.taoglas.com
11
4.2
1805MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
12
4.3
1920MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
13
4.4
1990MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
14
4.5
2595MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
15
4.6
3550MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
16
4.7
5530MHz 3D and 2D Radiation Patterns – Free Space
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
17
4.8
890MHz 3D and 2D Radiation Patterns – 30*30cm Ground Plane
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
18
4.9
1805MHz 3D and 2D Radiation Patterns – 30*30cm Ground Plane
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
19
4.10
1920MHz 3D and 2D Radiation Patterns – 30*30cm Ground Plane
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
1990MHz 3D and 2D Radiation Patterns – 30*30cm Ground Plane
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
21
4.12
2595MHz 3D and 2D Radiation Patterns – 30*30cm Ground Plane
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
22
4.13
3550MHz 3D and 2D Radiation Patterns – 30*30cm Ground Plane
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
23
4.14
5530MHz 3D and 2D Radiation Patterns – 30*30cm Ground Plane
XY Plane
SPE-13-8-071-H
XZ Plane
YZ Plane
www.taoglas.com
24
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6. SPE-13-8-071-H
Packaging5.
Mechanical Drawing
www.taoglas.com
25
6.
Packaging
1 pcs MA520.A.BC.008 per PE Bag
300*160mm
4. Dimensions:
Antenna
Weight: 170g
4.
300mm
Characteristics
160mm
4.
60 pcs MA520.A.BC.008 per carton
Dimensions: 390*330*260mm
Weight: 10.5Kg
Characteristics
4.
260mm
390mm
330mm
Characteristics
4.
4.
4.
4.
Characteristics
4. SPE-13-8-071-H
www.taoglas.com
26
7.
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4. SPE-13-8-071-H
www.taoglas.com
27
8.
Application Note
8.1
4.
Efficiency –Radiation
Cellular
Antenna
Patterns3.Antenna
Characteristics
Free Space
4.
4.
Characteristics
4.
Characteristics
30*30cm Ground plane
4.
4.
4.
4.
Characteristics
4. SPE-13-8-071-H
www.taoglas.com
28
8.2
Free Space
SPE-13-8-071-H
www.taoglas.com
29
8.3
Free Space
SPE-13-8-071-H
www.taoglas.com
30
Changelog for the datasheet
SPE-13-8-071 – MA520.A.BC.008
Revision: H (Current Version)
Date:
Notes:
Author:
2021-09-19
IP Rating
Erik Landi
Previous Revisions
Revision: G
Revision: B
Date:
Notes:
Author:
2020-04-02
Updated drawing, Packaging, data and images
Jack Conroy
Revision: F
Date:
Notes:
Author:
2013-10-24
Amended Cellular data
Aine Doyle
Revision: A (Original Release)
Date:
Notes:
Author:
2017-03-01
Updated Introduction
Jack Conroy
Date:
Notes:
Author:
2013-10-9
Initial Datasheet Release
Technical Writer
Revision: E
Date:
Notes:
Author:
2016-12-23
Updated with revised salt spray data and disclaimer
Andy Mahoney
Revision: D
Date:
Notes:
Author:
2016-05-18
Updated drawing and pictures
Aine Doyle
Revision: C
Date:
Notes:
Author:
SPE-13-8-071-H
2014-01-02
Amended Photo
Aine Doyle
www.taoglas.com
31
www.taoglas.com
© Taoglas
SPE-13-8-071-H
www.taoglas.com
32
很抱歉,暂时无法提供与“MA520.A.BC.008”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+261.08102
- 9+256.29298
